Results 1 to 15 of 15
  1. Can anybody help me getting the key for this video?
    Link:
    https://www.channel4.com/programmes/the-royals/on-demand/75650-007
    MPD:
    https://cf.jos.c4assets.com/CH4_08_02_900_75650007001001_001/CH4_08_02_900_75650007001001_001_J01.ism/stream.mpd
    PSSH:
    AAAAZnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEYIARIQAAAAAAAAAAAAAAAABQU4AxoIcmJtY2g0dHYiJDAwMDAwMDAwLTAwMDAtMDAwMC0wMDAwLTAwMDAwNTA1MzgwMzIA
    License:
    https://c4.eme.lp.aws.redbeemedia.com/wvlicenceproxy-service/widevine/acquire
  2. Originally Posted by phineferb98 View Post
    Link:
    MPD:
    PSSH:
    License:
    --key 00000000000000000000000005053803:937557e1c3ff70ca6209b46413e5d4d4
  3. Originally Posted by white_snake View Post
    Link:
    MPD:
    PSSH:
    License:
    could you explain step by step how you did it?
  4. Originally Posted by gaby45 View Post
    You need a PSSH and license url (like for all license requests), and the json payload, no headers needed. If you want to learn, you should start by reading the sticky threads.
    If you don't care about the process and just want to download, I suggest you look up Freevine and/or UK-FTA, which automate this process.
  5. May I ask for help getting the key/video here: https://www.channel4.com/programmes/the-talent/on-demand/75441-001
    I looked through the threads but I'm a lot of steps behind and while I'll continue to do research for my own sake, this was a one-off request from my friend.
    Conversely, if someone could tell me what I should use to get the key?
    This is what I've gotten so far:
    PSSH:
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEAAAAAAAAAAAAAAAAAVBQlc=
    License URL:
    but I've tried using the token and other info sent as a payload but it doesn't work.
    Oct 2023
    Donesville
    PSSH: AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEHevitVBtRAlgH33Wt0FPLpI49yVmwY=
    KEYS: 77af8ad541b51025807df75add053cba:089ac1238e9dd64eb3ddffbf46e02ae6
  7. Originally Posted by billybanana View Post
    Thank you! But are you sure that's the key? It's not working for me with N_m3u8DL-RE or yt-dlp --allow-u. I'm using this mpd: https://pastebin.com/raw/EHrTf0JP
  8. Wrong Key
    Try this one
    00000000000000000000000005414257:5f1dd28039eb94ce0b6ea72484a0e2b1
    Command to download
    N_m3u8DL-RE --key 00000000000000000000000005414257:5f1dd28039eb94ce0b6ea72484a0e2b1 "https://ak-jos-c4assets-com.akamaized.net/CH4_08_02_900_75441001001003_002/CH4_08_02_900_75441001001003_002_J01.ism/stream.mpd?c3.ri=13635892196639582782&mpd_segment_template=time&filter=%28type%3D%3D%22video%22%26%26%28%28DisplayHeight%3E%3D288%29%26%26%28systemBitrate%3C4800000%29%29%29%7C%7Ctype%21%3D%22video%22&ts=1723609643&e=600&st=v6Hq28b5cWdPDTL7emKCwisqJ-ysRbKU8oXd8CYEtpo" -M format=mp4
    your file
    https://www.swisstransfer.com/d/69f9cd7b-79e6-46e2-99c6-631746bfd9e7
  9. Originally Posted by cedric8528 View Post
    Wrong Key
    Try this one
    Command to download
    your file
    Thank you so much! For the key and file.
    Oct 2023
    Donesville
    Wrong Key
    That's odd. It downloaded and decrypted fine for me using that key. My script is based off Angela's All4 so definitely works in the same manner.
    Enter the All4 video URL: https://www.channel4.com/programmes/the-talent/on-demand/75441-001
    MPD URL: http://ak.dash01.stream.c4assets.com/wvmod-stream/CH4_33_05_42_75441001001003_004_HD.mpd?c3.ri=13506413707358981913
    License URL: https://c4.eme.lp.aws.redbeemedia.com/wvlicenceproxy-service/widevine/acquire
    KEYS: --key 77af8ad541b51025807df75add053cba:089ac1238e9dd64eb3ddffbf46e02ae6
    DOWNLOAD COMMAND: N_m3u8DL-RE "http://ak.dash01.stream.c4assets.com/wvmod-stream/CH4_33_05_42_75441001001003_004_HD.mpd?c3.ri=13506413707358981913" --select-video best --select-audio best --select-subtitle all -mt -M format=mkv:muxer=mkvmerge --save-name "The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264" --save-dir "D:/Downloads/" --key 77af8ad541b51025807df75add053cba:089ac1238e9dd64eb3ddffbf46e02ae6
    Do you wish to download? Y or N: y
    13:30:39.091 INFO : N_m3u8DL-RE (Beta version) 20231113
    13:30:39.102 INFO : Loading URL: http://ak.dash01.stream.c4assets.com/wvmod-stream/CH4_33_05_42_75441001001003_004_HD.mpd?c3.ri=13506413707358981913
    13:30:39.211 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
    13:30:39.211 INFO : Parsing streams...
    13:30:39.213 WARN : Writing meta json
    13:30:39.214 INFO : Extracted, there are 13 streams, with 10 basic streams, 2 audio streams, 1 subtitle streams
    13:30:39.214 INFO : Vid *CENC 1920x1080 | 4962 Kbps | video=4932948 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.214 INFO : Vid *CENC 1920x1080 | 2984 Kbps | video=2964250 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.214 INFO : Vid *CENC 1280x720 | 1990 Kbps | video=1976900 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.215 INFO : Vid *CENC 1024x576 | 1494 Kbps | video=1483428 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.215 INFO : Vid *CENC 1024x576 | 1198 Kbps | video=1186957 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.215 INFO : Vid *CENC 640x360 | 997 Kbps | video=989142 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.215 INFO : Vid *CENC 640x360 | 799 Kbps | video=791974 | avc1.4D401F | 1 Segment | Main | ~15m17s
    13:30:39.216 INFO : Vid *CENC 512x288 | 502 Kbps | video=494564 | avc1.42C01F | 1 Segment | Main | ~15m17s
    13:30:39.216 INFO : Vid *CENC 384x216 | 254 Kbps | video=247337 | avc1.42C01F | 1 Segment | Main | ~15m17s
    13:30:39.216 INFO : Vid *CENC 256x144 | 155 Kbps | video=148657 | avc1.42C01F | 1 Segment | Main | ~15m17s
    13:30:39.216 INFO : Aud *CENC audio_eng=128000 | 134 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | Main | ~15m17s
    13:30:39.217 INFO : Aud *CENC audio_eng_1=128000 | 134 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | Alternate | ~15m17s
    13:30:39.217 INFO : Sub textstream=0 | 1 Segment | Main | ~15m17s
    13:30:39.217 INFO : Parsing streams...
    13:30:39.218 INFO : Selected streams:
    13:30:39.218 INFO : Vid *CENC 1920x1080 | 4962 Kbps | video=4932948 | avc1.640029 | 1 Segment | Main | ~15m17s
    13:30:39.219 INFO : Aud *CENC audio_eng=128000 | 134 Kbps | mp4a.40.2 | en | 2CH | 1 Segment | Main | ~15m17s
    13:30:39.219 INFO : Sub textstream=0 | 1 Segment | Main | ~15m17s
    13:30:39.219 WARN : Writing meta json
    13:30:39.220 INFO : Save Name: The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264
    13:30:39.221 WARN : MuxAfterDone is detected, binary merging is automatically enabled
    13:30:40.754 WARN : The entire file has been cut into small segments to accelerate
    13:30:40.756 INFO : Start downloading...Vid 1920x1080 | 4962 Kbps | video=4932948 | avc1.640029 | Main
    13:30:41.080 INFO : Start downloading...Sub textstream=0 | Main
    13:30:41.185 WARN : The entire file has been cut into small segments to accelerate
    13:30:41.186 INFO : Start downloading...Aud audio_eng=128000 | 134 Kbps | mp4a.40.2 | en | 2CH | Main
    13:30:41.468 WARN : Reading media info...
    13:30:41.485 INFO : NaN: Subtitle, webvtt
    13:30:41.486 WARN : Extracting VTT(raw) subtitle...
    13:30:41.491 INFO : Binary merging...
    13:30:43.768 WARN : Type: cenc
    13:30:43.769 WARN : PSSH(WV): CAESEHevitVBtRAlgH33Wt0FPLoaCHJibWNoNHR2Igc1NDE0MjQwMgA=
    13:30:43.770 WARN : KID: 77af8ad541b51025807df75add053cba
    13:30:43.771 WARN : Reading media info...
    13:30:43.795 INFO : [0x1]: Video, h264 (High) (avc1), 1920x1080, 25 fps, 92 kb/s
    13:30:51.049 WARN : Type: cenc
    13:30:51.049 WARN : PSSH(WV): CAESEHevitVBtRAlgH33Wt0FPLoaCHJibWNoNHR2Igc1NDE0MjQwMgA=
    13:30:51.050 WARN : KID: 77af8ad541b51025807df75add053cba
    13:30:51.051 WARN : Reading media info...
    13:30:51.099 INFO : [0x1]: Audio, aac (LC) (mp4a), 87 kb/s
    13:30:52.355 INFO : Binary merging...
    13:30:52.367 INFO : Decrypting...
    13:30:55.467 INFO : Binary merging...
    13:30:56.966 INFO : Decrypting...
    13:31:00.307 WARN : The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264.mp4
    13:31:00.307 WARN : The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264.en.m4a
    13:31:00.308 WARN : The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264.srt
    13:31:00.308 WARN : Muxing to The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264.MUX.mkv
    13:31:02.021 WARN : Cleaning files...
    13:31:02.064 WARN : Rename to The.Talent.1080p.ALL4.WEB-DL.AAC2.0.H.264.mkv
    13:31:02.065 INFO : Done
  11. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    It's possible it worked for you cause you got a different manifest. Yours and @cedric's don't match
    Oct 2023
    Donesville
    Web v Android endpoints would give a different manifest I guess ? Something to watch out for I s'pose.
  13. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    If the manifests aren't tokenized/geolocked, it's best just to provide the whole download command. It eliminates any manifest issues
