Is there a good settings in gerneral for 2160p.WEB.DV.HDR.HEVC 35~ to a 1080p.DV.HDR.HEVC Settings?
i want to convert some of my movies so i can watch them on my holiday
Post moved to it's own thread where you can get more help.
Be aware that if the file you want to convert is obviously warez, it is against VideoHelp's forum rules to help you.
A MediaInfo report about the file might be useful. Download MediaInfo from VideoHelp's software section and install it. Open your file in MediaInfo. Click View->Text. Select and copy the MediaInfo report window and paste it into a reply to this thread. You can edit the text in the report to remove identifying information if necessary. When you are done, post your reply.
I probably can't help you with encoding settings, particularly if the UHD source file has Dolby Vision HDR.Ignore list: hello_hello, tried, TechLord, Snoopy329
Processing a HEVC-HDR smartphone 4K video file in VDub2?
By Marvolo in forum Video ConversionReplies: 7Last Post: 8th Aug 2023, 14:42 -
How To Downscale 4K 2160p HEVC 10 bit Video To 2K 1080p AVC 10bit
By LouieChuckyMerry in forum Video ConversionReplies: 32Last Post: 26th May 2023, 03:07 -
2160p HEVC HDR Dolby Vision video on SDR 1440p display shows bad colors
By psycketom in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2021, 01:19 -
Multi Rate HEVC Encodes for 720p/1080p/2160p
By mukeshsinh in forum Newbie / General discussionsReplies: 0Last Post: 29th Jul 2021, 09:22 -
cut at keyframe HEVC 10bit HDR editor?
By lifespeed in forum EditingReplies: 1Last Post: 23rd Nov 2020, 15:26
