I would like to watch a TV program in one audio language while my partner watches in a different language, eg using bluetooth headphones.
I am about to buy a new TV, does anyone know if such a feature is available ?
If not, any way to achieve the desired result?
Usually in TV broadcasts you can select the audio track, but I doubt that the TV itself will allow you to split into 2 separate sounds. Either you will need some additional device or a second TV)
You can add an additional TV boxset that would have the same program and if there is a dual language option, then this might work. But this could mean an additional subscription payment, depending on your TV provider.
For example, Arte HD channel broadcast in French and German.
How to split dual language subtitle?
By vgallotti in forum SubtitleReplies: 3Last Post: 5th Feb 2024, 16:00 -
Redirect language DVD buttons to 1 language
By Anonymous847344 in forum Authoring (DVD)Replies: 15Last Post: 4th Dec 2022, 23:05 -
Adding a second language track
By Undertaker666 in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2021, 08:20 -
How to bulk remove "style" (or dual language subtitle for that matter)
By shadiow in forum SubtitleReplies: 1Last Post: 4th Sep 2020, 12:20 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 06:43
