Page 36 of 62
FirstFirst ... 26 34 35 36 37 38 46 ... LastLast
Results 1,051 to 1,080 of 1860
  1. Originally Posted by mickmars View Post
    Originally Posted by achilles View Post
    I always do a devine search to find out the ID that the service code is looking for. I never just copy/paste the URL from the browser.
    I didnt know that was a possibilty,in these cases.
    What's the command/procedure etc ?
    devine search [service] [keyword]
  2. Code:
    devine dl --skip-dl iP https://www.bbc.co.uk/iplayer/episode/b0074dlv/
    initially skips but then downloads. Would think this is the service/__init__.py at error but author seems absent?
    Mar 2024
    What makes you think stabbedbybrick is absent?!
    This looks like a genuine bug in either devine or the iPlayer service. The --skip-dl functionality works for other services.
  4. Originally Posted by SaintyUK View Post
    I posted a fix last week for an ITV fault and it appears to have been ignored.
  5. Originally Posted by SaintyUK View Post
    No not Devine because --skip-dl works on other services. The fact it initially skips and then goes on to download suggests Devine dl is being called more than once by the service __init__
    [Attachment 83624 - Click to enlarge]
    probably a segment thing.
    [Attachment 83625 - Click to enlarge]
    But some titles work as expected. So def. it is a service fault.
    Mar 2024
    I have created a semi-automated guide to install stabbedbybrick's fork of Devine, any dependencies and stabbedbybrick's Devine services!
    It can be found here: https://forum.videohelp.com/threads/416617-Semi-automated-guide-to-install-stabbedbybr...fork-of-Devine
  7. Originally Posted by SaintyUK View Post
    Thank you for making this guide.
  8. When it comes to Devine is it best to set up a free account for Roku? I am having trouble downloading from Ruko. I do have Windscribe now and no limits are on it.
    Dec 2023
    Spain
    Is there a trick to be able to download just the subtitle track in SRT?
    I have SRT set in the config, but I'm getting MKS files from the MY5 service.
    Is it service dependant on them offering SRT subs?
    Dec 2022
    Lesotho
    Are they not automatically muxed?
    Dec 2023
    Spain
    They are, but I need to get just a SRT subs file for one particular show.
    Mar 2024
    This is your friend:
    devine dl -?
    However to answer your question:
    devine dl -S {service} {title}
    Dec 2023
    Spain
    Thanks, getting a subs file isn't the issue. But the subs file is MKS not SRT, despite having that set in the config. Hence asking if there's a trick to it or if certain services will only give MKS files.
    Mar 2024
    Ah sorry, misread your message. I wonder if you'll have to convert them separately afterwards.
    Dec 2022
    Lesotho
    If you open that up in Subtitle Edit, it will actually automatically convert to SRT. Then just save it. I tried copying the sub first, then just renamed the extension to .srt and opened that with SE and compared the two. No difference at all.
    Dec 2023
    Spain
    Ah, so if I just rename a MKS file to be SRT it's job done?
    Dec 2022
    Lesotho
    I think it still wants to be converted but it all depends on what you want to do with the subtitle.
  18. Originally Posted by mkjustuk View Post
    I think the raw VTT file(s) are kept in the tmp folder. Can easily be converted to srt, there are plenty of sites that do that, my favourite is https://subtitletools.com/convert-to-srt-online
  19. EDIT: adding key_vault.db solves the problem.
    Hello, anyone uses devine viki? I use this viki service from here Sp4rky/devine-services - devine-services - The CDM-Project
    it starts with the video licensing then failed. I also tried the
    VIKI 40417c
    C:\Users\AppData\Local\devine>devine dl --lang zh --s-lang en --sub-format srt VIKI https://www.viki.com/tv/40417c-you-are-my-secret
                           / __ \/ ____/ |  / /  _/ | / / ____/
                          / / / / __/  | | / // //  |/ / __/
                         / /_/ / /___  | |/ // // /|  / /___
                        /_____/_____/  |___/___/_/ |_/_____/
                        v3.3.3 Copyright © 2019-2024 rlaphoenix
                          https://github.com/devine-dl/devine
         Service Config loaded
         Loaded Cdm Widevine CDM: 4464 (L3)
         Loaded 1 Vaults
      ────────────────────────────── Service: VIKI ───────────────────────────────
         Service has no Geofence
         Authenticated with Service
      ────────────────── Series: You Are My Secret.2024 (2024) ───────────────────
         1 Season, 33 Episodes
      ────────────────────── You Are My Secret.2024 S01E01 ───────────────────────
         1 Video
         └── [H.264, SDR] | zh | 1920x1080 @ 3386 kb/s, 25.000 FPS
             ⠇ ---------------------------------------- • --:-- • FAILED
         1 Audio
         └── [AAC] | zh-Hans | 2.0 | 200 kb/s
             ⠇ ---------------------------------------- • --:-- • SKIPPED
         1 Subtitle
         └── [VTT] | en | English
         1 Attachment
         └── 1252594v_thumbnail.jpg | image/jpeg | Thumbnail
         ❌ Download Failed...
            Expecting value: line 1 column 1 (char 0)
    C:\Users\AppData\Local\devine>devine dl --lang zh --s-lang en --sub-format srt VIKI https://www.viki.com/tv/40599c-melody-of-golden-age
         Loaded 1 Vaults
      ───────────────── Series: Melody of Golden Age.2024 (2024) ─────────────────
         1 Season, 40 Episodes
      ───────────────────── Melody of Golden Age.2024 S01E01 ─────────────────────
         1 Video
         └── [H.264, SDR] | zh | 1920x1080 @ 3163 kb/s, 25.000 FPS
             ⠸ ---------------------------------------- • --:-- • FAILED
         1 Audio
             ⠸ ---------------------------------------- • --:-- • SKIPPED
         1 Subtitle
         1 Attachment
         └── 1253396v_thumbnail.jpg | image/jpeg | Thumbnail
    And this one I can download just fine. Although this one needed a VPN. I have tried the other titles available in this VPN location and I get same error as first the one.
    C:\Users\AppData\Local\devine>devine dl --lang ko --s-lang en --sub-format srt VIKI https://www.viki.com/tv/36461c-the-fiery-priest?qId=ebbf85b8a6dac9d1194c7ff3483c3455
         Loaded 1 Vaults
      ─────────────────── Series: The Fiery Priest.2019 (2019) ───────────────────
      ─────────────────────── The Fiery Priest.2019 S01E01 ───────────────────────
         1 Video
         └── [H.264, SDR] | ko | 1920x1080 @ 3377 kb/s, 30.000 FPS
             ⠙ ---------------------------------------- • --:-- • Decrypting
         1 Audio
         └── [AAC] | ko | 2.0 | 200 kb/s
         1 Subtitle
             ⠙ ---------------------------------------- • --:-- • CANCELLED
         1 Attachment
         └── 1143941v_thumbnail.jpg | image/jpeg | Thumbnail
         Widevine(AAAAV3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADcIARIQmdz/jRk3SBeXn
         NufTegKjxoLYnV5ZHJta2V5b3MiEJnc/40ZN0gXl5zbn03oCo8qAkhE)
         └── 99dcff8d19374817979cdb9f4de80a8f:38aa749bceac1046021a7d09ea6aa1f3*
             from CDRM-Vault API
         ❌ Download Cancelled...
    Nov 2024
    Planet Earth
    Hi,
    I am trying to access the free Amazon Freevee (with ads) movie "Passengers."
    I am using the Devine service of TPD94.
    However, I am getting the following error.
    Widevine(AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQ3bYmEX5VQhe2K
    vNHvuHbjxoGYW1hem9uIjVjaWQ6em8rSFJYOVVTMjY4b2hhNGdQM0Y4dz09LDNiWW1FWDV
    WUWhlMkt2Tkh2dUhianc9PSoCU0QyAA==)
    └── An exception occurred in the Service's license function:
        'widevine2License'
    Any ideas?
    Am I missing something?
    URL:
    (devine-py3.11) W:\APPLICATIONS_DESKTOP\git_stabbedbybrick_devine_py311poetry>devine dl --list-titles AMZN B01MQVG52J
         Loaded 0 Vaults
         Loaded Hola: 43 Countries
      ────────────────────────────── Service: AMZN ───────────────────────────────
      ──────────────────────── Movies: Passengers (2016) ─────────────────────────
         1 Movie
         └── Passengers (2016)
    (devine-py3.11) W:\APPLICATIONS_DESKTOP\git_stabbedbybrick_devine_py311poetry>devine dl AMZN B01MQVG52J
         Loaded 0 Vaults
         1 Movie
      ──────────────────────────── Passengers (2016) ─────────────────────────────
         1 Video
         └── [H.264, SDR] | en | 960x400 @ 3001 kb/s, 23.976 FPS
             ⠏ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
         1 Audio
         └── [AAC] | en | 2.0 | 192 kb/s
         Widevine(AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQ2ZGCkvs0TmeCl
         QcouITylhoGYW1hem9uIjVjaWQ6MlpHQ2t2czBUbWVDbFFjb3VJVHlsZz09LGVrTWltK1Z
         HUVdhcWxUY1g1RkpnNkE9PSoCU0QyAA==)
             'widevine2License'
             'widevine2License'
            An unexpected error occurred in one of the download workers.
            See the error trace above for more information.
    Nothing useful:
    (devine-py3.11) W:\APPLICATIONS_DESKTOP\git_stabbedbybrick_devine_ py311poetry>devine -d dl AMZN B01MQVG52J
    My devine.yaml looks like this.
    C:\Users\AnonymousUser>type %LOCALAPPDATA%\devine\devine.yaml
    directories:
      services: W:\APPLICATIONS_DESKTOP\symbolic_links_devine-services\
    cdm:
      default: ANDROID_4464_l3
    downloader: n_m3u8dl_re
    n_m3u8dl_re:
      use_proxy: false
    dl:
      workers: 16
      sub_format: srt
    Thanks,
    SummerArk
  21. Hi. I've just installed devine using the instruction on stabbedbybrick's githib page (pip install devine). I then installed stabby's Services using the instructions given by SaintyUK i.e. I ran the command "git clone https://cdm-project.com/stabbedbybrick/devine-services.git". In my main devine folder I made a file called devine.yaml which specifies the services path and details my All4 credentials. The devine folder contains all the dependencies, my wvd folder and the devine-services folder. Unfortunately, I'm not up and running - can anyone suggest why devine can't see my Services? Many thanks.
  22. This morning freevine stopped working for iPlayer, so I thought I'd try to setup and use Devine. When I try to search I get a geoblocked error and 404 not found and when I try adding the without a proxy tag I just get the 404 not found. Which configuration do I have incorrect? Do I need to provide my iPlayer username and password anywhere?
    I just downloaded the services from stabbedbybrick and didn't modify anything.
    Freevine Error
    [Attachment 83733 - Click to enlarge]
    devine search iP "Top Gear"
    [Attachment 83734 - Click to enlarge]
    devine search --no-proxy iP "Top Gear"
    [Attachment 83735 - Click to enlarge]
  23. Originally Posted by pooksahib View Post
    Had this problem at first too. The service name from stabbedbybricks is ALL4 (all upper-case). Try that instead of lowercase like your screenshot.
  24. Originally Posted by stabbedbybrick View Post
    Originally Posted by pssh View Post
    Is there any way to download multiple audio tracks with "Devine"?
    If not, anyone got any "hacks" how to do so?
    I have tried:
    devine dl -q 360 -a DD,AAC -w s02e01 --no-folder CTV /shows/227
    devine dl -q 360 -a DD+AAC -w s02e01 --no-folder CTV /shows/227
    devine dl -q 360 -a DD|AAC -w s02e01 --no-folder CTV /shows/227
    devine dl -q 360 -a DD -AAC -w s02e01 --no-folder CTV /shows/227
    But without result.
    Looking at the code
    https://cdm-project.com/TPD94/devine/src/branch/master/devine/commands/dl.py
    video has the option to download multiple resolutions(s), but no such a thing for Audio
    There's no default feature for this as far as I know. You'd have to add it to the service code yourself.
    @stabbedbybrick:
    With your addition of "N_m3u8DL-RE" as a downloader to Devine,
    is it now possible to download "multiple" audio tracks?
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
  25. Originally Posted by crusr4 View Post
    Hi crusr4. You had me thinking 'can it be that simple?!' But my hopes were dashed. Assistance still required then so, to recap: I've installed devine using "pip install devine". I've installed stabby's Services using "git clone https://cdm-project.com/stabbedbybrick/devine-services.git". In my main devine folder is devine.yaml with my All4 credentials. The devine folder contains all the dependencies, my wvd folder and the devine-services folder. Can anyone suggest why devine can't see my Services? Many thanks.
  26. Execute this command: "devine env info". You should be able to figure it out from there.
  27. Thanks, achilles, but I'm pleased (with myself!) to say that's exactly what I did after a little bit of research. I installed devine by opening the CMD within a D drive folder and so assumed that all dependencies etc should be there, never thinking that the yaml and wvd had to go deep inside C/appdata. Sadly, I still have an issue: whether my VPN is on or off I get this (see pic). Does anyone have an explanation/fix? Many thanks.
  28. I finally registered for the Roku Channel. I did the cookie thing and put my credentials in the YAML. I am still having the same problem by not being able to download episodes from ROKU. Thank you in advance for any help you can give me in this matter:
    C:\devine>devine dl -q 486 -w S01E28 ROKU https://therokuchannel.roku.com/details/bde37c3449765d779b5aaea52d726b36/ironside
                        v3.3.1 Copyright © 2019-2024 rlaphoenix
         Loaded 1 Vaults
      ────────────────────────────── Service: ROKU ───────────────────────────────
         Service is not Geoblocked in your region
      ───────────────────────── Series: Ironside (1967) ──────────────────────────
         8 Seasons, 199 Episodes
      ──────────────────── Ironside S01E28 Return of the Hero ────────────────────
    ╭───────────────────── Traceback (most recent call last) ──────────────────────╮
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\site-packages\url │
    │ lib3\connectionpool.py:467 in _make_request                                  │
    │    464 │   │   try:                                                          │
    │    465 │   │   │   # Trigger any extra validation we need to do.             │
    │    466 │   │   │   try:                                                      │
    │ ❱  467 │   │   │   │   self._validate_conn(conn)                             │
    │    468 │   │   │   except (SocketTimeout, BaseSSLError) as e:                │
    │    469 │   │   │   │   self._raise_timeout(err=e, url=url, timeout_value=con │
    │    470 │   │   │   │   raise                                                 │
    │ lib3\connectionpool.py:1099 in _validate_conn                                │
    │   1096 │   │        │
    │   1097 │   │   # Force connect early to allow us to validate the connection. │
    │   1098 │   │   if conn.is_closed:                                            │
    │ ❱ 1099 │   │   │   conn.connect()                                            │
    │   1100 │   │        │
    │   1101 │   │   # TODO revise this, see https://github.com/urllib3/urllib3/is │
    │   1102 │   │   if not conn.is_verified and not conn.proxy_is_verified:       │
    │ lib3\connection.py:653 in connect                                            │
    │   650 │   │   # Remove trailing '.' from fqdn hostnames to allow certificate │
    │   651 │   │   server_hostname_rm_dot = server_hostname.rstrip(".")           │
    │   652 │   │        │
    │ ❱ 653 │   │   sock_and_verified = _ssl_wrap_socket_and_match_hostname(       │
    │   654 │   │   │   sock=sock,                                                 │
    │   655 │   │   │   cert_reqs=self.cert_reqs,                                  │
    │   656 │   │   │   ssl_version=self.ssl_version,                              │
    │ lib3\connection.py:806 in _ssl_wrap_socket_and_match_hostname                │
    │   803 │   │   if is_ipaddress(normalized):                                   │
    │   804 │   │   │   server_hostname = normalized                               │
    │   805 │        │
    │ ❱ 806 │   ssl_sock = ssl_wrap_socket(                                        │
    │   807 │   │   sock=sock,                                                     │
    │   808 │   │   keyfile=key_file,                                              │
    │   809 │   │   certfile=cert_file,                                            │
    │ lib3\util\ssl_.py:465 in ssl_wrap_socket                                     │
    │   462 │   except NotImplementedError:  # Defensive: in CI, we always have se │
    │   463 │   │   pass                                                           │
    │   464 │        │
    │ ❱ 465 │   ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls, server │
    │   466 │   return ssl_sock                                                    │
    │   467        │
    │   468        │
    │ lib3\util\ssl_.py:509 in _ssl_wrap_socket_impl                               │
    │   506 │   │   SSLTransport._validate_ssl_context_for_tls_in_tls(ssl_context) │
    │   507 │   │   return SSLTransport(sock, ssl_context, server_hostname)        │
    │   508 │        │
    │ ❱ 509 │   return ssl_context.wrap_socket(sock, server_hostname=server_hostna │
    │   510        │
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\ssl.py:517 in     │
    │ wrap_socket        │
    │    514 │   │   │   │   │   server_hostname=None, session=None):              │
    │    515 │   │   # SSLSocket class handles server_hostname encoding before it  │
    │    516 │   │   # ctx._wrap_socket()                                          │
    │ ❱  517 │   │   return self.sslsocket_class._create(                          │
    │    518 │   │   │   sock=sock,                                                │
    │    519 │   │   │   server_side=server_side,                                  │
    │    520 │   │   │   do_handshake_on_connect=do_handshake_on_connect,          │
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\ssl.py:1108 in    │
    │ _create        │
    │   1105 │   │   │   │   │   if timeout == 0.0:                                │
    │   1106 │   │   │   │   │   │   # non-blocking                                │
    │   1107 │   │   │   │   │   │   raise ValueError("do_handshake_on_connect sho │
    │ ❱ 1108 │   │   │   │   │   self.do_handshake()                               │
    │   1109 │   │   │   except (OSError, ValueError):                             │
    │   1110 │   │   │   │   self.close()                                          │
    │   1111 │   │   │   │   raise                                                 │
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\ssl.py:1379 in    │
    │ do_handshake        │
    │   1376 │   │   try:                                                          │
    │   1377 │   │   │   if timeout == 0.0 and block:                              │
    │   1378 │   │   │   │   self.settimeout(None)                                 │
    │ ❱ 1379 │   │   │   self._sslobj.do_handshake()                               │
    │   1380 │   │   finally:                                                      │
    │   1381 │   │   │   self.settimeout(timeout)                                  │
    │   1382        │
    SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1006)
    During handling of the above exception, another exception occurred:
    │ lib3\connectionpool.py:793 in urlopen                                        │
    │    790 │   │   │   response_conn = conn if not release_conn else None        │
    │    791 │   │   │                                                             │
    │    792 │   │   │   # Make the request on the HTTPConnection object           │
    │ ❱  793 │   │   │   response = self._make_request(                            │
    │    794 │   │   │   │   conn,                                                 │
    │    795 │   │   │   │   method,                                               │
    │    796 │   │   │   │   url,                                                  │
    │ lib3\connectionpool.py:491 in _make_request                                  │
    │    488 │   │   │   │   new_e, (OSError, NewConnectionError, TimeoutError, SS │
    │    489 │   │   │   ) and (conn and conn.proxy and not conn.has_connected_to_ │
    │    490 │   │   │   │   new_e = _wrap_proxy_error(new_e, conn.proxy.scheme)   │
    │ ❱  491 │   │   │   raise new_e                                               │
    │    492 │   │        │
    │    493 │   │   # conn.request() calls http.client.*.request, not the method  │
    │    494 │   │   # urllib3.request. It also calls makefile (recv) on the socke │
    The above exception was the direct cause of the following exception:
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\site-packages\req │
    │ uests\adapters.py:486 in send                                                │
    │   483 │   │   │   timeout = TimeoutSauce(connect=timeout, read=timeout)      │
    │   484 │   │        │
    │   485 │   │   try:                                                           │
    │ ❱ 486 │   │   │   resp = conn.urlopen(                                       │
    │   487 │   │   │   │   method=request.method,                                 │
    │   488 │   │   │   │   url=url,                                               │
    │   489 │   │   │   │   body=request.body,                                     │
    │ lib3\connectionpool.py:847 in urlopen                                        │
    │    844 │   │   │   elif isinstance(new_e, (OSError, HTTPException)):         │
    │    845 │   │   │   │   new_e = ProtocolError("Connection aborted.", new_e)   │
    │    846 │   │   │                                                             │
    │ ❱  847 │   │   │   retries = retries.increment(                              │
    │    848 │   │   │   │   method, url, error=new_e, _pool=self, _stacktrace=sys │
    │    849 │   │   │   )                                                         │
    │    850 │   │   │   retries.sleep()                                           │
    │ lib3\util\retry.py:515 in increment                                          │
    │   512 │   │        │
    │   513 │   │   if new_retry.is_exhausted():                                   │
    │   514 │   │   │   reason = error or ResponseError(cause)                     │
    │ ❱ 515 │   │   │   raise MaxRetryError(_pool, url, reason) from reason  # typ │
    │   516 │   │        │
    │   517 │   │   log.debug("Incremented Retry for (url='%s'): %r", url, new_ret │
    │   518        │
    MaxRetryError: HTTPSConnectionPool(host='vod.delivery.roku.com', port=443): Max
    retries exceeded with url:
    /244b9b96ae0248c093dafd9cf0d8c2a7/b5558de986f747e980a21f48353ee232/450a776494b34
    a17936e4ca497d297e5/index.mpd (Caused by SSLError(SSLError(1, '[SSL:
    WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1006)')))
    │ in _run_module_as_main:198                                                   │
    │ in _run_code:88                                                              │
    │ in <module>:7        │
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\site-packages\cli │
    │ ck\core.py:1157 in __call__                                                  │
    │ ck\core.py:1078 in main                                                      │
    │ ck\core.py:1688 in invoke                                                    │
    │ ck\core.py:1657 in _process_result                                           │
    │ ck\core.py:783 in invoke                                                     │
    │ C:\Users\sheld\AppData\Local\Programs\Python\Python311\Lib\site-packages\dev │
    │ ine\commands\dl.py:340 in result                                             │
    │   337 │   │   │   │   events.subscribe(events.Types.TRACK_MULTIPLEX, service │
    │   338 │   │   │                                                              │
    │   339 │   │   │   with console.status("Getting tracks...", spinner="dots"):  │
    │ ❱ 340 │   │   │   │   title.tracks.add(service.get_tracks(title), warn_only= │
    │   341 │   │   │   │   title.tracks.chapters = service.get_chapters(title)    │
    │   342 │   │   │                                                              │
    │   343 │   │   │   # strip SDH subs to non-SDH if no equivalent same-lang non │
    │ C:\Users\sheld\git\stabbedbybrick-333\devine-services\services\ROKU\__init__ │
    │ .py:188 in get_tracks                                                        │
    │   185 │   │   if url and "origin" in urlparse(url).query:                    │
    │   186 │   │   │   url = unquote(urlparse(url).query.split("=")[1]).split("?" │
    │   187 │   │        │
    │ ❱ 188 │   │   tracks = DASH.from_url(url=url).to_tracks(language=title.langu │
    │   189 │   │   tracks.videos[0].data["playbackMedia"] = r.json()["playbackMed │
    │   190 │   │        │
    │   191 │   │   for track in tracks.audio:                                     │
    │ ine\core\manifests\dash.py:60 in from_url                                    │
    │    57 │   │   elif not isinstance(session, Session):                         │
    │    58 │   │   │   raise TypeError(f"Expected session to be a {Session}, not  │
    │    59 │   │        │
    │ ❱  60 │   │   res = session.get(url, **args)                                 │
    │    61 │   │   if res.url != url:                                             │
    │    62 │   │   │   url = res.url                                              │
    │    63        │
    │ uests\sessions.py:602 in get                                                 │
    │   599 │   │   """                                                            │
    │   600 │   │        │
    │   601 │   │   kwargs.setdefault("allow_redirects", True)                     │
    │ ❱ 602 │   │   return self.request("GET", url, **kwargs)                      │
    │   603 │        │
    │   604 │   def options(self, url, **kwargs):                                  │
    │   605 │   │   r"""Sends a OPTIONS request. Returns :class:`Response` object. │
    │ uests\sessions.py:589 in request                                             │
    │   586 │   │   │   "allow_redirects": allow_redirects,                        │
    │   587 │   │   }                                                              │
    │   588 │   │   send_kwargs.update(settings)                                   │
    │ ❱ 589 │   │   resp = self.send(prep, **send_kwargs)                          │
    │   590 │   │        │
    │   591 │   │   return resp                                                    │
    │   592        │
    │ uests\sessions.py:703 in send                                                │
    │   700 │   │   start = preferred_clock()                                      │
    │   701 │   │        │
    │   702 │   │   # Send the request                                             │
    │ ❱ 703 │   │   r = adapter.send(request, **kwargs)                            │
    │   704 │   │        │
    │   705 │   │   # Total elapsed time of the request (approximately)            │
    │   706 │   │   elapsed = preferred_clock() - start                            │
    │ uests\adapters.py:517 in send                                                │
    │   514 │   │   │                                                              │
    │   515 │   │   │   if isinstance(e.reason, _SSLError):                        │
    │   516 │   │   │   │   # This branch is for urllib3 v1.22 and later.          │
    │ ❱ 517 │   │   │   │   raise SSLError(e, request=request)                     │
    │   518 │   │   │                                                              │
    │   519 │   │   │   raise ConnectionError(e, request=request)                  │
    │   520        │
    SSLError: HTTPSConnectionPool(host='vod.delivery.roku.com', port=443): Max
    C:\devine>
    I have Windscribe now as my VPN if this is a VPN issue please give me guidance on how to configure Windscribe. I have this SSL error with Freevine as well and Roku has always been the toughest service. I used to have success with the free Windscribe VPN until just lately though.
  29. Good morning all. I ran "devine dl iP https://www.bbc.co.uk/iplayer/episode/p0f259mn/colin-from-accounts-series-1-1-the-flash". A lot of text appeared in a box headed 'Traceback (most recent call last)' and after the box was KeyError: 'n_m3u8dl_re' then back to the CMD startpoint. I do have N_m3u8DL-RE in my working folder and that folder is in Path. I tried changing N_m3u8DL-RE to n_m3u8dl-re but the result was the same. Also, the devine.yaml file in appdata includes "downloader: n_m3u8dl_re". Can anyone suggest cause and cure of this KeyError? Many thanks.
  30. Originally Posted by pooksahib View Post
    two suggestions:
    1) remove downloader: n_m3u8dl_re from your devine.yaml and try again or
    2) replace downloader: n_m3u8dl_re with downloader: aria2c
    hope that helps.
