What exactly is a Divx file? I see where you can convert it and everything else but I can find what exactly a Divx file is. And how would you know if you had one? Just wondering.
Thanks Boxingjunkie![]()
Hi there,
Quote From http://www.divxnetworks.com:
DivX movies have an AVI extension, but that doesn't mean that all AVI are DivX. To know for sure if your movie is a DivX, open it with VirtualDub, then File > File Information. If the file is a DivX, you'll see DivX ;) next to "Decompressor".DivX™ is a digital video compression technology based on the ISO MPEG-4 standard. It provides broadband performance that is significantly superior to competitive technologies, allowing DVD-quality downloads of a typical 90-minute feature film in less than 30 minutes through existing broadband connections.
Hope this can help
Simo- A Life? Cool! Where can I download one of those from?
- I have a dream: 1,000,000,000,000 bytes free.
- The box said: 'install on Windows XP, 2003 or better'. So I installed it on Linux.
- Windows is NOT a virus. Viruses DO something -
keep in mind that divx is only one of the compressions based on MPEG-4...i believe nAVI and asf are both MPEG-4 (and also .avi)...but of much lesser quality than true divx
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
DIVX player question
By slats7 in forum Video Streaming DownloadingReplies: 4Last Post: 25th Sep 2008, 08:10 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 21:22 -
divx conversion question
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2007, 18:20
