I downloaded a movie and there isn't any sound. When I open up the file with windows media player it trys to look for a codec and says there is an error... then it continues playing the movie.. but with no sound.
It does it on other players also. my sound is working on my computer tho.. and it does work with other movies also. just not this one.
Can anyone help?
-Acer_m1![]()
http://www.vcdhelp.com/tools.htm
You need the proper codecs on your system. Dont know the movie you downloaded or the group it came from, start off with the 3.11 install that one, if it works great, if not, get the 4.1
sound problems. GSpot 2,52
By camino camino in forum Video ConversionReplies: 0Last Post: 13th Jul 2010, 05:44 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36 -
DV encoded Sound Problems
By zack28 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Sep 2007, 18:20
