Hello,
Some video movies (mp4) I have are a little dark and audio is low.
I am not familiar with ffmpeg, but got some instructions help from a friend.
I used ffmpeg to make the video a little brighter and raise a little the audio.
All was well, then it started to change the frames per second of the video - I did not change anything in the command line to do it.
The command lines I used are:
1. CD Drive:\"Path to video location"
2. ffmpeg -i "video file.mp4" -vf eq=brightness=0.2:contrast=1.5 af volume=2 -b:v1800k "output video file.mp4"
The original video file is 23.976 fps.
The output video file is 47.952 fps.
OS windows 10 pro, 19045.4170 x64 22H2
What is wrong ?
Answers will be appreciated.
Motim
Source is probably vfr, first thing I would try is whether extending the video filtering by "-filter:v fps=24000/1001 -fps_mode:v cfr" and calling '-fflags +igndts' before loading the source helps.
Last ffmpeg update changed average bit rate usage with -cq render, previous
By JN- in forum Video ConversionReplies: 2Last Post: 24th Dec 2022, 17:29 -
How to export frames from a video with timecode in filenames (ffmpeg)?
By eliio in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2022, 11:25 -
Cannot encode video with ffmpeg libx264 maintaining 5 reference frames.
By Budman1 in forum EditingReplies: 4Last Post: 20th Aug 2020, 13:27 -
ffmpeg cut point wrong with 5 reference frames video
By Budman1 in forum EditingReplies: 9Last Post: 8th Aug 2020, 12:06 -
Reading Video Frames Using ffmpeg
By chris319 in forum ProgrammingReplies: 15Last Post: 4th Nov 2019, 15:10
