  1. Member MourningStar's Avatar
    Mar 2009
    I have this 3+min video. When it is done playing the attached image displays at the end. I want that frame removed. I have tried Lossless Cut and AviDemux with no success. I even cut the video to 5+ seconds long (attached) and it still appears at the end. Help!
  2. I don't see that frame when playing the attached clip,... are you sure you play (and attached) the right clip?
    Maybe copy it into another folder and play it from there,...
  3. Member MourningStar's Avatar
    Mar 2009
    you are right, I do not see it either. I will look into it and get back, -thx.
  4. Member MourningStar's Avatar
    Mar 2009
    sorry, I seem to have resolved it.
