For download i use N_m3u8DL-RE.
This is the link:
https://mediasetinfinity.mediaset.it/video/ierieoggiintv/popcorn-1983_F308773901011401
The mpd is here:
https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1536064_18e334073d3645/dashrcenc/sd_wv_mpl.mpd
With N_m3u8DL-RE i can download it, BUT with permanent green picture through drm.
How can i generate the keys, to remove the drm ?
I read about from Widevine L3 Decryptor, is it helpful ? And if yes, how does this work step by step ?
Please let me know.
Results 1 to 30 of 467
your key
Code:8f01191be79ca58773311b02bfa0790c:cf402c51d3c5bc807cad53aaf2fb4a21
[Attachment 77993 - Click to enlarge]
https://cdrm-project.com/
Just need PSSH and License Url -
It works perfectly cedric8528, thank You.
The PSSH-URL i found in the mpd-header, but how did i get the license URL, which is needed, too ?Last edited by speedbob; 29th Mar 2024 at 06:31.
I found it in the console now, tried it with another video - and it works great.
Thanks a lot, cedric8528 !!
[Attachment 78005 - Click to enlarge] -
Buongiorno, chiedo scusa, anche io ho problemi con i video drm di mediaset.
Ho letto quanto avete scritto ma non essendo esperto non ho capito come fare.
Potreste spiegarmi passo passo come devo fare per scaricare per esempio questo video?
https://mediasetinfinity.mediaset.it/video/centovetrine12/episodio-1_F304005801000101
Grazie di cuore.
Matteo -
See this thread: https://forum.videohelp.com/threads/412937-mediaset-infinity-m3u8-link-not-found
In your specific case, PSSH:
License url (partial):Code:AAAAU3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADMIARIQ4gfURCfFxspXJINuzjIsNRoNYW1hem9udHZjcmltZSIIdGFtX3Rlc3QqAlNEMgA=
Key:Code:https://widevine.entitlement.theplatform.eu/wv/web/ModularDrm/getRawWidevineLicense?releasePid=........
MPD:Code:e207d44427c5c6ca5724836ece322c35:214f12ea5b23a4c5125e2d624abafd06
Download command:Code:https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1553611_18ecdb8581cd01/dashrcenc/sd_wv_mpl.mpd
Code:N_m3u8DL-RE -M format=mkv --key e207d44427c5c6ca5724836ece322c35:214f12ea5b23a4c5125e2d624abafd06 "https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1553611_18ecdb8581cd01/dashrcenc/sd_wv_mpl.mpd" --save-name "CentoVetrine S12E01"
Rieccomi, ho cercato di leggere i vari forum
Al momento ho trovato il file mdp e la licenza.
Non riesco a trovare il PSSH, proprio non capisco come si faccia.
Una volta inserito nel Send Widevine Request i vari codici sotto appare il risultato.
E da li come mi muovo?
Scusate tanto ma faccio davvero fatica.
Se poteste fare una guida passo passo
Un grande saluto.
Matteo -
brother, english forum here so talk english. Why do we all have to waste time translating your posts ?
Or maybe you didn't realize you were in an English forum ? maybe ok your first post, but the second one isn't admitted. This is no respect for all of us
also: mediasetinfinity it has been covered several times in this forum. Just do a simple search instead of asking the same things over and over again -
Hi, I apologize for the Italian. I made several attempts and managed to identify the various steps, therefore mpd, pssh and license and I arrived at the final string.
I installed ffmpeg on the PC and entered the string.
However, I find myself faced with this additional difficulty. Can you help me? Thank you with all my heart.
[Attachment 79406 - Click to enlarge] -
put exe in N_m3u8DL-RE
https://files.videohelp.com/u/301156/mp4decrypt.zip -
Thanks, I did what you wrote.
He downloaded the file but everything is green.
This error appears
I apologize again for my many difficulties
[Attachment 79408 - Click to enlarge] -
Ok thanks now it works.
However, I have another question.
I tried with another file but the widevine screen is different. Help
[Attachment 79409 - Click to enlarge]
https://cdrm-project.com/ -
just paste your pssh and license url there and then click decrypt .. its still the same ,
Maybe I'm the one who's wrong but it doesn't work. How should the fields following the license be filled in? Heathers, json and cookies. I apologize immensely
need only pssh and lic url. nothing more
[Attachment 79416 - Click to enlarge]
already cedric on post#2 show you which data need
also white_snake on post#4 show you the right lic url
so, really idk your issue ... -
Now it seems to work. Thank you with all my heart. Let's hope we don't make a mess
Buongiorno, come fare per scaricare questo? https://mediasetinfinity.mediaset.it/video/giocosporco/sesta-puntata--filippo-raciti_F...13159201000601
Grazie -
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
As Pepe said you should take a look at sticky thread. If you are lazy and only want this video :
Download link : https://gofile.io/d/IO5uXyCode:page url: https://mediasetinfinity.mediaset.it/video/giocosporco/sesta-puntata--filippo-raciti_F313159201000601 mpd_url: https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1537656_18e869df989d01/dashrcenc/hd_wv_mpl.mpd keys: ['1101e1d8c59ef1541fc056d4ad784f8e:9769f8a826c2d40ef39676dc06e6f9b6'] N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1537656_18e869df989d01/dashrcenc/hd_wv_mpl.mpd" --save-name "Sesta puntata | Filippo Raciti" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 1101e1d8c59ef1541fc056d4ad784f8e:9769f8a826c2d40ef39676dc06e6f9b6
Grazie, puoi darmi il link anche di questi 4, poi magari la guida per farlo io, grazie
https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/nina-le-iene-present...13146101000401
https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/cizco-le-iene-presen...13146101000501
https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/le-iene-presentano-i...13146101000601
https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/le-iene-presentano-i...13146101000701Last edited by simonemancino; 16th Aug 2024 at 13:09.
It seems that mediaset doesn't like batch downloading..Code:
page url: https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/nina-le-iene-presentano-inside-quello-che-gli-uomini-non-sanno_F313146101000401 mpd_url: https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1528650_18e192c26b1645/dashrcenc/hd_wv_mpl.mpd keys: ['cf896de6d3ea097da1a5c764e141c743:2823e1d07511018640b49fabb73fd19f'] N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1528650_18e192c26b1645/dashrcenc/hd_wv_mpl.mpd" --save-name "NINA: Le Iene presentano: Inside: Quello che gli uomini non sanno" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key cf896de6d3ea097da1a5c764e141c743:2823e1d07511018640b49fabb73fd19f page url: https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/cizco-le-iene-presentano-inside-san-patrignano-inferno-o-paradiso_F313146101000501 mpd_url: https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1530516_18e3deb74d5f89/dashrcenc/sd_wv_mpl.mpd keys: ['8519e82727ccd75509352538453078b8:79dd706a2b6a029896fec61092c1ea05'] N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1530516_18e3deb74d5f89/dashrcenc/sd_wv_mpl.mpd" --save-name "CIZCO: Le Iene presentano: Inside: San Patrignano: inferno o paradiso?" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 8519e82727ccd75509352538453078b8:79dd706a2b6a029896fec61092c1ea05 page url: https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/le-iene-presentano-inside-perche-rosa-e-olindo-possono-essere-assolti_F313146101000601 mpd_url: https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1537676_18e607b73caf89/dashrcenc/hd_wv_mpl.mpd keys: ['2816676fc11ae0e2d0067b287642324c:69c583fa66fb2bd3977fb8458c375fac'] N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/03/1537676_18e607b73caf89/dashrcenc/hd_wv_mpl.mpd" --save-name "Le Iene presentano: Inside: Perché Rosa e Olindo possono essere assolti" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 2816676fc11ae0e2d0067b287642324c:69c583fa66fb2bd3977fb8458c375fac page url: https://mediasetinfinity.mediaset.it/video/leienepresentanoinside/le-iene-presentano-inside-doping-davvero-vincono-sempre-i-migliori_F313146101000701 mpd_url: https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1548900_18e9dcc5efc645/dashrcenc/hd_wv_mpl.mpd keys: ['f1aa3ccccce977d4d1d7dddd27650088:55f26c346915a1bc4f564f666cb08348'] N_m3u8DL-RE "https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1548900_18e9dcc5efc645/dashrcenc/hd_wv_mpl.mpd" --save-name "Le Iene presentano Inside: Doping: davvero vincono sempre i migliori?" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key f1aa3ccccce977d4d1d7dddd27650088:55f26c346915a1bc4f564f666cb08348
ok, but this https://mediasetinfinity.mediaset.it/video/giocosporco/sesta-puntata--filippo-raciti_F...13159201000601 is always from Mediaset and you finally have obtained the link
I didn't understand your message, I already provided download command + download link for this video : https://forum.videohelp.com/threads/413997-Need-help-to-download-drm-protected-video-f...ty#post2746801
I think he just wants a download link. That's what he means by "puoi darmi il link anche di questi 4". He most likely doesn't understand N_m3u8DL-RE
mediaset infinity m3u8 link not found
By supergirl73 in forum Video Streaming DownloadingReplies: 218Last Post: 18th Mar 2025, 01:25 -
How to download a (DRM) protected video
By h3mlock in forum Video Streaming DownloadingReplies: 16Last Post: 19th Aug 2024, 18:42 -
Download drm protected video
By me2m8 in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2022, 03:49 -
DrM-protected video download
By WelleTy in forum Video Streaming DownloadingReplies: 5Last Post: 5th Apr 2021, 15:10 -
Download DRM protected video and decrypt it with a drm licence url
By vikral in forum Video Streaming DownloadingReplies: 9Last Post: 9th Feb 2021, 03:14
