As per the title description, I'm wanting to copy a part of the audio track which was extracted from a video using ffmpeg.
I don't have exact times for the beginning and ending of the wanted portion of audio. So I think I'll have to use a GUI controlled audio editor to see the audio waveform and then select the beginning and ending of the wanted portion of audio.
Thought this would be an easy procedure, but it is turning out to be difficult!
I have already tried using Audacity, ocenaudio, and also Goldwave. I'm having trouble placing "markers" (accurately) for the beginning and end of the wanted audio clip using all of these editors. Also, it is not clear on how to actually copy the clip between the markers and discard the rest of the audio clip? The 'help' option for these editors (where available) were not really helpful and not really clear on the procedure.
So, what is an easy to use GUI audio editor that will allow precise 'marker' placement and easy to copy/export the wanted audio portion and discard the rest of the audio content?
In Audacity, open your file. Anywhere on one of the tracks, left drag to create a light-coloured selection. Adjust the exact position of either or both edge/s with the mouse pointer; it will change to a finger when you touch the edge of the selection; then left click-drag it.
Then export as @Ennio says.Last edited by Alwyn; 21st Mar 2024 at 03:39.
Thanks for the (detailed) comments!
Sort of got the hang of using Audacity to extract a portion of the audio clip now! Initially I found Audacity a bit difficult to use, it is not really user friendly from my point of view. Just starting to get using Audacity more effectively and more efficiently now.
M3u8: Audio track or video track but never both?
By undercash in forum Newbie / General discussionsReplies: 0Last Post: 21st Feb 2023, 07:49 -
Edit Video Track Separately From Audio Track in VideoPad
By meandersleut in forum EditingReplies: 0Last Post: 12th Sep 2022, 13:11 -
tsMuxeR extracted ts file audio shorter than video length problem
By Tsubasa in forum Newbie / General discussionsReplies: 10Last Post: 3rd Aug 2022, 12:20 -
how to download a portion of video from m3u8 that has separate video audio.
By adi111 in forum Video Streaming DownloadingReplies: 8Last Post: 5th Aug 2020, 15:53 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 07:43
