I have been burning an SVCD disk with Nero 5.5.8.0
I made two MPEG2 files with TMPGEnc using the normal template rate 2520kb/s
I usually burn these file with Nero using the "try to fit to disk size" encoding bit rate.
But I just tried the "user defined" which lets you elect a rate. I selected 255KB/s out the the selections (there was no 2520) All PAL
With the "fit disk size" I can fast forward x2, x4,x8 on my standalone DVD and have no problems
but with the "user defined" using Fast forward on the DVD often ends with a jump between files or locked in a loop in a file.
Any ideas on why this happens??
Results 1 to 1 of 1
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Vegas, Xvid Encoding, Max Bitrate 56kbit only
By kidcash in forum AudioReplies: 3Last Post: 26th Dec 2007, 00:08 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 17:12
