Hello,
I need help for download a video from TF1
TF1 URL
https://www.tf1.fr/tf1/les-reines-du-ring
MPD found with in TF1 URL
https://vod-das.cdn-0.diff.tf1.fr/eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjaXAiOiI4Ni4...m/14079992.mpd
PSSH found in MPD file
AAAAMHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABAiCDE0MD c5OTkySOPclZsG
License Widevine with found with TF1 URL
https://widevine-proxy-m.prod.p.tf1.fr/proxy?id=14079992&rn=1&ssc=efd9fa4c-5bd2-4f40-a...9&e=1712406017
I used Get Widevine Keys
http://108.181.133.95:8080
2734ef5f7b63569da91d6d9c7a73d1ec:6a6d349f4ff326177 881326191ba3a6c
65ad541577245380a508d0e30fcf38d4:7ff6c7a2be4e8a400 8286e2c628d9beb
27112303808d5b79a9d2fe902b316aa1:449a219fffd5b5b4b 887141c9ad069ae
Here my commande line the video and audio are downloaded but always encrypted and not mixed
N_m3u8DL-RE.exe https://vod-das.cdn-0.diff.tf1.fr/eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjaXAiOiI4Ni4...m/14079992.mpd --key 2734ef5f7b63569da91d6d9c7a73d1ec:6a6d349f4ff326177 881326191ba3a6c:65ad541577245380a508d0e30fcf38d4:7 ff6c7a2be4e8a4008286e2c628d9beb:27112303808d5b79a9 d2fe902b316aa1:449a219fffd5b5b4b887141c9ad069ae -M format=mp4
Thank you in advance for you time![]()
need to add --key for each key
or better, save all keys into txt file, rename as key.txt and run RE -M format=mp4 --key-text-file key.txt "https://mpd"
if your issue persist, use shaka to decrypt instead mp4decrypt
same --key-text-file key.txt but add also --use-shaka-packager -
(I verified your keys are good)Code:
N_m3u8DL-RE.exe https://vod-das.cdn-0.diff.tf1.fr/eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjaXAiOiI4Ni4...m/14079992.mpd --key 2734ef5f7b63569da91d6d9c7a73d1ec:6a6d349f4ff326177 --key 881326191ba3a6c:65ad541577245380a508d0e30fcf38d4:7 ff6c7a2be4e8a4008286e2c628d9beb:27112303808d5b79a9 --key d2fe902b316aa1:449a219fffd5b5b4b887141c9ad069ae -M format=mp4
Your movie : https://www.transfernow.net/dl/20240406iyQEz6vpLast edited by aqzs; 6th Apr 2024 at 08:49.
Hello lomero & aqzs
Thanks you help and upload
I will rety wih shaka
because with mp4decrypt I have video more longer than audio
downloading drm protected video from TF1+
By grizabella in forum Video Streaming DownloadingReplies: 40Last Post: 22nd Mar 2025, 16:41 -
A TF1 movie in green screen with N_m3u8DL-RE CMD
By GilbertA83 in forum Video Streaming DownloadingReplies: 6Last Post: 19th Feb 2024, 14:43 -
Keys from TF1 videos
By ecolek in forum Video Streaming DownloadingReplies: 7Last Post: 11th Nov 2023, 14:23 -
TF1: Need help to download this stream
By kalemvar1 in forum Video Streaming DownloadingReplies: 7Last Post: 6th Oct 2020, 08:13
