Been filming home movies for some time on my DV camera.
Goal: Create SVCD home movies with all footage.
Use: Have used Adobe premiere & pinnacle studio DV to capture footage.
Problem: After taking my raw AVI footage into TMPGE to encode it to MPEG2 I must be doing something wrong. I get pixelating on the fast camera movements during the filming. I have tried different settings but I can't figure out what I am doing wrong.
Setup: Drag the AVI into TMPGE. Choose SVCD (NTSC) - not NTSC film. Drag the clip in. Choose interlace, bottom field first 1:1 VGA Aspect ratio. (I use no noise reduction.) Average bit rate can't be set higher than 2520 and go.
Question: Do you think it is in the capturing stage I am doing something wrong or is it in the conversion or is that just as good as it gets?
As I said earlier, I get some pixeling or blocking throughout the fast movements part of the movie. I thought at first I was using an inferior program such as pinnacle studio and the capturing was bad but I tried Adobe premiere and it did the same.
Any info would be appreciated...
You could try using the TMPGEnc Deinterlace filters. When ever I get picture problems I use the even filter. Hope this helps
o(-_-)o---------------------------------------o(-_-)o
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
Having Strange Problem with after encode!
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 20th Mar 2011, 04:36 -
Little Problem during encode in Format Factory
By Stef2010 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 10:43 -
Problem with Independence Day (Region A) encode
By meatycheesyboy in forum Blu-ray RippingReplies: 2Last Post: 2nd Sep 2008, 12:07 -
NEW PROBLEM: Will Not Encode
By totalnewbiedumbass in forum ffmpegX general discussionReplies: 4Last Post: 14th Dec 2007, 10:25
