How to capture a snapshot in MPC-HC without the black lines at the top and at the bottom?
Here is the example, attached.
The video has the black lines at the top and at the bottom.
I want to capture a snapshot of only the video itself, without the black spaces (lines).
Is there any way to accomplish this?
Thanks.
What i do is click on prt scn and i get the option to only copy the image and paste in my paint app.Not sure if windows 10 can do this since i'm on windows 11.
I know, it is possible via special manipulations. I am using FastStone Capture for this.
But, here, I dont want any manual image editing.
I want to just press F5 (Snapshot autosave) and it will do the thing for me.
Important to mention
that the black areas are a part of the video itself, not becouse I stretch a player's frame.
In a Dolby Vision thread at the Doom9 forums, a border detection tool (DetectBorders.exe) is mentioned. I understand Doom9 forums member named Atak_Snajpera wrote it. He is member here at VH too. Maybe he can chime in and tell if implementing his tool for screen capture or application snapshot is possible.
Just mentioning, but do note that when using the "print screen" button on the keyboard, the image being copied to the clipboard can have an other-than-source resolution. For example, imagine playing a 4K video on a 1920x1080 pc-monitor. Print-screen button will yield a 1920x1080 picture. At least, on my Windows machine it does. Whereas "taking a snapshot" - as a feature of the player application - can be set to take the frame in it's native (here 4K) resolution.Last edited by Ennio; 28th Mar 2024 at 05:37.
If the black bars are part of the video they will be in the screenshot, Just use any image editor including the one that comes with you OS and crop the black bands. Like everyone said above, if you want an automated way, script approach is your best bet.
How to set a snapshot file path to the current folder in MPC-HC?
By monstro in forum Software PlayingReplies: 2Last Post: 28th Mar 2024, 04:01 -
Black Lines in night sky
By United61 in forum EditingReplies: 4Last Post: 28th Jan 2023, 01:18 -
ConvertToYV12 is smudging out black lines
By killerteengohan in forum RestorationReplies: 1Last Post: 5th May 2021, 12:21 -
MPC-HC & MadVR - Vertical black lines while playing some videos
By vidblue in forum Software PlayingReplies: 3Last Post: 6th Dec 2019, 03:31 -
Jagged lines and no subtitles on MPC-HC
By jericjan in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2019, 05:09
