Just got the movies "The Green Mile" and "Cast Away" on my PC in .VOB.
Put them through DVD2AVI; got the .AVI, but no sound. It says about at 50% of the way through the conversion that an error occurred while encoding sound or something like that. I'm using the "standard" conversion method on this program (DVD2AVI). I don't know what to do. Any help? Thanks!
With his senses keen, don't fail to watch your back. For when the time is right, Wolf will be there for the final attack...
select demux instead of decode & use external tools to decode/downmix/downsample the ac3 audio. azid & ssrc or besweet is popular
Perhaps the best place to start would be to delete then reinstall DVD2AVI and try it again. Maybe something got deleted or corrupted somewhere?
once u load the vob files into dvd2avi, preview it (f5) and post what dvd2avi says about the audio info
LOL>>>>try using channel 2 for your audio track in dvd2avi ur probably getting dts sound under channel 1! good luck PEACE
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
