I have file A from webscrabbing to get time(inaccurate) and subtitles for of the only some of the subtitles (for example this video I only take 38 lines of subtitles for file A from a 34 minute videos).
B file is full accurate subtitles with 1000 lines and accurate time.
I want to modify file A to have timecodes from file B and only that. So I can later use file A as input to rip off audio of the parts i need.
But there is one big problem is that many times timecode from file A doesnt match the accurate time. (1 seccond different max). And the text of both files is mostly but isnt the exact same. (I only take the words which were being told, skipped all "[...] (...) : ...")
Can fix the subs manually of course but I need a way to automate this for it to be worth the time.
I can provide link for both subtitlse if needed.
[Attachment 78173 - Click to enlarge]
Try to run Speech to Text (Whisper) to get synchronized timestamps and text for the audio files. Subtitles Edit has this feature.
the thing is I only need a very small amount of the subtitles, and these subtitles lines are determined by a js script i ran which scrap a google chrome addon result. And I already have B subtitles file which has synchronized timecodes and subtitles.
sorry for late reply, I found another way to get the similar result i wanted so the answer is no longer needed.
Thank you for trying to help.
Matroska text file attachment
By Bigo2 in forum Software PlayingReplies: 10Last Post: 12th Jul 2022, 08:30 -
How to delete part of text in another language from a file?
By bluenite in forum SubtitleReplies: 2Last Post: 3rd Nov 2021, 15:15 -
How to get File list with file size in a text file?
By iKron in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jul 2021, 21:13 -
Renaming chapters in an mp4 from a text file
By RandmTask in forum Video ConversionReplies: 5Last Post: 24th Sep 2020, 04:06 -
Aegisub - Correct workflow when importing a text file
By dynamique in forum SubtitleReplies: 1Last Post: 7th Jul 2020, 12:31
