Does anyone here know if this audio card supports midi hardware playback,i have an audigy rx 5 that plays midi files.Searched google but no midi playback mentioned.
Results 1 to 10 of 10
Just got the card and installed it and no support for midi play back.
Page 44 of the manual mentions midi settings, so while it is not really the focus of these cards anymore, it is pretty simple & fundamental to that whole series/family of chipsets. Easy to include. It's probably just hidden, and you will need a good dedicated midi file player or sequencer to get good results.
Scott -
I got a midi player installed that does the same job,CoolSoft_VirtualMIDISynth_2.13.7.
My Creative Sound Blaster X-Fi
[Attachment 78033 - Click to enlarge] plays midi files. But it is a little stand alone black box device, not a card. It's about 20 years old but still worksExtraordinary claims require extraordinary evidence -Carl Sagan -
I thought you meant my Creative Sound BlasterX AE-5,the audigy rx 5 is card i replaced which had midi support.
You said, "I have an ...rx5...".
Wasn't clear that you were replacing it. Why replace it if it works?
Looking at that model, no it doesn't have a dedicated midi synth sound chip. But that's probably because the card is geared more towards high end gaming.
However, you don't really need a dedicated chip, all you need is a software Synthesizer that can play midi files. Computers have improved so much since the old SB models that a dedicated chip isn't necessary as long as your CPU is decent enough. There seems to be a bunch of soft syth options available for download, including a few that are listed as free. I would go for one with DL soundfont support.
Hope that helps.
Scott -
I replaced the card cause i do high end gaming,the rx was sometimes getting problems with midi outputs just vanishing due to driver conflicts.
OLD computer, can't select a default MIDI dvice
By Rekrul in forum Software PlayingReplies: 1Last Post: 24th Oct 2023, 11:09 -
is there a way to control midi volume in windows?
By sommers in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2022, 02:59 -
Where can I get a real midi-to-wav converter software?
By Videogamer555 in forum AudioReplies: 9Last Post: 9th Jan 2022, 10:16 -
How can I record from stereo mic with Creative SB1506 Sound Blaster Zx
By Truthler in forum AudioReplies: 1Last Post: 10th Oct 2021, 02:56 -
creative sound card
By flannob in forum AudioReplies: 2Last Post: 27th Mar 2020, 20:29
