Hi everyone
Thank you in advance, and for your help and patience. I've been searching everywhere to find a way to Create UHD Bluray Discs to play on my BluRay player using a Mac.
I found Leawo that has a UHD Creator tool for Mac, however Leawo's products are quite expensive, nearly $100 just for that one module, not anything else.
DVDFab's UHD is only for windows,
YuHan Media's interface is not intuitive so I can't figure out if it does UHD Bluray on MacOs or not.
Are there other software out there that supports Mac Os that I can use to burn a UHD BluRay disc? I've got 70gb 2160p files with all the bells and whistles for Audio and Visuals but can't figure out how to do this without spending a fortune.
I've found tsMuxer, but can't figure out if it's also used for Burning this sort of UHD BluRay or if it's just to convert files and things. The UI is beyond my knowledge.
Thank you
Just saw this post, Yuhan uhd creator has Mac version, https://yuhanmedia.com/uhd-creator
dvdfab does have a Mac version for Mac computers - https://www.dvdfab.cn/uhd-copy.htm?trackid=headmenu2
just click on Mac to download the Mac version. -
Thanks October, maybe I didn't understand the difference between their UHD Copy which there's a mac version, and the UHD Creator which is only windows. Much appreciated.
Convert mkv with Dolby Vision to UHD Bluray
By kallek in forum Authoring (Blu-ray)Replies: 19Last Post: 25th Apr 2024, 06:50 -
Remove region lock from UHD Bluray disc
By kallek in forum Blu-ray RippingReplies: 7Last Post: 9th Oct 2023, 09:24 -
Convert-mkv-4k-to-UHD-Bluray
By lcohen448 in forum Authoring (Blu-ray)Replies: 16Last Post: 5th Aug 2023, 03:55 -
Convert mkv 4k to UHD Bluray
By lcohen448 in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Aug 2023, 19:51 -
UHD mkv to BD-R DL50GB - tool to shrink >50K UHD MKV to BD compliant BDMV?
By njweb in forum Blu-ray RippingReplies: 6Last Post: 5th Mar 2021, 03:07
