Does anybody know why a computer (running Windows XP, and bought before 2005) would suddenly have problems connecting to the Internet after replacing the power supply?
Everything that was connected from the old power supply is connected from the new power supply, too. And it makes no difference whether I tweak the BIOS or just 'Load Default Values'. Everything else seems to work, but the Ethernet port.
I did not delete anything, nor do I have any viruses.
I just changed the power supply.
The error is that the Local Connection icon keeps alternating between the computers with the red 'X' (- no connection -) and the computers with the yellow moving circle (- connecting -).
Most of the time, it's on "no connection", but in between it seems to want to be connecting.
The only issue I can think of is that the previous power supply was up to 350W, and this new one is up to 250W, but the PC should work even with a 250W supply.
Thank you.
AnonymousGuest
the only thing i can think of;
Maybe you damaged the network cable?
Or the network controller is under powered due your lower wattage power supply?
Power supply standards are changed so your 20 year old hardware might not match newer standards?
I own a recent motherboard (intel 1151) that refuses to boot with a modern power supply but does with a 15 year old one -
Yongnuo YN600 LED light power supply 8 volt?
By Kenny202 in forum Newbie / General discussionsReplies: 7Last Post: 8th Feb 2024, 13:21 -
By Anonymous84 in forum ComputerReplies: 18Last Post: 2nd Dec 2023, 07:28 -
What power supply do i need for my VCR?
By Master Tape in forum Newbie / General discussionsReplies: 20Last Post: 14th Dec 2022, 16:59 -
TV Power Supply Most Likely Dead
By cornemuse in forum Newbie / General discussionsReplies: 25Last Post: 22nd Oct 2020, 11:39 -
Blackmagic DeckLink Multibridge SD power supply?
By produtronrex in forum Capturing and VCRReplies: 0Last Post: 5th Jun 2020, 12:14
