  1. Does it matter which i burn it on? Tried on a friends Sony DVD player that is compatible with vcd's..but wont play if its burned onto cd-R not sure if it will on CD-rw instead.
    Anyone knows?
  2. I burn to both cdr and cd-rw from my own experience it depends on the quality of your discs,allways get the best discs you can afford.
    I have had the same problem with cdr discs some work and some dont ,I dont know why but i have never had a problem with cd-rw.
    When i am playing around and checking out new settings i always use cd-rw , if i make a mistake i just wipe it then try again..
    gavron..
  3. Check the DVD player compatability list, you may find that that player will only play CDRW or a particular colour of CDR
    Craig
  4. Dude, Burn your VCD on a CD-RW & see if the thing works, THEN burn it on a CD-R. I trached a lot of CD-R's until I figured out that if I screw up a CD-RW, I can just Erase & Rewrite it.
    Most DVD Players will play both CD-R & CD-RW, even my Sh***y Mintek DVD Player will play CD-RW's.
    -Mick-
  5. There's still a surprising amount of players out there that won't play CDR
    Craig
  6. As above.
    BTW, I'm sure you saw this: http://forum.vcdhelp.com/viewtopic.php?t=75572 when you posted the thread.
    This is a bulletin board, not IRC. Please wait at least a day or two for a response and don't bump the thread.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  7. ahh my bad..sorry dudes.
