Hi
I have tried and tested different programs, such as tsmuxer and others to create a Blu Ray Folder for an MKV, however, none of them have worked for me, in fact, some programs lower the framerate to 30
This is the mediainfo of the MKV
Format : Matroska
Format version : Version 4
File size : 27.8 GiB
Duration : 2 h 23 min
Overall bit rate : 27.7 Mb/s
Frame rate : 59.763 FPS
Writing application : Lavf60.16.100
Writing library : Lavf60.16.100
ErrorDetectionType : Per level 1
Video
Format : AVC
Format profile : High@L4.2
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 1 frame
Format settings, GOP : M=1, N=60
Codec ID : V_MPEG4/ISO/AVC
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : VideoHandle
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
VENDOR_ID : [0][0][0][0]
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Title : SoundHandle
Language : English
Default : No
Forced : No
I think the fact that the MKV has a framerate of 59,763 FPS is giving me headaches.
Anyone can help me to create a Blu ray without transcoding?
Results 1 to 25 of 25
Blu-ray does not support 1080p59.94, closest is 1080i29.97.
Re-encode your footage to use a standard framerate (29.97), make it Blu-ray compliant (vbv, keyint...), and flag it as interlaced. -
No. But you could use "fake interlaced" mode to fool the player. See here:
http://web.archive.org/web/20211006144459/https:/forum.doom9.org/showthread.php?t=154533
http://web.archive.org/web/20211016213149/http:/www.x264bluray.com/home/1080i-pLast edited by Sharc; 3rd Apr 2024 at 04:10.
So Blu-ray is not the same as AVCHD burnt to DVD-R media. I do this with 1080p 25fps using multiAVCHD (no reencoding) and playback is fine with my Sony Blu-ray player.
Burned media does not have to abide specifically to the Blu-ray standard. There is always some leeway but this is on a player/brand basis.
tsMuxer does not follow strictly the H.222 specifications, yet most players will support what it outputs, to some extent. -
I disagree with @cibo. The further you stray from the standard, the less compatible and supported you become. It's not possible to make a 4k UHD Blu-ray be fully compatible, because there isn't a standard yet for burnables, but there IS a standard for HD Blu-ray and there is available consumer software to create it. Would be a shame to ignore the possibility of compatibility.
Scott -
multiAVCHD is too complex a program to explain here how to use its miriad of functions.
However, assuming you have all the required tools installed, the following should get you started.
Note: The following is for 1080p 25fps (no re-encoding so, h264 video, AC3 audio), AVCHD to DVD-R media. You will only get about 30 minutes on a disc. Works for my Sony player, but no guarantees for other players.
Via Settings tab "Reset all to defaults"
Select "Use Imgburn with DVD/BDR output"
Navigate to Image burn when requested
Via Media tab "Add video files"
Via Author tab select "Create top menu" and check "XMB" menu. Uncheck everything else
Set "TV system" to "PAL 24p" (for menu creation)
Set "Transparency" slider to zero
Via Menu (General) tab set "Default menu type" to "Static", (Motion should also work)
Via Menu (Advanced) tab check "Do not apply background tweaks"
Via Menu (Extended) tab set "Menu encoding quality" to "Very High"
Click (Start) button (bottom of right hand pane)
Select (AVCHD Disc) from options
Click ImgBurn write button when requested -
Another note on the compatibility: AAC is not accepted audio codec by Blu-ray and AVCHD. Audio must be encoded in PCM or Dolby.
Conversion 59.94p -> 29.97i in Avisynth:
or using ffmpeg, try:Code:separatefields().selectevery(4,0,3).weave()
Code:ffmpeg -i "%~1" -vf setfield=tff,tinterlace=4 -c:a ac3 -c:v libx264 -preset slow -crf 20 -flags +ilme+ildct "%~1_interlaced.mkv"
The "true" should keep it in sync
https://avisynthplus.readthedocs.io/en/latest/avisynthdoc/corefilters/fps.html -
If you are not familiar with avisynth or ffmpeg, maybe try BD Rebuilder. It outputs Blu-ray compliant files or discs for many source formats, including basic menus. Most support you would find in the doom9 forum I think.
Thanks so much for your help
Yes, the big problem of this video that this video was recorded using a Samsung with some strange framerate in MP4, which has been a headache trying to get this video to have a framerate to create a simple BD format, every time I reduce the framerate the audio gets out of sync.
At the moment I have the video running with TMPEnc authoring works to convert it to MKV at 29.970 and supposedly with synced audio, but this can easily take 20 hours :/
Using BD Rebuilder got this error:
[12:04:46] Importing MP4: PARTE1
- Preparing MP4 for processing...
- Scanning for Variable Frame Rate...
- Collecting audio/video streams from source...
- Converting source to compliant format...
[12:10:15]ERROR: Failed VFR conversion. Aborted.Last edited by javieracdc; 7th Apr 2024 at 11:10.
You cold try converting with Avidemux.
https://www.avidemux.org/nightly/win64/
Latest, last in list.
Settings:
Video output: Mpeg4 AVC (x264)
Audio output: AC3 (AAC not supported in BD)
Video output/Filters/Transform/Resample FPS
Mode: 29.97 (NTSC)
Interpolation: None
I would make a 5-10 minute selection first, to test sync. Total encoding time will of course depend very much on your system -
That's a hint at least. Fixing may be not so easy, otherwise BD RB would probably have done it, I guess.
2 possible approaches
- One could convert VFR to CFR by remuxing the video into a container which doesn't support VFR, like .avi for example. It may require resampling of the audio though. Here a proposal using ffmpeg. It will be very fast as no reencoding is done, no quality loss, just adjusting timestamps.
You could try similar using some GUI, maybe?Code:ffmpeg -r 30000.0/1001.0 -i "your VFR source" -c:v copy -c:a copy CFR.avi ffmpeg -i CFR.avi -i "your VFR source" -map 0:v -map 0:a -map_metadata:s:v 1:s:v -c:v copy -c:a copy -fflags +genpts "new_CFR.mp4" del CFR.avi
- Or if you re-pack your .mkv into an .mp4 container - or better use the original .mp4 from the Samsung capture - you could try mp4fpsmod from here:
https://github.com/nu774/mp4fpsmod
Resampling of the audio (and converting to ac3 for Blu-Ray) may be required, you have to try.
Good luck.Last edited by Sharc; 7th Apr 2024 at 12:44.
Hello, I now have the following case
I have a MKV that I recorded from the Iphone 15 and I have these HDR parameters:
HDR format : Dolby Vision, Version 1.0, Profile 8.4, dvhe.08.05, BL+RPU, no metadata compression, HLG compatible.
Transfer characteristics : HLG
Matrix coefficients : BT.2020 non-constant
It also has a variable frame rate but I can't transform it to Blu Ray with tsmuxer because the audio is out of sync, since I have to set a fixed framerate in tsmuxer.
In fact the video framerate is approx 59fps but I would like to set it to 59.95 to match the BD frame.
How can I convert from 59 to 59.95 fps constant without losing audio sync and losing HDR and keep the same video quality, (keeping the bitrates)?
Burning MKV To Blu-ray
By Captainfearless in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Feb 2023, 09:27 -
Best way to convert an MKV file to Blu-ray?
By hbenthow in forum Authoring (Blu-ray)Replies: 28Last Post: 21st Jan 2022, 07:05 -
Splitting Blu-Ray MKV By Chapters
By mugz8391 in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Aug 2020, 15:11 -
MKV Video shrinked and to Blu-Ray 25
By Spovkobob in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jul 2020, 04:36 -
Which is best? Convert to Blu-ray format or leave as MKV?
By Yanta in forum MediaReplies: 11Last Post: 13th Jun 2019, 22:37
