Results 1 to 30 of 30
    Aug 2023
    Turkey
    hi
    i try many think to get the right pssh i cannot figure out can any help me to get pssh
    i cant share the link becouse its have token and hmac will be expire very soon
    on the mpd file thare are
    <AudioChannelConfiguration
    schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_c onfiguration:2011"
    value="2" />
    <!-- Common Encryption -->
    <ContentProtection
    schemeIdUri="urn:mpeg:dash:mp4protection:2011"
    value="cenc"
    cenc:default_KID="0FFB2FB2-32EE-3ECF-CE73-709FB8EDA4FA">
    </ContentProtection>
    no pssh insaide
    here its the kid
    0ffb2fb232ee3ecfce73709fb8eda4fa
    if i calculate the regluary kid to pssh
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEA/7L7Iy7j7PznNwn7jtpPo=
    this pssh will not work
    also i get the keys bud its wrong keys becouse the pssh its not coreckt
    i try with init not succes
    with axinom cannot becouse i cant find system id for widevine
    i dont now how to
    anyone its welcome ..
    kind regarts
  2. Can't you just extract the PSSH from the mp4 init segment? (See e.g. here: https://forum.videohelp.com/threads/413400-getPSSH-the-n00b-s-way#post2723476)
    Aug 2023
    Turkey
    thank for you answer @obo
    the sitration its i think i cant make even a mp4 init
    have you any provide for me to try difrend way to get segmnet mp4 ?
    kind regarts
  4. Download the crypted file(s) and use the linked script to search for the PSSH in the crypted file(s). Usually every widevine crypted mp4 file has the PSSH in its meta data (the resides in the moov atom) at the very beginning of the file.
    Aug 2023
    Turkey
    have you any type how to
    Download the crypted init.mp4 file
    i try with yt-dlp and N_m3u8DL-RE.exe
    with same comand and scripts bud its goin to fail
    example i try with this script
    import os
    import subprocess
    import re
    import base64
    import urllib.request
    import binascii
    from urllib.error import HTTPError
    def get_pssh(keyId):
        array_of_bytes = bytearray(b'\x00\x00\x002pssh\x00\x00\x00\x00')
        array_of_bytes.extend(bytes.fromhex("edef8ba979d64acea3c827dcd51d21ed"))
        array_of_bytes.extend(b'\x00\x00\x00\x12\x12\x10')
        array_of_bytes.extend(bytes.fromhex(keyId.replace("KID =", "")))
        return base64.b64encode(bytes.fromhex(array_of_bytes.hex()))
    def return_pssh(kid):
        kid = ''.join(c for c in kid if c.isalnum())
        return "PSSH = {}".format(get_pssh(kid).decode('utf-8'))
    def print_color(text, color_code):
        print(f"\033[{color_code}m{text}\033[0m", end="", flush=True)
    def get_pssh_from_url(url):
        mpd_headers = {
            "user-agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36"
        if url == "":
            print_color("URL input aborted. Exiting...", "91")
            return
        try:
            # Comment out the code that searches for PSSH values in the MPD
            # pssh_list = []
            mpd_data = urllib.request.urlopen(url).read().decode('utf-8')
            baseurl = url.rstrip("/") + "/"
            print_color("Calculating the PSSH, please wait.\n", "91")
            subprocess.run(['yt-dlp', '--allow-u', '--no-progress', '--console-title', url],
                           stdout=subprocess.DEVNULL, stderr=subprocess.STDOUT)
            for file in os.listdir():
                if file.endswith('.mp4') and file != 'test.mp4':
                    os.rename(file, 'test.mp4')
                    break
            kid = None
            dump_output = subprocess.run(['mp4dump.exe', 'test.mp4'], capture_output=True, text=True).stdout
            for line in dump_output.split('\n'):
                if 'KID' in line:
                    print("Found line with KID:", line)
                    parts = line.split('=')[1].strip()
                    if '[' in parts:
                        kid = parts.split('[')[1].strip(']')
                        print("Extracted KID:", kid.replace(' ', ''))
                    break
            if kid:
                pssh_result = return_pssh(kid)
                if pssh_result:
                    print_color(pssh_result, "92")
                    start_over()
            else:
                print("\nMPD doesn't have a KID.")
                if file.endswith('.m4a') or file == 'test.mp4':
                    os.remove(file)
        except HTTPError as e:
            print_color("Failed to fetch the MPD data. Please check the URL and try again.", "91")
            print("\n", end="")
            print_color(str(e), "91")
            start_over()
        except ValueError as e:
            if "unknown url type" in str(e):
                print_color("Invalid URL format. Please enter a valid URL.", "91")
                start_over()
            else:
                raise e
    def enter_url():
        url = input("Enter the URL : ")
        if url:
        else:
    def start_over():
        choice = input("\nDo you want to start over? (y/n): ")
        if choice.lower() == "y":
            enter_url()
        else:
            print("Exiting...")
    if os.path.exists('test.mp4'):
        os.remove('test.mp4')
    enter_url()
    its going to fail
    web [*~id=axxx_17x163xxx073~hmac=3xaexxx5xx3bd2xx 8xa7xc].faudio_eng=128000.m4a.part
    Aug 2023
    Turkey
    Originally Posted by imr_saleh View Post
    thank you for your tip
    bud
    have try thad get only PlayReady pssh out
    no succes with it
    Aug 2023
    Turkey
    i try to figure out with how to get easy init.mp4
    its thare any option with N_m3u8DL-RE ?
    with ytl get forbiiden
  8. can you send the whole MPD file?
    the init.mp4 path is usually in there.
  9. use this yt-dlp command to get one fragment
    yt-dlp --allow-u --test "mpd url"
    of course, N_m3u8DL-RE can download init.mp4 too, but maybe need CTRL+C to stop download when you get init.mp4.
  10. Banned
    Apr 2022
    Hong Kong
    Tried this before?
    AAAARnBzc2gBAAAA7e+LqXnWSs6jyCfc1R0h7QAAAAEP+y+yMu4+z85zcJ+47aT6AAAAEhIQD/svsjLuPs/Oc3CfuO2k+g==
    Aug 2023
    Turkey
    Originally Posted by CrymanChen View Post
    Tried this before?
    yes i cant get any response from this pssh
    Aug 2023
    Turkey
    yeap with this comand with yt-dlp
    [download] Destination: web [*~id=ac63906744_1711637058073~hmac=34aeef93873af27 3592d1675dd758c83bd2ce6a41de7440d7add86cb0f3a7f1c].fvideo=1800000.mp4
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (1/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (2/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (3/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (4/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (5/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (6/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (7/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (8/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (9/10)...
    [download] Got error: HTTP Error 403: Forbidden. Retrying fragment 1 (10/10)...
    [download] Got error: HTTP Error 403: Forbidden. Giving up after 10 retries
    not posibel
    bud i think mybe can be work with N_m3u8DL-RE
    will try again with stop
    18:43:50.261 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
    18:43:50.264 INFO : Parsing streams...
    18:43:50.510 WARN : Writing meta json
    18:43:50.553 INFO : Extracted, there are 4 streams, with 3 basic streams, 1 audio streams, 0 subtitle streams
    18:43:50.554 INFO : Vid *CENC 1280x720 | 1800 Kbps | video=1800000 | avc1.4D401F | 11251 Segments | ~12h00m03s
    18:43:50.557 INFO : Vid *CENC 768x432 | 760 Kbps | video=760000 | avc1.4D401E | 11251 Segments | ~12h00m03s
    18:43:50.558 INFO : Vid *CENC 416x234 | 240 Kbps | video=240000 | avc1.4D400D | 11251 Segments | ~12h00m03s
    18:43:50.561 INFO : Aud *CENC audio_eng=128000 | 128 Kbps | mp4a.40.2 | en | 2CH | 11251 Segments | ~12h00m03s
    18:43:50.562 INFO : Parsing streams...
    18:43:50.564 WARN : Live stream found
    18:43:50.587 INFO : Selected streams:
    18:43:50.600 INFO : Vid *CENC 1280x720 | 1800 Kbps | video=1800000 | avc1.4D401F | 11251 Segments | ~12h00m03s
    18:43:50.601 INFO : Aud *CENC audio_eng=128000 | 128 Kbps | mp4a.40.2 | en | 2CH | 11251 Segments | ~12h00m03s
    18:43:50.607 WARN : Writing meta json
    18:43:50.627 INFO : Save Name: web_2024-03-28_18-43-50
    18:43:50.637 WARN : set refresh interval to 26 seconds
    18:43:50.840 WARN : fMP4 is detected, binary merging is automatically enabled
    18:43:50.922 WARN : Type: cenc
    18:43:50.925 WARN : PSSH(WV): CAESEA/7L7Iy7j7PznNwn7jtpPoSEI6FR0Dwqjkw0k9FkT2JlLESEHyuh tWo2hRVI99BS7I2S8oaDGtyZWFkaWdpdHVyayIOYm1wcmVtaWV yZW9yZ2Q=
    18:43:50.925 WARN : KID: 0ffb2fb232ee3ecfce73709fb8eda4fa
    18:43:50.928 WARN : Reading media info...
    18:43:50.946 INFO : [0x1]: Video, h264 (avc1), 1280x720
    18:43:51.029 WARN : Type: cenc
    18:43:51.029 WARN : PSSH(WV): CAESEA/7L7Iy7j7PznNwn7jtpPoSEI6FR0Dwqjkw0k9FkT2JlLESEHyuh tWo2hRVI99BS7I2S8oaDGtyZWFkaWdpdHVyayIOYm1wcmVtaWV yZW9yZ2Q=
    18:43:51.032 WARN : KID: 0ffb2fb232ee3ecfce73709fb8eda4fa
    18:43:51.033 WARN : Reading media info...
    18:43:51.054 INFO : [0x1]: Audio, aac (mp4a), 128 kb/s
    Aug 2023
    Turkey
    i dont think so bud here its the mpd file
    <?xml version="1.0" encoding="utf-8"?>
    <!-- Created with Unified Streaming Platform  (version=1.12.1-28247) -->
    <MPD
      xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
      xmlns="urn:mpeg:dash:schema:mpd:2011"
      xmlns:cenc="urn:mpeg:cenc:2013"
      xmlns:mspr="urn:microsoft:playready"
      xsi:schemaLocation="urn:mpeg:dash:schema:mpd:2011 http://standards.iso.org/ittf/PubliclyAvailableStandards/MPEG-DASH_schema_files/DASH-MPD.xsd"
      type="dynamic"
      availabilityStartTime="1970-01-01T00:00:04Z"
      publishTime="2024-03-28T11:58:40.525606Z"
      minimumUpdatePeriod="PT2S"
      timeShiftBufferDepth="PT12H"
      maxSegmentDuration="PT4S"
      minBufferTime="PT10S"
      profiles="urn:mpeg:dash:profile:isoff-live:2011,urn:com:dashif:dash264">
      <Period
        id="1"
        start="PT0S">/
        <BaseURL>hmac=blabla/</BaseURL>
        <AdaptationSet
          id="1"
          group="1"
          contentType="audio"
          lang="en"
          segmentAlignment="true"
          audioSamplingRate="48000"
          mimeType="audio/mp4"
          codecs="mp4a.40.2"
          startWithSAP="1">
            schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011"
            value="2" />
          <ContentProtection
            value="cenc"
          <!-- PlayReady -->
          <ContentProtection
            schemeIdUri="urn:uuid:9A04F079-9840-4286-AB92-E65BE0885F95"
            value="MSPR 2.0">
            <cenc:pssh>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</cenc:pssh>
            <mspr:IsEncrypted>1</mspr:IsEncrypted>
            <mspr:IV_Size>8</mspr:IV_Size>
            <mspr:kid>si/7D+4yzz7Oc3CfuO2k+g==</mspr:kid>
            <mspr:pro>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</mspr:pro>
          <!-- Widevine -->
          <ContentProtection
            schemeIdUri="urn:uuid:EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED">
            <cenc:pssh>AAAAdnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFYIARIQD/svsjLuPs/Oc3CfuO2k+hIQjoVHQPCqOTDST0WRPYmUsRIQfK6G1ajaFFUj30FLsjZLyhoMa3JlYWRpZ2l0dXJrIg5ibXByZW1pZXJlb3JnZA==</cenc:pssh>
          <Role schemeIdUri="urn:mpeg:dash:role:2011" value="main" />
          <SegmentTemplate
            timescale="48000"
            initialization="bmpremiereorgd-$RepresentationID$.dash"
            media="bmpremiereorgd-$RepresentationID$-$Time$.dash">
            <!-- 2024-03-27T23:58:31.960000Z / 1711583911 - 2024-03-28T11:58:35.800000Z -->
            <SegmentTimeline>
              <S t="82156027774080" d="184320" r="11250" />
            </SegmentTimeline>
          </SegmentTemplate>
          <Representation
            id="audio_eng=128000"
            bandwidth="128000">
          </Representation>
        </AdaptationSet>
        <AdaptationSet
          id="2"
          group="2"
          contentType="video"
          par="16:9"
          minBandwidth="240000"
          maxBandwidth="1800000"
          maxWidth="1280"
          maxHeight="720"
          sar="1:1"
          frameRate="25"
          mimeType="video/mp4"
          startWithSAP="1">
          <ContentProtection
            value="cenc"
          <!-- PlayReady -->
          <ContentProtection
            value="MSPR 2.0">
          <!-- Widevine -->
          <ContentProtection
          <SegmentTemplate
            timescale="600"
            <SegmentTimeline>
              <S t="1026950347176" d="2304" r="11250" />
            </SegmentTimeline>
          </SegmentTemplate>
          <Representation
            id="video=240000"
            bandwidth="240000"
            width="416"
            height="234"
            codecs="avc1.4D400D"
            scanType="progressive">
          </Representation>
          <Representation
            id="video=760000"
            bandwidth="760000"
            width="768"
            height="432"
            codecs="avc1.4D401E"
          </Representation>
          <Representation
            id="video=1800000"
            bandwidth="1800000"
            width="1280"
            height="720"
            codecs="avc1.4D401F"
          </Representation>
        </AdaptationSet>
      </Period>
      <UTCTiming
        schemeIdUri="urn:mpeg:dash:utc:http-iso:2014"
        value="https://time.akamai.com/?iso" />
    </MPD>
  14. Well your PSSH is right there:
    Aug 2023
    Turkey
    --key 13731d37881b464cbc934c64b8e1385d:1dfeda89c5534cf60 6c7b3a962171d1e
    i was auchso think thad coreckt bud its not
    this its coreckt kid normal bud cant get coreckt pssh for this
  16. Originally Posted by senkron24 View Post
    which tool you used to obtain keys? online sites? Uncheck cache
    Aug 2023
    Turkey
    my own cmd
    WKS-KEYS
  18. The Key ID you posted in Post #1 was for the W3 Common Encryption.
    The PSSH from Widevine i posted contains 3 Key IDs. Even though the Key ID you posted was the first in the Widevine PSSH, there were 2 more Key IDs inside
    8e854740-f0aa-3930-d24f-45913d8994b1
    7cae86d5-a8da-1455-23df-414bb2364bca
    and a specific content ID and provider were also specified.
    Aug 2023
    Turkey
    yes exackt thad so
    i think this first one its widevine
    0FFB2FB232EE3ECFCE73709FB8EDA4FA
    7cae86d5a8da145523df414bb2364bca
    8e854740f0aa3930d24f45913d8994b1
  20. A Key ID can't be "just widevine". Widevine and such are just ways of getting from having a key id to obtaining a key, implemented by different DRM Systems (i.e.: Widevine (Google), PlayReady (Microsoft), FairPlay (Apple) or even smaller ones like Marlin DRM or Axinom DRM).
  21. BTW an easy way of finding the PSSH from an MPD, whether it's in the MPD manifest itself or in the init segment, is with dash-mpd-cli with the "-v" option. For example with a 6play MPD from another thread today:
    % dash-mpd-cli -v "https://6play.vod.6cloud.fr/m6web/output/1/7/c/17cb27dac7a89a1ecdd88ab095c46b9330f7c386/static/13060525_1fc8df7b21f77198842ad3e55dc5bf4c_web_dash_upTo720p_720p_vbr_cae_drm_software.mpd"
    20:07:29  INFO Fetching the DASH manifest
    20:07:29  INFO DASH manifest has 1 period
    20:07:29  INFO Streams in period 1 (#1), duration 6070.200s:
    20:07:29  INFO   audio mp4a.40.2         |    93 Kbps |  lang=fra role=main label=LV
    20:07:29  INFO   video avc1.42C01E       |   233 Kbps |   400x224 role=main
    20:07:29  INFO   video avc1.64001F       |   500 Kbps |   640x360 role=main
    20:07:29  INFO   video avc1.64001F       |   918 Kbps |   720x404 role=main
    20:07:29  INFO   video avc1.64001F       |  1405 Kbps |   960x540 role=main
    20:07:29  INFO   video avc1.64001F       |  2106 Kbps |  1280x720 role=main
    20:07:29  INFO Preparing download for period 1 (#1)
    20:07:29  INFO   Audio stream selected: bw=93 Kbps lang=fra codec=mp4a.40.2
    20:07:29  INFO   Video stream selected: bw=233 Kbps resolution=400x224 codec=avc1.42C01E
    20:07:29  INFO   ContentProtection: cenc
    20:07:29  INFO     KID: 5C1A1123DCE22353983CBF0822586093
    20:07:29  INFO   ContentProtection: Widevine
    20:07:29  INFO     PSSH (from manifest): AAAAWnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADoIARIQXBoRI9ziI1OYPL8IIlhgkyIkZXlKaGMzTmxkRWxrSWpvaVkyeHBjRjh4TXpBMk1EVXlOU0o5
    20:07:29  INFO     WidevinePSSH<Aesctr, key_id: 5c1a1123dce22353983cbf0822586093, content_id: "65794a6863334e6c64456c6b496a6f6959327870634638784d7a41324d4455794e534a39">
    20:07:29  INFO   ContentProtection: PlayReady
    20:07:29  INFO     PSSH (from manifest): 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
    20:07:29  INFO     PlayReadyPSSH<PlayReadyPsshData<RightsManagementRecord: <WRMHEADER xmlns="http://schemas.microsoft.com/DRM/2007/03/PlayReadyHeader" version="4.0.0.0"><DATA><KID>IxEaXOLcUyOYPL8IIlhgkw==</KID><PROTECTINFO><KEYLEN>16</KEYLEN><ALGID>AESCTR</ALGID></PROTECTINFO><CHECKSUM>C8ve9UC9RYs=</CHECKSUM><LA_URL>https://lic.drmtoday.com/license-proxy-headerauth/drmtoday/RightsManager.asmx</LA_URL><LUI_URL>https://playready-ui.example.com</LUI_URL></DATA></WRMHEADER>>>
    20:07:29  INFO     PSSH (from init segment): AAAAWnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADoIARIQXBoRI9ziI1OYPL8IIlhgkyIkZXlKaGMzTmxkRWxrSWpvaVkyeHBjRjh4TXpBMk1EVXlOU0o5
    20:07:29  INFO Period #1: fetching 3036 audio, 2025 video and 0 subtitle segments
    You want the Widevine PSSH rather than the PlayReady PSSH, of course.
  22. Member
    Aug 2023
    Turkey
    I'm trying to understand
    So do you have any suggestions?
    I'm so confused, I feel like I'm in a dead end street
  23. Haven't you achieved what you were trying to do?
    You were trying to obtain a PSSH from an MPD file and i helped you do that, now i don't get what you're asking for.
  24. Member
    Aug 2023
    Turkey
    waww ı have try this bud not working on me
    =ac63906744_127659~hmac="
    [0s] [>-------------------------------------------------] Fetching DASH manifest
    11:24:43 INFO Fetching the DASH manifest
    11:24:43 ERROR Download failed: invalid media stream: Don't know how to download dynamic MPD
    i try with your link its working great
  25. Member
    Aug 2023
    Turkey
    Thank you very much, you are trying to help.
    However, none of the methods I have tried so far have worked.
  26. Originally Posted by senkron24 View Post
    For a dynamic manifest (these are generally used for "live" streaming, rather than replay), you'll need to add the option "--enable-live-streams". If it's a true live stream, dash-mpd-cli probably won't be able to download the content properly, because it doesn't implement the clock-based throttling necessary to wait until new segments become available. However, some streams are announced as live but in fact all segments are available, and those are likely to work. Even if it can't download the full stream, it should print the PSSH information.
  27. Member
    Aug 2023
    Turkey
    ooo yeah i see it now i just chack now big thanks my freand
  28. Member
    Aug 2023
    Turkey
    12:02:51  INFO Fetching the DASH manifest
    12:02:52  WARN Attempting to download from live stream (this may not work).
    12:02:52  INFO DASH manifest has 1 period
    12:02:52  INFO Streams in period 1 (#1), duration 0.000s:
    12:02:52  INFO   audio mp4a.40.2         |   125 Kbps |   lang=en role=main
    12:02:52  INFO   video avc1.4D400D       |   234 Kbps |   416x234 role=main
    12:02:52  INFO   video avc1.4D401E       |   742 Kbps |   768x432 role=main
    12:02:52  INFO   video avc1.4D401F       |  1757 Kbps |  1280x720 role=main
    12:02:52  INFO Preparing download for period 1 (#1)
    12:02:52  INFO   Audio stream selected: bw=125 Kbps lang=en codec=mp4a.40.2
    12:02:52  INFO   ContentProtection: cenc
    12:02:52  INFO     KID: 0FFB2FB232EE3ECFCE73709FB8EDA4FA
    12:02:52  INFO   ContentProtection: PlayReady
    12:02:52  INFO     PSSH (from manifest): 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
    12:02:52  INFO     PlayReadyPSSH<PlayReadyPsshData<RightsManagementRecord: <WRMHEADER xmlns="http://schemas.microsoft.com/DRM/2007/03/PlayReadyHeader" version="4.0.0.0"><DATA><KID>si/7D+4yzz7Oc3CfuO2k+g==</KID><PROTECTINFO><KEYLEN>16</KEYLEN><ALGID>AESCTR</ALGID></PROTECTINFO><CHECKSUM>3+xLIc4E0+4=</CHECKSUM><LA_URL>https://pr-castleblack.digiturk.com.tr/Rightsmanager.asmx</LA_URL></DATA></WRMHEADER>>>
    12:02:52  INFO   ContentProtection: Widevine
    12:02:52  INFO     PSSH (from manifest): AAAAdnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFYIARIQD/svsjLuPs/Oc3CfuO2k+hIQjoVHQPCqOTDST0WRPYmUsRIQfK6G1ajaFFUj30FLsjZLyhoMa3JlYWRpZ2l0dXJrIg5ibXByZW1pZXJlb3JnZA==
    12:02:52  INFO     WidevinePSSH<Aesctr, key_ids: 0ffb2fb232ee3ecfce73709fb8eda4fa, 8e854740f0aa3930d24f45913d8994b1, 7cae86d5a8da145523df414bb2364bca, content_id: "626d7072656d696572656f726764", provider: "kreadigiturk">
    12:02:52  INFO     PSSH (from init segment): AAAAdnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFYIARIQD/svsjLuPs/Oc3CfuO2k+hIQjoVHQPCqOTDST0WRPYmUsRIQfK6G1ajaFFUj30FLsjZLyhoMa3JlYWRpZ2l0dXJrIg5ibXByZW1pZXJlb3JnZA==
    12:02:52  INFO   Video stream selected: bw=234 Kbps resolution=416x234 codec=avc1.4D400D
    12:02:52  INFO Period #1: fetching 11252 audio, 11252 video and 0 subtitle segments
    [65s] [#>------------------------------------------------] Fetching audio segments (0.6 MB/s)
    now i get samthing
    same problem
    i get wrong keys on any pssh
  29. Member
    Aug 2023
    Turkey
    ahhh now i think understand why
    also i was able download one movie with coreckt pssh and key
    and think for every lisance request you need for this the right
    'X-ErDRM-Message':
    if this from other movie you not get the right keys
    'X-ErDRM-Message': must be from same move get it
    i have to lock how i can requset the right 'X-ErDRM-Message':
    bud will try to undertand again if i am sure i will give the result here
    not : yes i can confirm for each movie must be new token generate otherway you not get coreckt key..
    thank for all help me to found out whats problem
