Hi,
I'm trying to download a video from RTLPlay.be with the python script here https://forum.videohelp.com/threads/413893-Download-from-RTL-Play?daysprune=60
I get following error message :
File "/mnt/Download/get71.py", line 181, in <module> print (get_download_command(s, format_mpd=True))
File "/mnt/Download/get71.y", line 170, in get_download_command
keys = get_keys(pssh_value, video_token)
File "/mnt/Download/get71.py'
", line 147, in get_keys
device = Device. load (WVD FILE)
File " /home/alex/.local/lib/python3.10/site-packages/pywidevine/device.py", line 163, in load with Path(path).open(mode="rb") as f:
File "/usr/lib/python3.10/pathlib.py" line 1119, in open return self._accessor.open(self, mode, buffering, encoding, errors,
FileNotFoundError: [Errno 2] No such file or directory: 'device_wvd_file.wvd'
I don't really understand what the problem is. The file is not present on my system (ubuntu). Should it not has been installe with pywidevine ?
In cas someone could download the following video for me https://www.rtlplay.be/septante-et-un-p_8533/emission-du-26-03-24-c_13061109 it would be se kind and helpful. Or any idea about the error message here above is also more than welcome
Thanks in advance you all
Well, the error message is quite clear: [Errno 2] No such file or directory: 'device_wvd_file.wvd'
You need a local CDM in a file called device_wvd_file.wvd. Read the stickies to find how to extract one from an android device.
Here are some that may still or may not work anymore: https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here -
Hi,
wvd file is missing, read this post
and this post for explanations
Your video
Code:N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/7/4/4/744d804bd84928ff561495bdce1b8daec33f2626/static/13061109_181e673979dd4a466fcdf8b23ae85624_web_dash_upTo1080p_720p_vbr_cae_drm_hardware.mpd" --key eb1b7f365e1d610bd94db635a315dd49:9ea2d13e59ba5dd7345f28c5a65f9d38 -M format=mkv
Many thanks to both of you for the precious help you provided. I got my video with success ! Thanks again !
Can someone help me to download a video from plus.rtl.de
By frankio in forum Video Streaming DownloadingReplies: 158Last Post: 14th Sep 2025, 10:03 -
Download from plus.rtl.de
By Data2006 in forum Video Streaming DownloadingReplies: 80Last Post: 8th Oct 2024, 17:00 -
Download movie from "Plus.rtl.de"
By linkinp in forum Video Streaming DownloadingReplies: 36Last Post: 12th Apr 2024, 05:05 -
Download from RTL Play
By Kiwaki in forum Video Streaming DownloadingReplies: 10Last Post: 25th Mar 2024, 11:39 -
How can I download videos from play.rtl.hr?
By Nintendo Custom in forum Video Streaming DownloadingReplies: 23Last Post: 24th May 2022, 13:51
