No matter what software program I use; I can never capture higher than 352x240 with out losing frames. If I bump it up to 352x480 or 480x480 I lose frames. Any thing else higher and I still lose frames.
My system specs are:
Athlon 1gz processor
384 MB ram
40 gig 7200 rpm ata 66 HD
ATI AIW Pro 32MB vid card
Is my card a piece of junk. My system works great for everything else.
Thanks in advance.
in win9x use the 4.12.6292 drivers and MMC 7.1.
in win2k use the 5.xx.xx.192 drivers/MMC 7.1.
in win9x it's actually helpful to install "drivers, MMC 6.3, MMC 7.1 to a new directory, DVD 4.1" in that order. MMC 6.3 setup won't work right in all cases but you will have the VFW capture drivers you want. are you capturing MPEG or AVI? how many frames? if it's like 1 every 5 minutes it's no big deal, it may not even be a lost frame, but a resync of audio/video. if the ATI software says you're dropping <1% that's no big deal, probably lost one in the first second while it was setting up, but the message never goes away.
capture to a partition (preferably drive) other than the one with the windows swap file on it. in 3rd party programs use YUV2 or UYVY as the capture format, never RGB (it wastes cpu to convert)
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 10:52 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36
