Page 25 of 62
FirstFirst ... 15 23 24 25 26 27 35 ... LastLast
Results 721 to 750 of 1832
  1. A heads up when it comes to Baywatch on TubiTV you will find that season 7 episode 1 is an episode from an previous season. It was suppose to be "Shark Fever" but they have "If Looks Could Kill" instead. It turns out that Roku made the same exact error. So it is not the fault of Devine it is just a mistake on both the TubiTV and Roku websites.
  2. Thanks Tom Saurus, it wasn't on my radar, but it does raise the question as to whether a universal thread for platform errors would be worthwhile?
  3. Hi,
    Not sure what I've done but now getting the following:
    Service is not Geoblocked in your region
    + Using cached Tokens...
    Authenticated with Service
    {"code": 401, "message": "Token not valid"}
    Any ideas? thanks.
  4. Originally Posted by PunchDrunkL0ve View Post
    Hi,
    Any ideas? thanks.
    If this is C4, try the cache clear code posted in #129?
  5. Originally Posted by F1sav28 View Post
    Hi,
    Any ideas? thanks.
    It worked, many thanks.
    devine env clear cache ALL4
  6. Next issue:
    Using the default downloader to grab an episode that's already been licensed but the process bar doesn't move at all and the download never completes, although some segments are been written in the TMP folder. Aria2c gives me the same behaviour. Any suggestions? Thanks.
    1 Video
    └── [H.264, SDR] | en | 1920x1080 @ 4998 kb/s, 25.000 FPS
    ⠋ ---------------------------------------- • --:-- • LICENSED
    1 Audio
    └── [AAC] | en | 2.0 | 133 kb/s
    2 Subtitles
    ├── [VTT] | en
    └── [VTT] | en | SDH
    5 Chapters
    ├── 00:00:00.000 | Chapter 01
    ├── 00:12:08.800 | Chapter 02
    ├── 00:23:31.600 | Chapter 03
    ├── 00:37:38.960 | Chapter 04
    └── 00:46:23.840 | Credits
  7. And this:
    ERROR: Unknown command line flag
    'enable_raw_key_decryption' ERROR: Unknown command line
    flag 'keys'. Did you mean: v ? ERROR: Unknown command line
    flag 'temp_dir'
    Cached 1 Key to 0/0 Vaults
    thanks.
  8. What's the link? I've just tested a C4 video at -q 720 as a test and it worked for me.
  9. Hi everyone,
    I hope this is the right place to post this question. I have setup devine (v.3.3.3), wvd, configured the yaml etc. I am using the TPD94 services because it has CR.
    I issue the following command:
    devine --debug dl CR GYZJ43JMR
    After the correct auth, it starts crawling but at a certain point fails with:
         1 Video
         └── [H.264, SDR] | en-US | 1920x1080 @ 7957 kb/s, 23.974 FPS
             ⠋ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
         1 Audio
         └── [AAC] | en-US | 1.0 | 128 kb/s | United States
             ⠋ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
         2 Subtitles
         ├── [VTT] | en-US | United States
         │   ⠋ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
         └── [ASS] | it-IT
         2 Chapters
         ├── 00:00:00.000
         └── 00:22:05.000 | Credits
         ❌ Download Failed...
            An unexpected error occurred in one of the download workers.
            See the error trace above for more information.
    Can someone help me troubleshoot?
    Thank you for your time
  10. Originally Posted by F1sav28 View Post
    https://www.channel4.com/programmes/first-dates/on-demand/75512-017
  11. Works fine here.
  12. Originally Posted by SB47x View Post
    Works fine here.
    OK thanks for checking, must be my set-up then?
    Is my error related to the Shaka Packager?
  13. Looks like it's failing at the decryption stage, so potentially it's an issue with shaka-packager. Can you run shaka-packager? What version are you using? I'm running:
    # shaka-packager --version
    packager version v3.0.4-ceeb378-release
  14. Originally Posted by SB47x View Post
    mine says:
    mpd_generator version v3.2.0-53b8668-release
    Have I d/led the wrong one? smh
  15. Originally Posted by PunchDrunkL0ve View Post
    mine says:
    Yes, you've downloaded the "mpd_generator". You want the one called "packager" from here: https://github.com/shaka-project/shaka-packager/releases
    Pick the one suitable for your system.
  16. Originally Posted by stabbedbybrick View Post
    mine says:
    Didn't realise there were two versions LOL. D/led the packager renamed it shaka-packager and everything works as expected now YAY!
    Thanks everyone for your very helpful suggestions, much appreciated.
  17. OK three quick questions:
    a. How do I queue downloads?
    b. How can I prevent the script from adding a title header (with ie the Series name and episode number) in the mkv container? It can be easily removed afterwards with mkvpropedit but if I didn't want to have it there in the first place, which part in the dl.py(?) would I have to edit?
    c. If while downloading a series the server drops the connection, is there a way to resume and not re-download everything from the top?
    Thanks.
  18. Originally Posted by PunchDrunkL0ve View Post
    Thanks.
    a: Depends what you mean by queue. It defaults to downloading all available episodes from a show if nothing else is specified. To download a season, you use '-w S01'. To download an episode, you use '-w S01E01' or by using the episode URL (if the service supports it). Unless the service you're using has specifically added this functionality, you can't que multiple shows or movies.
    b: You can edit 'devine/core/titles/episode.py' to change the filename format. Just make sure you know what you're doing, or the script will most likely fail.
    c: Don't think so, but can't you just pick it up where it failed by starting with the failed episode? Seems like the easiest solution.
  19. Originally Posted by stabbedbybrick View Post
    Thanks.
    a) Thanks will try that. Do you think it would be possible to add a simple queuing system to your services? Ie allow to queue episodes using '-w s01e01,s01e02,s01e04' -w S01,S02 or something similar?
    b) The filename format is perfect In the mkv headers I'm seeing a title and movie name added during muxing. Only wanted to know where that code is in the script(s).
    Title                                    : Celebrity Masterchef S19E01
    Movie name                               : Celebrity Masterchef S19E01
    c) agreed.
  20. Originally Posted by PunchDrunkL0ve View Post
    c) agreed.
    a: This is already possible. See 'devine dl -?' for commands and how to use them.
    b: Ah, my bad. You can find the muxing process in 'devine/core/tracks/tracks.py'.
  21. Originally Posted by stabbedbybrick View Post
    c) agreed.
    a) great, got it.
    b) Ta
  22. Member
    Dec 2022
    Lesotho
    Ah so this is where I must look to fix an audio track problem. If I choose
    -l all
    the resultant file has the audio track with the bigger bitrate set to the 2nd track. I have to then reorder in post using mkvtoolnix.
    There is this snippet of code that may need altering but I don't fully understand it.
    for language in reversed(by_language or []):
                if str(language) == "all":
  23. Originally Posted by sipho View Post
    -l all
    Until you figure that out, you could use mkvpropedit to change the headers:
    to reorder the audio tracks (assuming track 1 is the video)
    mkvpropedit <your_mkv_file> --edit track:2 --set track-number=3 --edit track:3 --set track-number=2
    and then to change default audio track
    mkvpropedit <your_mkv_file> --edit track:a1 --set flag-default=1 --edit track:a2 --set flag-default=0
    Hope that helps.
  24. Member
    Dec 2022
    Lesotho
    Thanks @PunchDrunkL0ve
  25. Member
    Oct 2023
    Afghanistan
    If you want to download a whole bunch of different stuff you can always just add your commands to a batch file, say queue.bat and run it when you're ready eg:
    devine dl --list-titles my5  https://www.channel5.com/show/the-hotel-inspector
    devine dl -w S18E01 my5  https://www.channel5.com/show/the-hotel-inspector
    devine dl -w S18E05 --subs-only my5  https://www.channel5.com/show/the-hotel-inspector
  26. Originally Posted by billybanana View Post
    Thanks for the suggestion. I often do
    command1 && command2 && command3
    if I want to run a quick queue but creating a .bat file sounds good
  27. Hi People,
    Trying to download a movie from tubi (us) site,... But I am running into a few problems.
    My devine services are all uptodate.
    my first call was the following (granted this is most likely wrong, I leave things for a few weeks and it gets lost in the fog).
    just trying to get a response from tubi.
    C:\Devine>devine dl --list-titles TUBI https://tubitv.com/movies/310136/hotel-rwanda
    but i received the following error:
    [Attachment 81887 - Click to enlarge]
    Also tried using vpn connected to u.s. with the same error.
    really sorry people, a fatal mistake on my part,.... I thought that the cookies would self populate,... (They were in the cookies folder with todays date).
    I had to get them again with "open cookies txt".
    resaved them as TUBI.txt and now the call devine dl TUBI (address to movie) is downloading although incredibly slowly.
    also The first search call now works. (but I don't know if it's because i'm connected through a vpn for the whole length of the download because I can see that the call is still using hola.
    I can vaguely remember stabby saying something about only the call has to go through a proxy then the rest of the download a vpn is not required.
  28. Originally Posted by LastResort View Post
    Unless you log in and out on a regular basis, Tubi cookies will last a long time. I'm still using the same cookies as when I first made the script, which is like ~4 months ago.
    Hola is also generally terrible for speed, so it's not really advised to use it. Any proxy used in Devine will be applied for both API calls and download. This was not the case with Freevine, which is probably what you're remembering me talking about.
  29. Hi Stabby,,
    Yes it may well have been freevine. Oh wow, using hola to download would take forever,... assuming the link stayed connected. I was about to ask how I can turn off hola and then the light bulb came on. devine.yaml.... damn I was wrong.
    So this would download using hola :devine dl -V -A --list itv https://www.itv.com
    and i'm guessing that devine dl --no-proxy -V -A --list itv https://www.itv.com would cancel the proxy from being used.
    I had a read through devine/CONFIG.md and I can see that the settings for a vpn has to be set For example,
    username: zxqsR7C5CyGwmGb6KSvk8qsZ # example of the login format
    password: wXVHmht22hhRKUEQ32PQVjCZ
    I'm probably wrong but i thought that this info would need to be placed into devine.yaml,... What I cannot work out is why does hola kick in even when your looking for something in your own country. (and I think I know what the problem with tubi is.... I have never registered with them). Maybe that's why the cookies are not being kept, and I keep reloading the site and just grabbing the cookies for that moment in time.
  30. Member
    Mar 2024
    Learn something new everyday! I really didn't realise this. It was\is such as great feature to just use a proxy for the license part!
    I really hope that can be implemented in devine in the future
    Edit: just found https://github.com/devine-dl/devine/issues/29
