Is there a better method to double-rate deinterlace the attached (pathologic) source?
Some trials attached.
WARNING:
Watching this video may cause nausea or epileptic seizure to sensitive viewers.
Results 1 to 22 of 22
My generic QTGMC setting shows less artifacts on the third region with horizontal only lines. Just a quick run, I did not experiment anything else...
Code:QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1)
You should put an epileptic seizure warning
TDeint looks the least bad to me in that group
For this specific case you could "cheat" by using an lowpassed odd field luma mask + RIFE . You could overlay that on tdeint base with some temporalmedian applied. You'd expect the first few frames and last few to be messed up before it settles into the pattern per scene -
Yup, I missed it. I hope I won't be sued
The source may be awkward and far from natural video but I think it reveals the basic weaknesses of deinterlacers, each one exhibiting its specific artefacts, actually "damaging" the source. One reason why I am usually hesitant to deinterlace for "archiving" purposes.
At the end I think we would need to view this on an interlaced display? Unfortunately today's progressive monitors do not (and most likely will not in future) offer a setting to behave like a field oriented interlaced display such as legacy CRT's.
(Btw it's also enlightening to stream the source to the TV to see how its deinterlacer behaves.)Last edited by Sharc; 5th Apr 2024 at 02:02.
You should put an epileptic seizure warningI hope I won't be sued -
clip = havsfunc.QTGMC(Input=clip, Preset="Fast", InputType=0, TFF=False, TR2=0, SourceMatch=0, Lossless=2, opencl=True, Denoiser="KNLMeansCL", TR0=2, TR1=2, Rep0=2, Rep1=4, Rep2=8, DCT=5, Sbb=1, NoiseProcess=0, GrainRestore=0.0, NoiseRestore=0, StabilizeNoise=False, Sharpness=0
users currently on my ignore list: deadrats, Stears555, marcorocchini -
It's supposed to be flashing black and white. An interlaced analog TV shows one field at a time. Since one field is black and the other is white (in that section) the picture should flicker black and white.
You forgot a simple bob(0.0, 1.0) which is pretty much what one would see on a 59.94 Hz analog interlaced TV (lots of flicker). Careful though, some monitors and TVs will attempt to "fix" this video.Last edited by jagabo; 6th Apr 2024 at 12:56.
Makes sense, yes. (Btw a simple bob is included in my deint.mp4 as last case). I thought a legacy CRT may flicker less nervously because of its natural gradual brightness decay of the fluorescent screen. Maybe I am wrong. I don't have an old CRT anymore to verify. Anyway it was interesting to see how the various deinterlacers (and TVs) behave with this synthetic source.
Attached is a 60p version.
Code:LWLibavVideoSource("source_IL.ts") AssumeBFF() v0 = last.ChangeFPS(60000, 1001).Subtitle("interlaced_x2") v1 = QTGMC().Subtitle("qtgmc") v2 = BWDIF(field=2).Subtitle("bwdif") v3 = yadifmod2(mode=1).Subtitle("yadifmod2") v4 = tdeint(mode=1).Subtitle("tdeint") v5 = nnedi3(field=2).Subtitle("nnedi3") v6 = bob().Subtitle("bob") v0+v1+v2+v3+v4+v5+v6 prefetch(8)
Yes, that's almost exactly the script which I used. I just added AssumeFPS(25) at the beginning of the script for "PAL" framerate compliance - which makes the flicker more annoying.
I agree it's artifical-experimental and not a good test for practical deinterlacing. Yet one may find some of these 'deinterlacing defects' with anime sources or even 'natural' video.Last edited by Sharc; 7th Apr 2024 at 05:15.
The previous field has mostly faded away long before the new field is drawn. If you look at very high speed photography of an analog TV screen you'll see that a scanline has mostly faded away even as the next scanline of the same field is being drawn. You can see an example here:
https://youtu.be/3BJU2drrtCM?t=207
If you watch an analog TV showing a video where one field is all black and the other is all white it flickers horribly.Last edited by jagabo; 7th Apr 2024 at 13:02.
Early in that video (around the time I linked to) he is showing an inexpensive interlaced CRT TV. Later he shows a progressive LCD display where the situation is different.
I was asking about the CRT. If it is interlaced, then those lines are pretty damn close.
I wish he "froze" one field and overlayed the next field onto it to show how the second field fills the gaps in the first one. But I get the point - the phosphors decay very fast, which is surprising to me. Thanks. -
The scanlines are "close" because the electron beam isn't so highly focused that there's a gap between the lines. This makes the screen brighter and reduces the flicker (with a normal picture).
It depends. The beam could be more or less focused as needed.
A useless fun fact: with System A, as the size of TV screens grew, it was found that a wide beam makes the picture blurry and low-res, while a narrower beam leaves spaces between the lines. So a special technique was devised that used a narrow beam that wobbled up and down, producing oval-shaped spot. This allowed to preserve horizontal resolution and to close the gaps at the same time.
Header contains json data challenge
By sarvo99 in forum Video Streaming DownloadingReplies: 5Last Post: 20th Sep 2023, 09:13 -
Download stream key challenge
By maxjrzv84 in forum Video Streaming DownloadingReplies: 1Last Post: 14th Aug 2023, 22:44 -
Deinterlace or not?
By leed17 in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2022, 17:42 -
deinterlace help
By maudit in forum Newbie / General discussionsReplies: 7Last Post: 13th May 2022, 22:40 -
A very hard challenge: Download Streams From www.blutv.com.tr.
By Behroozfar in forum Video Streaming DownloadingReplies: 16Last Post: 1st Nov 2020, 17:14
