    Mar 2024
    London
    Hi everyone,
    Fairly new to video editing, been using VideoStudio Ultimate 2023 for about 6 months without any problems but have just starting experiencing a problem with the frame rate of files I am running through VS. I have also downloaded OBS Studio to compare the same sample video.
    When I use OBS and view the MP4 file through windows media player the file is fine but when I bring the file into VS Capture and play the file, the frame rate is slower?
    Any ideas or would I need to provide more details of my set or upload two samples to better show the issue?
    Many thanks in advance for any expert advice
    David
    Mar 2024
    London
    Hi all,
    Any ideas please
    Thanks in advance
  3. Looks like you are not getting any answers. Try their support page: https://www.videostudiopro.com/en/support/
    You could also post the mediainfo of your file here. Maybe someone will be able to help by looking at that info.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  4. Sorry for kind of ressurecting a semi-old thread, but i found this post when searching for the same issue, and then found the Corel page that may provide the answer for you. Tested it myself and so far it seems like it has done the trick. Hopefully it will help you and anyone else that stumbles upon this thread.
    https://kb.corel.com/130102
    Aug 2024
    Brisbane
    I have the issue described by @Colt374 (choppy video when rendering some types of file, eg 4k video, but not some other formats - it would repeat some frames, and miss others, giving a jerky output). I had raised the issue with Corel who asked for samples of video, but meanwhile found this page and I applied the hotfix mentioned in https://kb.corel.com/130102. It seems to work now, at least after a brief test. I have sent my response to the Corel team to see if this is what is OK by them or if it has been superseded.
    If this is a known issue, its a pity they didnt roll out this update available generally, rather than making us spend many hours experimenting and trying to track the problem down.
