I can't find the video source of any series on the site, I only find clips, but no playlists or complete films, can anyone help me?
Here is a link to an episode:
https://www.serially.it/play/thefive-s1e01
Results 1 to 30 of 38
I also can only find not encrypted trailers but no movie clip. It's written "Questo contenuto non è disponibile nella tua area geografica" so trying with a vpn might help.
In "Italia" I get : "Esegui l'accesso per guardare gratuitamente". I created an account. For https://www.serially.it/play/thefive-s1e01 I get:
mpd : https://aebe0fc-az-westeurope-fsly.cdn.redbee.live/ixmedia/assets/cbf61495-e10a-4bac-a...d-idx.ism/.mpd
pssh :licence : https://rbm-ixmedia.live.ott.irdeto.com/licenseServer/widevine/v1/rbm-ixmedia/license?contentId=cbf61495-e10a-4bac-aec5-311231131362_AEBE0Fc&keyId=983187bd-b82a-4cbf-aca8-5ed33c1993b1&ls_session=.........Code:AAAAXHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADwIARIQmDGHvbgqTL+sqF7TPBmTsRoIdXNwLWNlbmMiGG1ER0h2YmdxVEwrc3FGN1RQQm1Uc1E9PSoAMgA=
key :Then with N_m3u8DL-RE im able to download up to 1080p. I got TunnelBear vpn with 2gb plan so i will not be able to download the all video and try to decrypt it.. I you have a free vpn in Italia..Code:983187bdb82a4cbfaca85ed33c1993b1:c819995ec0545d05e710cdbc24efdd22
Italian IP needed.
Manifest:
Key:Code:https://redbee.serverside.ai/vod/mpds/5/55400e31-cb33-432c-a390-e82e71a671b9.mpd
Code:--key 983187bdb82a4cbfaca85ed33c1993b1:c819995ec0545d05e710cdbc24efdd22
@aqzs: You can download without VPN and your key is correct
[Attachment 78120 - Click to enlarge] -
Thank you all I too had already taken PSSH licence and key, but I cannot find the link to the complete file.
How did you find the link to the complete file? I can't find it?
I can only find an mpd link that makes you download a file of 15 or 40 seconds duration.
I cannot find the one like yours in the picture. -
Like this one : https://redbee.serverside.ai/vod/mpds/1/11ed5452-e75c-4630-8b53-1f8a434bb6da.mpd
[Attachment 78129 - Click to enlarge]
Just play the video with inspector opened and search for "mpd". if you want to automate the process you can parse the api request that's made to :
cbf61495-e10a-4bac-aec5-311231131362_AEBE0Fc is the id of the movie (in the url) and you have put the authorisation barear in the headerCode:https://exposure.api.redbee.live/v2/customer/IXMedia/businessunit/SERIALLY/entitlement/cbf61495-e10a-4bac-aec5-311231131362_AEBE0Fc/play?
Like aqzs said ''Just play the video with inspector opened and search for "mpd"
[Attachment 78132 - Click to enlarge]
right click -> Copy Value -> Copy URL
Code:N_m3u8DL-RE.exe MPD_URL
[Attachment 78133 - Click to enlarge]
Choose the *CENC* Video (take a look the duration, other videos are short)
Same thing for audio -
You have to feed N_m3u8DL-RE with the url of the .mpd. For exemple open a cmd in the same folder as N_m3u8DL-RE.exe:
Then you have to use the arrows up/down and space to select or diselect the files you want to download.Code:N_m3u8DL-RE.exe https://redbee.serverside.ai/vod/mpds/1/11ed5452-e75c-4630-8b53-1f8a434bb6da.mpd
For exemple if you want the best quality for this clip select the line :
00:39:22.314 INFO : Vid *CENC 1920x1080 | 5200 Kbps | video=5200000 | avc1.4D4028 | 464 Segments | ~44m23s
00:39:22.316 INFO : Aud *CENC audio_ita=128000 | 128 Kbps | mp4a.40.2 | it | 2CH | 464 Segments | ~44m23s -
Sorry I was blind I didn't see the longer link, *CENC* video
Thank you very much!!! -
Excuse me, friends, I've tried to get the key for the same video, i.e. https://www.serially.it/play/thefive-s1e01, so inspecting I got the following PSSH:
and licenseCode: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
https://rbm-ixmedia.live.ott.irdeto.com/licenseServer/widevine/v1/rbm-ixmedia/license?...h1gy7JAxS5T-vk
but using keysDB or https://cdrm-project.com/ I get an error ({"code":400,"error":true,"message":"Failed to extract KID from PSSH: No KID or Content ID was found in the PSSH."}. Should I use a header?
Thank you very, very much, in advance, for all your kind help and advice. Have a nice evening
For the next time use "[/CODE][/CODE]" to share the pssh. The pssh contains infos for playready and widevine, check with : https://emarsden.github.io/pssh-box-wasm/decode/.
The pssh for widevine is :Code:AAAAWnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADoIARIQmDGHvbgqTL+sqF7TPBmTsRoIdXNwLWNlbmMiGG1ER0h2YmdxVEwrc3FGN1RQQm1Uc1E9PTIA
Thank you very, very much, aqzs for prompt answer and all your help. With your precious advice I was able to get the correct key. Thanks, again.
Have a nice evening
Good evening my friends. I'm experiencing a problem with the following video from serially:
https://www.serially.it/play/sifuerastu0s1e01.
I could find without trouble the key, that is
anyway, after downloading and decrypting, I get the following messages during the muxing processCode:e123b7d78a3c4a5082f016d3937852d2:fed5727b00f3770c749f466c8459375b
The resulting file is a 23B useless one. I have the latest version of ffmpeg. What do you thing about this? Thank you very, very much, in advance for all help and advice. Have a nice eveningCode:16:13:16.787 WARN : Si fueras tú S1E1 - Al posto suo.copy.mp4 16:13:16.789 WARN : Si fueras tú S1E1 - Al posto suo.it.m4a 16:13:16.791 WARN : Si fueras tú S1E1 - Al posto suo.es.m4a 16:13:16.793 WARN : Muxing to Si fueras tú S1E1 - Al posto suo.MUX.mp4 16:13:18.318 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b106b780] Incorrect number of samples in encryption info 16:13:18.353 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b106b780] Could not find codec parameters for stream 0 (Video: h264 (avc1 / 0x31637661), none, 960x540, 1564 kb/s): unspecified pixel format 16:13:18.361 WARN : Consider increasing the value for the 'analyzeduration' and 'probesize' options 16:13:18.828 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b109fd80] Incorrect number of samples in encryption info 16:13:19.240 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b1bbb9c0] Incorrect number of samples in encryption info 16:13:19.312 WARN : [mp4 @ 00000205b4b734c0] track 1: codec frame size is not set 16:13:19.315 WARN : [mp4 @ 00000205b4b734c0] track 2: codec frame size is not set 16:13:19.317 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b106b780] Incorrect number of samples in encryption info 16:13:19.319 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b109fd80] Incorrect number of samples in encryption info 16:13:19.321 WARN : t:\Si fueras t├║ S1E1 - Al posto suo.copy.mp4: Invalid data found when processing input 16:13:19.323 WARN : t:\Si fueras t├║ S1E1 - Al posto suo.it.m4a: Invalid data found when processing input 16:13:19.325 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000205b1bbb9c0] Incorrect number of samples in encryption info 16:13:19.326 WARN : t:\Si fueras t├║ S1E1 - Al posto suo.es.m4a: Invalid data found when processing input 16:13:19.403 WARN : Cleaning files... 16:13:19.442 INFO : Done
Use this mpd:
The regular MPD:Code:https://AEBE0Fc-az-westeurope-fsly.cdn.redbee.live/ixmedia/assets/2c627658-01d8-4bff-90fc-09662e133cc4_AEBE0Fc/materials/mKcKVDK7Q5_AEBE0Fc/vod-idx-11.ism/.mpd
also contains ad streams, so that's probably what's causing the problem.Code:https://redbee.serverside.ai/vod/mpds/c/c0643615-b893-4005-8b83-a5deaeef8bdd.mpd
This command worked just fine for me:
If it doesn't work for you, update your ffmpeg binaries with these: https://github.com/yt-dlp/FFmpeg-Builds/releasesCode:N_m3u8DL-RE -M format=mkv --key e123b7d78a3c4a5082f016d3937852d2:fed5727b00f3770c749f466c8459375b https://AEBE0Fc-az-westeurope-fsly.cdn.redbee.live/ixmedia/assets/2c627658-01d8-4bff-90fc-09662e133cc4_AEBE0Fc/materials/mKcKVDK7Q5_AEBE0Fc/vod-idx-11.ism/.mpd
Thank you so very much for answer and advices. I udated the binaries and tried again. Now muxing is accomplished, but, strangely, the resulting video is encrypted. Weird, isn't it?
Log is the following
Code:17:58:34.115 WARN : Muxing to Si fueras tú S1E1 - Al posto suo.MUX.mp4 17:58:36.265 WARN : [h264 @ 000001987f929c00] top block unavailable for requested intra mode -1 17:58:36.269 WARN : [h264 @ 000001987f929c00] error while decoding MB 0 0, bytestream 467 17:58:36.931 WARN : [aac @ 000001987f929c00] channel element 2.11 is not allocated 17:58:37.375 WARN : [aac @ 000001987f929c00] channel element 2.15 is not allocated 17:58:37.755 WARN : [mp4 @ 000001987f998d80] track 1: codec frame size is not set 17:58:37.810 WARN : [mp4 @ 000001987f998d80] track 2: codec frame size is not set 17:58:38.146 WARN : [mp4 @ 000001987f998d80] aac bitstream error 17:59:43.123 WARN : Last message repeated 30 times 17:59:43.755 WARN : Cleaning files... 17:59:43.818 INFO : Done
@misiek1963
[Attachment 79417 - Click to enlarge]
what do you mean encrypted ? -
make sure to add ffmpeg in your pathCode:
Weird, I don't get any warning at all from ffmpeg. Run:
to make sure N_m3u8DL-RE is using the right binary. Also try to use this build of N_m3u8DL-RE: https://github.com/stabbedbybrick/N_m3u8DL-RE/releasesCode:where ffmpeg
Finally, try to not specify any output file name, some character like "ú" could possibly break something somewhere. -
Thank you so very much for all advices, I apologize to have answered so late, you're right, as always!
The problem was the accent, it caused ffmpeg muxing to malfunction. Without it everything works. So in file name it should never be present any character like the abovo, eventually we can change the name afterwards. Thank you very much, again, for all help. Have a great day
Hi,I followed the instructions in this thread,but in the end I'm forced to ask for help.I'm Italian and I apologise for my English which is not my primary language.So here's the problem:I would like to download this video
,but the first obstacle is that in the . mpd fileCode:https://www.serially.it/play/1303-la-paura-ha-inizio?t=0
I can't find/understand the pssh code to get the key.If I enter this commandCode:https://redbee.serverside.ai/vod/mpds/9/970ee7e0-7014-4b9b-a312-6509e966eaef.mpd
what I get are two separate files, video and audio, but the video has a black screen, the audio in .m4a format is not audible.What I'm doing wrong ?Code:N_m3u8DL-RE.exe --ffmpeg-binary-path C:\ProgramData\chocolatey\bin\ffmpeg.exe https://redbee.serverside.ai/vod/mpds/9/970ee7e0-7014-4b9b-a312-6509e966eaef.mpd
Here is your file : https://www.swisstransfer.com/d/fdca42c8-6787-4503-b2ac-972f7ee611e9
Need help downloading
By Angel_Cyclops in forum Video Streaming DownloadingReplies: 36Last Post: 19th Feb 2025, 07:00 -
Downloading an HLS stream: ONLY in sync when downloading with ffmpeg. Possi
By royjeon215 in forum Video Streaming DownloadingReplies: 6Last Post: 21st Jan 2024, 03:56 -
Help downloading from iq.com
By dami3n in forum Video Streaming DownloadingReplies: 10Last Post: 3rd Apr 2022, 04:27 -
Need Help Downloading this
By daigo99 in forum Video Streaming DownloadingReplies: 16Last Post: 20th Jul 2021, 19:58 -
Need help with downloading
By DWIChannel in forum Video Streaming DownloadingReplies: 2Last Post: 16th Jul 2020, 11:27
