here's the case i have a bunch of avi files that i converted to mpg thru
roxio toast now after i did that i realized that the files went from roughly
220-odd mb to 460-odd mb now you can't fit that on a 650 or 700mb cdr\rw so what i did is i burned the first of the two files that i have ( they add up together to about 980mb or so) on one disc on the lowest speed provided then when it was done i put it in my dvd player (samsung m101)
only to find that there was no picture but just sound and pretty bad sound at that (given what i've heard out of vcd quality media) and that was the results of my first trial to make vcd![]()
Results 1 to 1 of 1
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
