Has anyone fitted one of these
https://i.ebayimg.com/images/g/YNEAAOSwHIllgZbi/s-l1600.jpg
How did you cope with the magnified image on the screen, didn't expect that, I've taken it off again until I've asked around
Not sure about the link/screen in your post, KVM seems to be a outdated VGA port ?
I have very good experience with below KVM switches
KVM 1 from Ugreen
KVM 2 from Mleeda (Wired Remote included)
Hope this helps somehow. -
It may be more useful to link to the actual splitter rather than a pic of it. (and fleabay is not the best place to acquire anything like this since it will hardly describe the item adequately)
Possible that you over-estimated its potential and it merely sends the image from one PC rather than an independant image from both as determined by each PC's graphics. -
I appreciate what you say, there's not much detail i can put up, it's a bit lacking in that, it's meant to to switch from one computer or the other using just the one screen, it's just that the image comes up a little bigger than normal. Looks like I'm going to have to set it up again and play with it. -
Not sure why you think this is necessary.
You could easily connect 2 PCs to one monitor, since most monitors have multiple inputs. Simply connect 1 PC to the Displayport input, another PC to the HDMI, or USB -C, input. Then use the input selection button to switch between the inputs.
Scott -
Old CRT monitor shows scan lines near bottom on the monitor
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 30th Jan 2024, 16:20 -
How do you install in x264 8 bit codec on Windows computers?
By Guernsey in forum Video ConversionReplies: 14Last Post: 12th Oct 2022, 01:58 -
Which player today is high quality and recommended for new computers?
By kjkjk32 in forum Software PlayingReplies: 6Last Post: 14th Oct 2020, 16:28 -
Vegas Pro ... how many computers can I install it on?
By Gromit137 in forum EditingReplies: 14Last Post: 22nd Jun 2019, 10:01 -
Question how to make audio out/in jumper for Windows 1-jack computers
By jimdagys in forum AudioReplies: 3Last Post: 25th Mar 2019, 16:39
