Which of the following do you recommend for best quality tv viewing and capture? I will be capturing to avi and mpg, and eventulay mpg2.
ATI All-in-Wonder 128
ATI TV Wonder
Hauppage WinTV
Cheap TV tuner with BT878 chipset (STB or other)
Thanks,
Garron
I was also wondering about the pinnacle systems studio pctv or the pinnacle dc10 plus.
I bought and used an ATI128pro-32mb to watch a bit of TV,
and most capture to mpeg3 -> SVCD. I also play quake, and unreal on it.
It work good for $99 AGP all in one.
Even it does TV but I rather watch a Sony TV, then a Sony monitor.
Personally, I use an STB Tv Pci (not the model with the FM tuner) (circa 1996) with great results. It has the Bt848 chipset, composite in, Svideo in, audio in (which you can pass through to a soundcard) as well as the standard tv tuner (coax in.) The highest resolution that I was able to get this card to capture at is 480x480 but I've heard that it can capture higher.
I recently bought a Cybermail AV and hated it. Win2K drivers didn't work and there was a lot of video noise during the capture so I would stay away from that.
For the STB TV Pci there are Win98 drivers as well as generic WDM drivers for this card.
I have been able to run virtualdub (with the VxD drivers) and PowerVCDII (with the generic WDM drivers.) You can get the STB TV pci off of ebay for like $15. If you are looking for a cheap but reliable capture card I would the STB TV pci. It's old but it does the job and does it well!
DVD recorder digital tuners
By joecass in forum Newbie / General discussionsReplies: 80Last Post: 19th Apr 2011, 11:51 -
where do I purchase tv tuners that are cablecard ready?
By craig198 in forum Media Center PC / MediaCentersReplies: 13Last Post: 29th Jan 2011, 18:19 -
TV Tuners in Windows 7 x86
By jznomoney in forum Capturing and VCRReplies: 0Last Post: 10th Aug 2009, 16:44 -
QAM Tuners
By hd999 in forum DVB / IPTVReplies: 3Last Post: 23rd Dec 2007, 19:29 -
HD Tuners
By sponge in forum Newbie / General discussionsReplies: 7Last Post: 22nd Dec 2007, 04:21
