Page 25 of 27
FirstFirst ... 15 23 24 25 26 27 LastLast
Results 721 to 750 of 796
  1. is this extension work with VDOCIPHER ? i have real CDM but it freeze when i click guess
  2. Originally Posted by thegoodguy View Post
    https://github.com/DevLARLEY/WidevineProxy2
  3. Very good addon. It works even with deprecated non-working widevine library on old browser, running in Windows 7 unlike WidevineProxy2. So, would be better to add strings for copy ready command for using with utilities, such as N_m3u8DL-RE, yt-dlp+mp4decrypt or may be other.
  4. Now I have a question for you abhttps://forum.videohelp.com/attachment.php?attachmentid=83782&stc=1&d=17327336 12out the plugin "Foxfire / vwvg (Widevine L3 Guessor 2024) How to upload this missing CDM as in the picture that is missing
Name:	Zrzut ekranu (9).png
  5. Originally Posted by Henryk69 View Post
    The reason no one replied to your post is,
    that you did not RFM
    (Don't worry you are not alone,
    in the age of YT Videos,
    quick results are always expected and even I am guilty
    of not reading the manuals, it is just quicker to "ask").
    Documentation<= Read here first!
    https://github.com/FoxRefire/wvg/tree/next
    Installation
    - Download or clone this code
    - At the same directory of manifest.json(root directory of this extension),
    put the one of the following Android L3 CDM key pair file(s).
    https://github.com/FoxRefire/wvg/wiki/Getting-started
    Place the Android L3 CDM key pair files into root directory of the extension
    So .... place "ONE" of:
    - device.wvd
    or
    - device_client_id_blob + device_private_key
    or
    - client_id.bin + private_key.pem
    or
    - remote.json
    into root directory of the extension where you cloned it .....
    and that is it, as simple as that ......
    You are welcome.
    If I was in politics I make sure you drink plenty of beer
    and watch plenty of TV to keep you busy. | Data is the new oil.
  6. Thanks for the quick reply to my email "pssh"
    So I will first download and install Red Light Filter Manager 1.6. But it doesn't matter where I install this program.
    "wvg-next" - not in this folder
  7. Originally Posted by Henryk69 View Post
    Missed the T, it should have been RTFM and not RFM
  8. Dzięki za pomoc pssh
    Zainstalowałem ten program .
    Czy trzeba coś w tym programie zmienić ?????
    https://forum.videohelp.com/attachment.php?attachmentid=83799&stc=1&d=1732814938
    Thanks for the help pssh
    I installed this program.
    Do I need to change something in this program?????
    It would be better to upload the old version 1.0
Name:	Zrzut ekranu (10).png
  9. Originally Posted by Henryk69 View Post
    You can uninstall the RMF (RadLight-Filter-Manager) its not needed
    My post #725
    where I refer to RFM should have been RTFM (I have missed the "T") ....
    please accept my apology for the confusion caused
    VH automatically fills in links to some programs,
    and so it did in the case of RTM.
    This is how the sentence should have looked like:
    that you did not RTFM
    And RTFM is an acronym for "read the ******* manual",
    used to reply to basic questions that can be found in documentation or online help.
    If you followed the steps in my post #725,
    you should get the "extension" working
    If not, post back with what exactly you have done so far
    and maybe have a look at the manual
  10. For now I have my program folder and it looks like in the picture, and I wonder
    how to do it step by step with this CDM, I'm new here and an amateur and what's easy for you
    is not necessarily easy for me, I've only been dealing with DRM for a few days
    I'm just learning, and I have to translate it all from English to Polish - sometimes I translate it with a mistake
    I translate it with a mistake / but now enough of this self-pity, let's get to work
    I have my program folder and I have to do exactly this:
    Installation
    At the same directory of manifest.json(root directory of this extension), put the one of the following Android L3 CDM key pair file(s).
    Don't know how to get these files? See How to dump CDM key pair for more informations.
    Supported CDM Key Pair Formats
    device.wvd
    remote.json (How to use Remote CDM)
    Does this mean that you need to create 2 files named :
    device_client_id_blob + device_private_key and client_id.bin + private_key.pem and put them in the program/wvg-next directory where the manifest.json file is?
    https://forum.videohelp.com/attachment.php?attachmentid=83802&stc=1&d=1732837728
Name:	Zrzut ekranu (11).png
  11. Originally Posted by Henryk69 View Post
    Installation
    device.wvd
    I am (ass you and me) that you have read the excellent Wiki that "FoxRefire" wrote here:
    from top to the bottom and enjoyed it as much as I did
    (who does not love reading guides and manuals, right?
    Hand on heart, did you read the complete Wiki?
    Many people here, including me, spend hours reading/learning and some contributing here ...
    When I mention RTFM, I was referring you to do the same ......
    If you not sure, "search it, using your favorite search engine"
    Translating from EN -> PL works great (much better then CN -> EN), may not be 100% accurate here,
    but will give you idea of how thins are/should be ...
    (I still believe that New Members should not be able to post here
    without spending some time reading!!!!!)
    *.wvd is in the correct place
    but has a 0 KB in size ....
    *.wvd is a file (that now can be downloaded from this forum as well)
    that is created (using pywidevine) from "client_id.bin" + "private_key.pem" OR "device_client_id_blob" + "device_private_key"
    so 2 files extracted from Device/Emulator ...(and automatically by this extension if you place the 2 files in the same DIR !!!)
    If you read all the post I wrote, its somewhere there, and also in the Wiki that "FoxRefire" wrote ......
    searching "wvd file" will give the clues
    and how it is created ......and has been discussed on VH
    numerous times ....
    Here are just a few (From the Sticky Threads) on the subject:
    https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio
    https://forum.videohelp.com/threads/415466-Real-Device-CDMS
    https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
    remote.json is a file containing settings to access remote CDM over Internet if you have the settings
    https://github.com/FoxRefire/wvg/wiki/Using-with-Remote-CDM
    https://github.com/FoxRefire/wvg/wiki/Troubleshooting-FAQ#is-it-safe-to-use-a-remote-c...-a-third-party
    Please, just read the links posted above, before you hit that "Reply" button again. Thank you.
    Before I cast my vote, I read about the person/questions and others to be able to make an informed decision.
    When I execute code/app on my PC, I have a look where it come from, what it does, check is safe
    and execute application.exe -? to see what it offers ......(if anything at all from CLI
    but sometimes the amount of options is overwhelming and will ask for help once searching
    for answer does not yield any meaningful answer.
  12. I created this wvd-0 file myself and stored it there
  13. On Opera/Chrome this addon get keys about 20 seconds, but on Firefox - about 3 minutes. Why so different performance?
  14. Originally Posted by Henryk69 View Post
    If you have problems even on this step, may be you need an easier solution? Try trial version of StreamFab Downloader? You can download up to 3 videos per service during the trial period.
  15. This StreamFab, I've already tested it, it works but it doesn't download from all sites, but I have a question for everyone here on the forum, make a program like this and then update it
  16. Originally Posted by Henryk69 View Post
    Did you try to open site with video in this app as in browser? You can see the "Download" button, it doesn't work?
  17. Yes, but there are specific websites listed on which this software works, so not all of them and it's not cheap.
  18. Originally Posted by Henryk69 View Post
    It works also on not listed sites with encrypted videos, I used it last year, when can't to get keys from cdrm-project. So, do you know, what you need to do with received keys, what utilities to use in next step? If no, you need to read sticky posts, as this: https://forum.videohelp.com/threads/408557-Decryption-The-Last-Crusade .
  19. Would be better to add file/files upload input field instead of coping files to the addon directory, then addon can be packed to .xpi extension without needing to pack it with device files.
    The problem is that on Firefox it works much slower, than on Chrome and now addon doesn't work with DRMToday license on both browsers. Also would be good to generate ready to download command in another text field.
  20. When I click the guess button, the mouse cursor changes to a spinning wheel, but nothing happens from Prime.
    [Attachment 84290 - Click to enlarge]
  21. you need python installed and pywidevine
  22. Good evening everyone.
    I hope you had a merry Christmas!
    I have a new problem with Widevine L3 Guessor 2024. I'm looking for the keys for Paramount+.
    The CommonWV preselection doesn't work. Does it even work with Paramount+?
    Thank you very much.
    Best regards
    Heiko
  23. Member
    Feb 2006
    Best regards
    Heiko
    Paramount+ changed something on their end so Widevine L3 Guessor 2024 and WidevineProxy2
    will no longer work. try Devine - https://cdm-project.com/stabbedbybrick/devine-services
  24. Member
    Dec 2021
    england
    stabbedbybrick's devine dont have Paramount+ service
  25. Originally Posted by Goku73 View Post
    I already had it installed. It's not working for me with Amazon, either on Chrome or Firefox.
  26. You can check addon serviceability with other license type on this sample.
    Looks like there is no fixes yet, try WidevineProxy2.
  27. Hello to Everyone!
    Is there any help with this ?
    the mediaKey Object could not be created/initialized
    (DRM_MEDIA_KEY_INIZIALIZATION_FAILED)
    after using Frida latest version and keyDive to Dump L3 from Android-Studio it gives this error
    i have tried with emulator Pixel 6 & Android 9
    also i tried with Pixel 8 Pro & Anroid 13 Google Api as the Developer Guide say's it works but when i open the DRM Test Stream it gives error Anyone had this issue before please Help me with it thanks in advance
  28. https://www.channel4.com/programmes/travel-man-48-hours-in/on-demand/75174-002
    i am trying to use the app download this tv show , but i got a wrong url
    N_m3u8DL-RE "https://cf.jos.c4assets.com/CH4_08_02_900_75174_002_1_173453880786371/CH4_08_02_900_75174_002_1_173453880786371_J01.ism/stream.mpd?c3.ri=13499391095207767592&mpd_segment_ template=time&filter=(type=="video"&&((DisplayHeig ht>=288)&&(DisplayHeight<=576)))||type!="video"&ts =1737208675&e=600&st=uWcWFM0MdtDc0ij7xSYpkBeF9eDdU 1DtJ5JfGIm-hu0" -M format=mp4 --key 00000000000000000000000011796366:bb78b20495c7d14a6 504f48582a8a7e7 -sv best -sa best --save-name "Travel Man 48 Hours in..." --save-dir "C:\the"
    i am try to downaold the best vision, but the url is erro, how can in fix it , and on ch4 can i get the HD cilp ?
  29. Member
    Mar 2024
    The URL needs to be encoded, use something like https://www.urlencoder.org
