I was wanting to try and frameserve using Virtualdub. In the guide that I found on this site it says to install the Proxyon. I dont have anything in my Proxy folder that came with Virtualdub. Can anyone tell me where to find this Proxyon? Or is there an even easier way to do this?
Thanks Boxingjunkie![]()
I had the same problem a while back when I did a fresh install of my operating system, I just send you by e-mail the files that should be in the aviproxy folder, you can use those to complete the settings.
For some reason the proxyon file is missing in the latest version of vdub. Its in the earlier versions though.
Craig -
I too have noticed the missing files. Does anyone have problems getting their encoder to open files from their frame server?
Kreg -
Boys and girls.
Download a older version of VD and xtract the .reg files from it to the new version of VD that you have on your HD. Also that the new version of VD dont works under XP so you have to use a old version of it to frameserve.
Where can I download Frameserve ?
By DuBsTaR in forum Newbie / General discussionsReplies: 19Last Post: 9th Dec 2011, 19:47 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 31st Aug 2009, 00:40 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 07:24 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 17:34 -
How do I DeInterlace and Frameserve?
By rocky12 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2008, 22:50
