Hi,
I have a good subtitle file that is perfectly synchronized for the 25 FPS version of the film (but the film is not is HD).
I have found a HD version of the film, that is at 24 FPS: of course, the subs are not correctly synchronized because they have been synchronized for the 25 FPS version of the film.
Is there an easy way to adapt the subtitle file to the new speed of the film (24FPS) ? or should I have to manually re-synchronize the subs ?
Thank you very much,
Open the subtitle in Subtitle Edit
synchronization/change frame rate -
Well, maybe my question is not clear...
I have found a HD video (24FPS) of a film that I previously had in 25FPS (non HD).
My subtitles are perfect for a 25FPS version.
But is there a way to adapt the ".srt" file to the HD 24FPS version of the film ?
Because your solution change the video frame rate, so it would result in a HD 25FPS film, wouldn't it ?
Thank you very much, -
No, it is the ".srt" file that I have created myself.Is the subtitle you have embedded in the video?
I am not 100%, but it is what I have probably done because the subs remain perfectly synchronized with the 24 FPS film.Open the subtitle in SE and resync from 25 > 24 as I mentioned. That will retime (slow down) the subs, then
save as a new sub
The confusion (in my mind) comes from the fact that I believed that the video itself was slow down (not the subs), whereas it appears that the video remains unchanged and the subs are slow down: it is exactly what I need !
Thank you very much for your help
Post a subtitle for an existing video.
By loninappleton in forum SubtitleReplies: 7Last Post: 3rd Mar 2024, 02:09 -
i wont convert video from youtube and translate subtitle and audio
By avchd4k in forum Video ConversionReplies: 1Last Post: 30th Sep 2022, 13:58 -
VSDC - how to convert a file with several existing subtitles
By ronstephen in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2022, 07:45 -
Sync audio/video of Animation/Cartoon Bluray -> video speed VS audio speed
By precipizio in forum Blu-ray RippingReplies: 4Last Post: 14th Dec 2021, 11:07 -
Speed up video to restore original playback speed?
By nekrosoft13 in forum Video ConversionReplies: 6Last Post: 30th Nov 2019, 01:16
