    May 2023
    Italy
    Hello,
    I'm converting a list of files to .mkv with HandBrake, they should be all equals but some file returns error and stops encoding, jumping to the next.
    I've inspected the log and I see a long list of "avformatMux: track 2, av_interleaved_write_frame failed with error 'Permission denied'" and "Last error repeated 3 times".
    How can I solve this error?
    Thank you
    Mar 2008
    Usually permission denied means it doesn't have access to the output folder (Windows file/folder permissions)
    May 2023
    Italy
    It's weird because only few files got that problem, and they're all saved to the same folder.
    Mar 2008
    Compare a log where it worked Vs. where it failed and perhaps you'll see something.
    Also check the file names, sometimes embedded spaces or special chracters can cause issues
