Hi guys I have this question because I´m very worried about, I have my EVGA GTX 1080 Ti 11gb (for the moment I cant buy another better) and I so wish to use this card for upscaling video, this proccess can take several hours and I´m very worried about if the video card just blow up or something!
Thank You in advance
If y so worried, you can install MSI Afterburner and apply some power limit, like 90% or so
Several hours encoding should be no problem, assuming your card (and system) is properly cooled.
(haven't seen a card explode or die unless there was a heat or power issue)
=> check your temperaturesusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I used an EVGA GTX 1060 to adjust the color of an IP camera live stream that was going 24/7 for a few years. It still runs great.
It's not the card you need to worry about, it's the power supply and the wall outlet.
Many years ago I lived in an old apartment building where you could trip the breaker by plugging in an iron or a microwave oven, and I had built what at the time was a pretty fast system that I used for compiling code and video encoding and torrenting.
I blew 2 outlets and a power supply.
I doubt anything will happen to you card, people used those cards to mine bitcoin for years and they are still alive and kicking. -
As far as desktop computers are concerned, graphics cards are usually sold with enough cooling for themselves. The problem is your case cooling. If you don't have enough, the inside of the case will be too hot for the graphics card to cool itself. The first, most likely problem will be errors in your video encoding (GPU filtering or 3d rendering). Then, although systems and graphics cards are designed to slow down when overheating, they often just crash instead.
Beware that cheap laptops are often designed only for light loads -- casual web browsing, watching videos, desktop apps. They often overheat when run at 100 percent CPU/GPU.
Upscaling a video to 2k with VSDC
By kolaland in forum EditingReplies: 1Last Post: 12th Feb 2023, 12:22 -
Upscaling video
By robw1947 in forum Newbie / General discussionsReplies: 28Last Post: 13th Feb 2022, 04:52 -
Video Upscaling
By bradwiggo in forum Newbie / General discussionsReplies: 10Last Post: 13th Mar 2021, 17:48 -
DVDFab Video Upscaling--Enhance DVD from SD (480p) to Full HD (1080p) video
By DVDFab Staff in forum Latest Video NewsReplies: 2Last Post: 6th Aug 2020, 04:31 -
Playing video using Madvr the video lags when upscaling
By Arilando in forum Software PlayingReplies: 0Last Post: 7th Sep 2019, 16:29
