Starting a new Devine discussion to keep it out of stabby's Freevine thread.
https://github.com/devine-dl/devine
Discuss away![]()
Results 1 to 30 of 1872
I'm getting an error on all Channel 4 downloads. I can't figure out what file is can't find.
Code:D:\Downloads\Devine>devine dl -w S01E01 ALL4 helsinki-crimes / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.1 Copyright © 2019-2024 rlaphoenix https://github.com/devine-dl/devine Service Config loaded Loaded Cdm Widevine CDM: 4464 (L3) Loaded 1 Vaults ────────────────────────────── Service: ALL4 ─────────────────────────────── Service is Geoblocked in your region, getting a Proxy to gb + Using cached Tokens... Authenticated with Service ───────────────────────── Series: Helsinki Crimes ────────────────────────── 1 Season, 8 Episodes ────────────────────────── Helsinki Crimes S01E01 ────────────────────────── Requesting ANDROID assets... Requesting WEB assets... 1 Video └── [H.264, SDR] | en | 1920x1080 @ 5019 kb/s, 25.000 FPS ⠼ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ --:-- - 1 Audio └── [AAC] | 2.0 | 133 kb/s | en ⠼ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ --:-- - 2 Subtitles ├── [VTT] | en │ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:03 Downloaded └── [VTT] | en | SDH ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:05 Downloaded 5 Chapters ├── 00:00:00.000 | Chapter 01 ├── 00:08:55.480 | Chapter 02 ├── 00:17:39.040 | Chapter 03 ├── 00:27:13.480 | Chapter 04 └── 00:37:41.160 | Credits ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ C:\Python312\Lib\site-packages\devine\commands\dl.py:539 in result │ │ │ │ 536 │ │ │ │ │ │ │ ) │ │ 537 │ │ │ │ │ │ │ for i, track in enumerate(title.tracks) │ │ 538 │ │ │ │ │ │ )): │ │ ❱ 539 │ │ │ │ │ │ │ download.result() │ │ 540 │ │ │ except KeyboardInterrupt: │ │ 541 │ │ │ │ console.print(Padding( │ │ 542 │ │ │ │ │ ":x: Download Cancelled...", │ │ │ │ C:\Python312\Lib\concurrent\futures\_base.py:449 in result │ │ │ │ 446 │ │ │ │ if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]: │ │ 447 │ │ │ │ │ raise CancelledError() │ │ 448 │ │ │ │ elif self._state == FINISHED: │ │ ❱ 449 │ │ │ │ │ return self.__get_result() │ │ 450 │ │ │ │ │ │ 451 │ │ │ │ self._condition.wait(timeout) │ │ 452 │ │ │ │ C:\Python312\Lib\concurrent\futures\_base.py:401 in __get_result │ │ │ │ 398 │ def __get_result(self): │ │ 399 │ │ if self._exception: │ │ 400 │ │ │ try: │ │ ❱ 401 │ │ │ │ raise self._exception │ │ 402 │ │ │ finally: │ │ 403 │ │ │ │ # Break a reference cycle with the exception in self._ │ │ 404 │ │ │ │ self = None │ │ │ │ C:\Python312\Lib\concurrent\futures\thread.py:58 in run │ │ │ │ 55 │ │ │ return │ │ 56 │ │ │ │ 57 │ │ try: │ │ ❱ 58 │ │ │ result = self.fn(*self.args, **self.kwargs) │ │ 59 │ │ except BaseException as exc: │ │ 60 │ │ │ self.future.set_exception(exc) │ │ 61 │ │ │ # Break a reference cycle with the exception 'exc' │ │ │ │ C:\Python312\Lib\site-packages\devine\core\tracks\track.py:199 in download │ │ │ │ 196 │ │ │ │ │ license_widevine=prepare_drm │ │ 197 │ │ │ │ ) │ │ 198 │ │ │ elif self.descriptor == self.Descriptor.DASH: │ │ ❱ 199 │ │ │ │ DASH.download_track( │ │ 200 │ │ │ │ │ track=self, │ │ 201 │ │ │ │ │ save_path=save_path, │ │ 202 │ │ │ │ │ save_dir=save_dir, │ │ │ │ C:\Python312\Lib\site-packages\devine\core\manifests\dash.py:404 in │ │ download_track │ │ │ │ 401 │ │ │ │ res = session.get(url=rep_base_url, headers=init_range │ │ 402 │ │ │ │ res.raise_for_status() │ │ 403 │ │ │ │ init_data = res.content │ │ ❱ 404 │ │ │ │ track_kid = track.get_key_id(init_data) │ │ 405 │ │ │ │ total_size = res.headers.get("Content-Range", "").spli │ │ 406 │ │ │ │ if total_size: │ │ 407 │ │ │ │ │ media_range = f"{len(init_data)}-{total_size}" │ │ │ │ C:\Python312\Lib\site-packages\devine\core\tracks\track.py:364 in get_key_id │ │ │ │ 361 │ │ if not isinstance(init_data, bytes): │ │ 362 │ │ │ raise TypeError(f"Expected init_data to be bytes, not {ini │ │ 363 │ │ │ │ ❱ 364 │ │ probe = ffprobe(init_data) │ │ 365 │ │ if probe: │ │ 366 │ │ │ for stream in probe.get("streams") or []: │ │ 367 │ │ │ │ enc_key_id = stream.get("tags", {}).get("enc_key_id") │ │ │ │ C:\Python312\Lib\site-packages\devine\core\utils\subprocess.py:23 in ffprobe │ │ │ │ 20 │ elif isinstance(uri, bytes): │ │ 21 │ │ args.append("pipe:") │ │ 22 │ try: │ │ ❱ 23 │ │ ff = subprocess.run( │ │ 24 │ │ │ args, │ │ 25 │ │ │ input=uri if isinstance(uri, bytes) else None, │ │ 26 │ │ │ check=True, │ │ │ │ C:\Python312\Lib\subprocess.py:548 in run │ │ │ │ 545 │ │ kwargs['stdout'] = PIPE │ │ 546 │ │ kwargs['stderr'] = PIPE │ │ 547 │ │ │ ❱ 548 │ with Popen(*popenargs, **kwargs) as process: │ │ 549 │ │ try: │ │ 550 │ │ │ stdout, stderr = process.communicate(input, timeout=timeo │ │ 551 │ │ except TimeoutExpired as exc: │ │ │ │ C:\Python312\Lib\subprocess.py:1026 in __init__ │ │ │ │ 1023 │ │ │ │ │ self.stderr = io.TextIOWrapper(self.stderr, │ │ 1024 │ │ │ │ │ │ │ encoding=encoding, errors=errors) │ │ 1025 │ │ │ │ │ ❱ 1026 │ │ │ self._execute_child(args, executable, preexec_fn, close_f │ │ 1027 │ │ │ │ │ │ │ │ pass_fds, cwd, env, │ │ 1028 │ │ │ │ │ │ │ │ startupinfo, creationflags, shell, │ │ 1029 │ │ │ │ │ │ │ │ p2cread, p2cwrite, │ │ │ │ C:\Python312\Lib\subprocess.py:1538 in _execute_child │ │ │ │ 1535 │ │ │ │ │ 1536 │ │ │ # Start the process │ │ 1537 │ │ │ try: │ │ ❱ 1538 │ │ │ │ hp, ht, pid, tid = _winapi.CreateProcess(executable, │ │ 1539 │ │ │ │ │ │ │ │ │ │ # no special security │ │ 1540 │ │ │ │ │ │ │ │ │ │ None, None, │ │ 1541 │ │ │ │ │ │ │ │ │ │ int(not close_fds), │ ╰──────────────────────────────────────────────────────────────────────────────╯ FileNotFoundError: [WinError 2] The system cannot find the file specified ❌ Download Failed... One of the track downloads had an error! See the error trace above for more information. -
Billy, May I ask how you managed to get your installation to see your service config please...
I'm on windows 10, pip installed Devine.
Created a folder on my C drive simply called Devine.
images of installed files:
[Attachment 78261 - Click to enlarge]
[Attachment 78262 - Click to enlarge]
[Attachment 78263 - Click to enlarge]
I remember (i think it was iamghost) mention about the weird / \ change of these when using windows. so the Devine.yaml is using the reverse /.
upon running an elevated cmd prompt: and using devine env info i get the following:
[Attachment 78264 - Click to enlarge]
So I moved the folders cookies, WVD's cache, logs, to the AppData Local devine folder, Hoping this would achieve my goal. And correct this error:
(this is a test to search)
[Attachment 78265 - Click to enlarge]
Due to the "no service added" obviously something is not being seen.
And it seems that devine.yaml is being read from the appdata\local\devine\ folder. (which it shouldn't be doing.)
So my next attempt was to move my devine.yaml to appdata\local\devine\ folder to see what would happen. that's when things didn't really get exciting.
devine env info gives the following:
[Attachment 78266 - Click to enlarge]
I'm really hoping there's going to be a simple explanation because I've got a banging headache.... lol -
Devine.yaml needs to be in appdata devine in my case i need to edit it with Notepad ++
Everytime i make a change I keep a copy there also as its funny with the indents
Services: are in this folder
C:\Scripts\devinenv\Lib\site-packages\devine\services
[Attachment 78268 - Click to enlarge]
All the other folders like cookies Wds are there also works for meLast edited by PSXman_uk; 20th Apr 2024 at 02:20.
[Attachment 78269 - Click to enlarge]
billy are all your bin files in path ? works for me with your command -
I don't believe so and this is where the documentation/help file is about as clear as mud. I've got the below files in my D:\Downloads\Devine directory:
aria2c.exe
ccextractor.exe
ffmpeg.exe
mkvmerge.exe
packager-win-x64.exe
but given the majority of the links for those files on git are not just the executables, I'm not really sure what files are required and where to put them. I'm sure I won't be alone in this, so if you can confirm what your set up is, I should be able to resolve the problem. -
Not all is needed for Devine but i keep it all in one place
The rest is all in the environment that I setup from the start -
For future reference, if you look at this error output, you will see that the traceback starts in subprocess.py within the python library itself so that's unlikely to be causing the problem. This is the most recent call and going up the chain you can see that the first error that occurs within the devine code is at a different subprocess.py.
It stopped in a module called ffprobe which is a dead giveaway for what you are missing. And if you look in that part of the devine code, it says "Use ffprobe on the provided data to get stream information." so that's obviously where it's have the problem.Code:C:\Python312\Lib\site-packages\devine\core\utils\subprocess.py:23 in ffprobe
stabbedbybrick mentioned this but I am posting this so next time, the error output might be more readable to help figure out what the issue is.
BTW, it's not a bad idea to be running devine in a virtual environment. It looks like you installed devine into your global python library. -
This is where devine.yaml is read from. It doesn't read from a devine.yaml in wherever you running devine from.
And to save on future headaches, "wvds" should be in all lowercase. It won't work otherwise. And it should be the directory name only, don't include the .wvd file. So, "C:/devine/WVDs" just like the other directories.
https://github.com/devine-dl/devine/blob/master/CONFIG.md gives the expected syntax of the config file.Last edited by achilles; 10th Apr 2024 at 14:29.
new update for iplayer> https://cdm-project.com/stabbedbybrick/devine-services/src/branch/main/services/iP/__init__.py
just replace __init__.py file -
Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
Hi trying an ALL4 download and keeps failing at VTT subtitles. I don't need them. Can anyone tell me a command so it doesn't download subtitles? I have tried --video-only --audio-only --subs only srt but I'm obviously not getting correct command.
I've got SPOT sort of working. It hangs if you ask for an Album download but works OK for single downloads. Still doesn't beat spot-dl.
The problem is all these CDM guys have forked rlaphoenix's repository and made changes to the structure or are behind synchronizing rlaphoenix's updates . Pheonix himself suggests that as a way forward. What it means is that there will be services of the same tag-name knocking around that will only work on the forked platform. I had to carry over a file and folder to get SPOT to run.
I predict it is going to get very messy!Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
Yeah, this is the reason I decided to host only a service folder. People can just set it directly in the config or grab the services individually, and keep the Devine installation isolated.
I'd recommend cloning the original repo, set up poetry, and just add services to it as you see fit. -
Thanks for the help everyone. I've got it working for ALL4 on windows and it downloads fine, including the subtitles.
However, iPlayer seems to fail for me as I get:
AttributeError: 'Segment' object has no attribute 'keys'
It seems to be failing on line 473 in hls.py. I'm trying to work out why it can't find keys. -
For the time being BBC in UK-FTA is hours ahead faster and you've got that. I tried 'This Town' not only did it download the trailor but I also something else to do with fashion was on the list. However it bailed out after episode 4. Using the default downloader, (requests), devine seems to create dozens of threads; it confuses itself and fails waiting for download. So still work in progress.
Thanks Angela, yes, your UK-FTA is an excellent tool and I use that a lot.
To be honest I quite enjoy just playing around with new stuff and as stabbedbybrick had kindly created an iPlayer one I thought I'd try and get it to work.
I think I actually enjoy getting this sort of stuff working more than actually watching the shows. It's like doing a jigsaw. -
You know I feel this is quite like the old days learning to use yt-dlp with its conundrum of settings to get the correct streams. Devine is very clever software but using it does feel like a step backwards in time. It shouldn't be this way.
One thing I really wish devine had was an option for N_m3u8DL-RE as a downloader. Fast and reliable. Handles errors/timeouts well.
[Attachment 78275 - Click to enlarge]
But yes, in general I feel like N_m3u8DL-RE is the most stable downloader. And you could theoretically implement it to a service, but I feel like it would be a nightmare to handle the output and events so it's not worth it. -
Win 10, fully updated. python all up to date.
I could do with some help please chaps..... Things seem to have taken a radical turn for the worse... if i try to run devine --help from an elevated cmd prompt from my devine folder I no longer get:
[Attachment 78282 - Click to enlarge]
but instead all i get is this:
[Attachment 78283 - Click to enlarge]
If i do not use "poetry shell"
I still get this:
[Attachment 78284 - Click to enlarge]
I re-installed devine, no error messages appeared. So I am now at a loss as to what I should do.
I do have a .venv folder within my Devine folder,... and my devine.yaml has been reversed back to this:
directories:
services: C:\devine\devine\services
temp: C:\devine\temp
downloads: C:\devine\downloads
cookies: C:\devine\cookies
cache: C:\devine\cache
logs: C:\devine\Logs
WVDs: C:\devine\WVDs\8162_l3.wvd
cdm:
default: 8162_l3
credentials:
ALL4:
ROKU: email
assword
key_vaults:
- type: SQLite
path: C:\devine\devine\key_store.db
tag: ''
downloader: aria2c
profiles:
default: default
I tried having the devine.yaml in my C:\Devine\devine folder but still get the same error message as above.
also tried having devine.yaml in C:\Users\xxxx\AppData\Local\devine folder but this makes no difference.
Is it at all possible to reverse the installation to enable a clean re-install. Appreciate any advice/guidance please chaps.
How do I completely remove the music and sound effects from a movie?
By cns00 in forum EditingReplies: 1Last Post: 15th Jan 2024, 13:11 -
Which software can remove music from show but keep character dialogue?
By Mohamed61020 in forum AudioReplies: 6Last Post: 2nd Jul 2023, 22:32 -
Software for simple music videos?
By dewiclements in forum Software PlayingReplies: 3Last Post: 26th Jul 2022, 02:21 -
H.264 for archival and editing - no go?
By malling in forum Capturing and VCRReplies: 8Last Post: 20th Aug 2019, 00:51 -
Movie music too loud but dialogue too quiet fix needed
By hokkom in forum AudioReplies: 121Last Post: 4th May 2019, 09:51
