Have a DV8.1 file, bunch of extraneous audio/subtitle tracks and I need to split off some of the footage to make it two separate files. Would usually just drop it into MKVToolnix, check and uncheck as necessary, and remux. But it won't even open. I'm assuming the DoVi profile is the issue.
Is there a way to do this? Searching just turns up people wanting to convert to 8.1 from a lower profile.
Maybe there is something not right with your sourcefile. Can you post the whole MediaInfo data of it?
FYI MKVToolnix is perfectly capable of (re-)muxing Dolby Vision. But when doing DoVi, be sure to always set "Default duration/FPS" to the proper value. -
General Format : Matroska Format version : Version 4 File size : 23.3 GiB Duration : 3 h 30 min Overall bit rate : 15.9 Mb/s Frame rate : 24.000 FPS Encoded date : 2024-03-15 15:03:34 UTC Writing application : mkvmerge v83.0 ('Circle Of Friends') 64-bit Writing library : libebml v1.4.5 + libmatroska v1.7.1 Cover : Yes Attachments : cover.png Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 3 h 30 min Bit rate : 15.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.075 Stream size : 22.0 GiB (94%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2 Audio #1 ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 3 h 30 min Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 1.13 GiB (5%) Language : English Service kind : Complete Main Default : Yes Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 3 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 3 h 30 min Bit rate : 125 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 189 MiB (1%) Language : English Default : No Forced : No Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 12 min Bit rate : 3 b/s Frame rate : 0.014 FPS Count of elements : 165 Stream size : 5.48 KiB (0%) Language : Chinese Default : No Forced : No Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.031 FPS Count of elements : 199 Stream size : 6.44 KiB (0%) Language : Danish Default : No Forced : No Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.025 FPS Count of elements : 162 Stream size : 6.93 KiB (0%) Language : German Default : No Forced : No Text #4 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 30 min Bit rate : 82 b/s Frame rate : 0.268 FPS Count of elements : 3378 Stream size : 126 KiB (0%) Language : English Default : Yes Forced : No Text #5 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.031 FPS Count of elements : 200 Stream size : 6.67 KiB (0%) Language : Spanish Default : No Forced : No Text #6 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 12 min Bit rate : 4 b/s Frame rate : 0.014 FPS Count of elements : 164 Stream size : 6.73 KiB (0%) Language : Spanish Default : No Forced : No Text #7 ID : 10 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 4 b/s Frame rate : 0.016 FPS Count of elements : 201 Stream size : 6.43 KiB (0%) Language : French Default : No Forced : No Text #8 ID : 11 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 12 min Bit rate : 4 b/s Frame rate : 0.014 FPS Count of elements : 167 Stream size : 6.90 KiB (0%) Default : No Forced : No Text #9 ID : 12 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 15 b/s Frame rate : 0.031 FPS Count of elements : 200 Stream size : 12.2 KiB (0%) Language : Greek Default : No Forced : No Text #10 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.026 FPS Count of elements : 167 Stream size : 6.63 KiB (0%) Language : Italian Default : No Forced : No Text #11 ID : 14 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 7 b/s Frame rate : 0.022 FPS Count of elements : 143 Stream size : 5.84 KiB (0%) Language : Japanese Default : No Forced : No Text #12 ID : 15 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 4 b/s Frame rate : 0.016 FPS Count of elements : 201 Stream size : 6.69 KiB (0%) Language : Hungarian Default : No Forced : No Text #13 ID : 16 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 29 min Bit rate : 73 b/s Frame rate : 0.237 FPS Count of elements : 2976 Stream size : 113 KiB (0%) Language : Korean Default : No Forced : No Text #14 ID : 17 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.031 FPS Count of elements : 197 Stream size : 6.93 KiB (0%) Language : Dutch Default : No Forced : No Text #15 ID : 18 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 4 b/s Frame rate : 0.016 FPS Count of elements : 200 Stream size : 6.65 KiB (0%) Language : Norwegian Default : No Forced : No Text #16 ID : 19 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 3 b/s Frame rate : 0.016 FPS Count of elements : 201 Stream size : 6.11 KiB (0%) Language : Polish Default : No Forced : No Text #17 ID : 20 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.031 FPS Count of elements : 200 Stream size : 6.49 KiB (0%) Language : Portuguese Default : No Forced : No Text #18 ID : 21 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 50 b/s Frame rate : 0.194 FPS Count of elements : 2428 Stream size : 77.0 KiB (0%) Language : Portuguese Default : No Forced : No Text #19 ID : 22 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 12 min Bit rate : 5 b/s Frame rate : 0.014 FPS Count of elements : 165 Stream size : 7.22 KiB (0%) Language : Romanian Default : No Forced : No Text #20 ID : 23 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 4 b/s Frame rate : 0.016 FPS Count of elements : 201 Stream size : 7.08 KiB (0%) Language : Slovak Default : No Forced : No Text #21 ID : 24 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 7 b/s Frame rate : 0.031 FPS Count of elements : 200 Stream size : 6.09 KiB (0%) Language : Finnish Default : No Forced : No Text #22 ID : 25 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 7 b/s Frame rate : 0.031 FPS Count of elements : 200 Stream size : 5.72 KiB (0%) Language : Swedish Default : No Forced : No Text #23 ID : 26 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 3 h 28 min Bit rate : 4 b/s Frame rate : 0.016 FPS Count of elements : 201 Stream size : 6.89 KiB (0%) Language : Turkish Default : No Forced : No Text #24 ID : 27 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 47 min Bit rate : 8 b/s Frame rate : 0.031 FPS Count of elements : 200 Stream size : 6.55 KiB (0%) Language : Czech Default : No Forced : No -
Dolby Vision 8.1 is a single-layer dv, it's no different from a normal MKV, and the MKVVtoolnix should be able to handle it
Maybe because this:
Cover : Yes
Try clever FFmpeg-GUI.
Download it, start it and follow the instructions.
Then load your file, click main, click multiplex, set (on the left) the streams you want to retain and click multiplex.
Done.
Shrink 4K UHD with Dolby vision
By moon_light in forum Video ConversionReplies: 3Last Post: 26th Oct 2023, 15:32 -
Mkv with Dolby Vision?
By meimeiriver in forum Authoring (Blu-ray)Replies: 1Last Post: 9th Sep 2023, 06:28 -
Dolby vision profile 7 to 5?
By Maradon in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2023, 05:20 -
Dolby Vision Hybrids
By GreekUser in forum Video ConversionReplies: 4Last Post: 28th Jul 2022, 13:13 -
Dolby Vision
By JosephTocco in forum Newbie / General discussionsReplies: 15Last Post: 31st Oct 2021, 06:06
