I used a friend's iBook and sampled iMovie. Now I want to buy a low end mac so I can run iMovie. I need some help though.
What is the minimums I can get by with as far as processing speed, hard drive size, OS, firewire, etc.
Will it be possible to stay in the $600-$800 range for a machine that will run iMovie?
System Requirements:
• A Macintosh computer with a G3 (or later) 300 MHz or faster processor and a built-in FireWire port.
• A CD or DVD drive
• At least 64 megabytes (MB) of random-access memory (RAM). (128 MB of RAM is recommended.)
If running with 64MB you must turn Virtual Memory ON in the Memory Control panel in order to launch iMovie.
• 200 MB of available (unused) hard disk space (4 gigabytes are recommended. For example, 5 minutes of imported digital video requires about 1 gigabyte of disk space.)
• A monitor that supports 800 x 600 resolution (1024 x 768 is recommended) and thousands of colors (millions of colors is recommended)
• Mac OS 9.0.4 or later
• QuickTime 4.1.2 or later
• FireWire 2.4 or later (FireWire Support and Enabler extensions)
Other Requirements
• A digital video (DV) device, such as a camcorder or deck, with a FireWire, IEEE 1394, or iLink port
• A 4-pin-to-6-pin FireWire cable (for use with DV camcorders)
To view your movies with a television and/or VCR, you also need cables to connect your DV device to a VCR or television.
Minimum System Requirements for capturing miniDV
By darkwhite in forum ComputerReplies: 19Last Post: 27th May 2012, 08:21 -
Minimum System requirements for Bluray ripping/burning?
By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 12:32 -
Minimum hardware requirements to capture ATSC/QAM
By GLE3 in forum Capturing and VCRReplies: 9Last Post: 4th Mar 2010, 10:38 -
Minimum PC Requirements to do HD Video Editing?
By dan1st in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2009, 19:29 -
Minimum system requirements to play 720p files?
By ukb007 in forum Newbie / General discussionsReplies: 11Last Post: 21st May 2008, 14:36
