    Mar 2024
    Cairo, Egypt
    Has anyone tried dumping cdm from note 8 pro?
    the script doesn't work, it hangs on (functions hooked, play the stream..etc)
    I tried specifying cdm version and functions one by one, same thing.
    Feb 2022
    Search the forum first!
    You need to search the forum for function names to use in dump.js. If there are none that work for you, inspect libwvhidl.so and find the ones that your device has.
    All this has been answered before.
    Search!
    Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
    Mar 2024
    Cairo, Egypt
    Search!
    I did search, and as I said, I tried all functions retrieved from libwvhidl.so "thanks to ss vegeta".
    So I posted this in case someone has the same device and figured it out.
    Feb 2022
    If it still didn't work for ~me~ I would think I was doing something wrong. But you say it is 'dump.js' that doesn't work.
    You say you've trield 'all the functions', but from 'which' libwvhidl.so' is the question?
    To be sure you have the correct function names trust nothing and look at your libwvhidl.so with a hex editor. The method has been posted.
