Hi guys,
I tried different methods to download a video from RTL Play, with no success so far...
The link to the video (site requires login) is:
https://www.rtlplay.be/rtl-info-19h-p_8553/rtl-info-19-heures-17-03-24-c_13060570
Any suggestion to solve this issue is very welcome. Thanks!
Closed Thread
Results 1 to 11 of 11
I dunno if there are other hidden resolutions. 540p seems kinda low.Code:
N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/7/3/3/733fa22e3084dcfe5041b9a7676f3f6ff33cd8d2/static/13060570_45ac1622cd59e0850d31e366f7e72f10_web_dash_upTo540p_540p_vbr_cae_drm_software.mpd" --key fe1a9855ba37381ba7c2f70b6eba1238:554d1b2b12bb01659a32341284d402f6 -M format=mkv
Here is the downloader for https://www.rtlplay.be . It works only for free videos that don't have geographic restrictions. In theory, it should work for those as well if you have a good IP, but I don't know for sure because I couldn't test it (even with a free VPN). The script requires a mail/password.
Output:Code:import json import re import urllib.parse import requests from pywidevine.cdm import Cdm from pywidevine.device import Device from pywidevine.pssh import PSSH EMAIL = 'YOUR_EMAIL' PASSWORD = 'YOUR_PASSWORD' COOKIE_URL = 'https://cdn.cookielaw.org/consent/{consent_id}/{resource}' LAYOUT_URL = "https://layout.6cloud.fr/front/v1/rtlbe/m6group_web/main/token-web-3/video/{video_id}/layout" JWT_URL = 'https://front-auth.6cloud.fr/v2/platforms/m6group_web/getJwt' LOGIN_URL = 'https://accounts.eu1.gigya.com/accounts.login' TOKEN_URL = "https://drm.6cloud.fr/v1/customers/rtlbe/platforms/m6group_web/services/rtlbe_rtl_info/users/{user_id}/videos/{video_id}/upfront-token" def get_api_key(): consent_id = re.search( r'data-domain-script="([^"]*)"', requests.get("https://www.rtlplay.be").content.decode() ).group(1) response = json.loads(requests.get( COOKIE_URL.format(consent_id=consent_id, resource=f'{consent_id}.json') ).content.decode()) consent_ids = [rule["Id"] for rule in response["RuleSet"]] response = json.loads(requests.get( COOKIE_URL.format(consent_id=consent_id, resource=f'{consent_ids[0]}/fr.json') ).content.decode()) api_keys = [] for group in response["DomainData"]["Groups"]: for cookie in group["FirstPartyCookies"]: if "gigya" not in cookie["Host"]: continue api_keys.append(cookie["Name"]) api_key = api_keys[0] return api_key[api_key.index("_") + 1:] API_KEY = get_api_key() RES_PRIORITY = {"sd": 0, "hd": 1} LICENSE_URL = "https://lic.drmtoday.com/license-proxy-widevine/cenc/" WVD_FILE = "./device_wvd_file.wvd" def get_auth_info(): response = json.loads(requests.post( LOGIN_URL, headers={'Content-Type': 'application/x-www-form-urlencoded'}, data=f'loginID={urllib.parse.quote(EMAIL)}&password={PASSWORD}&sessionExpiration=-2&APIKey={API_KEY}&format=json' ).content.decode()) user_id = response["UID"] jwt_token = json.loads(requests.get(JWT_URL, headers={ 'X-Customer-Name': 'rtlbe', 'x-auth-device-id': 'x-auth-device-id', 'X-Auth-gigya-uid': user_id, 'X-Auth-gigya-signature': response["UIDSignature"], 'X-Auth-gigya-signature-timestamp': response["signatureTimestamp"] }).content.decode())["token"] return user_id, jwt_token USER_ID, JWT_TOKEN = get_auth_info() def format_manifest(manifest): split_path = "/rtl.be/" base_url, path_url = manifest.split("?")[0].split(split_path) base_url = base_url.split("/resource/")[0] base_url = "https://rtlbe.vod" + base_url[base_url.index("."):] return f"{base_url}{split_path}{path_url}" def get_video_data(source_url, format_mpd=False): video_id = re.search( r"(c_[^_]+)$", source_url ).group(1).replace("c_", "clip_") video_token = json.loads(requests.get( TOKEN_URL.format(user_id=USER_ID, video_id=video_id), headers={'Authorization': f'Bearer {JWT_TOKEN}'} ).content.decode())["token"] response = json.loads(requests.get( LAYOUT_URL.format(video_id=video_id), headers={'Authorization': f'Bearer {JWT_TOKEN}'} ).content.decode()) if "geoBlocked" in str(response): print("VPN Failure") exit(0) manifests = [] for block in response["blocks"]: if ".mpd" not in str(block): continue try: for item in block["content"]["items"]: item_content = item["itemContent"] if "video" not in item_content.keys(): continue video_content = item_content["video"] if video_content["id"] != video_id: continue for asset in video_content["assets"]: if asset["video_container"] != "mpd" or asset["format"] != "dashcenc": continue manifest = (asset["quality"].lower(), asset["path"]) if manifest not in manifests: manifests.append(manifest) except: pass if len(manifests) == 0: print("No MPD found for: ", source_url) exit(0) manifest = sorted(manifests, key=lambda m: RES_PRIORITY[m[0]], reverse=True)[0][1] if format_mpd: manifest = format_manifest(manifest) try: pssh_value = str(min(re.findall( r'<cenc:pssh\b[^>]*>(.*?)</cenc:pssh>', requests.get(manifest).content.decode() ), key=len)) except: return manifest, None, None return manifest, pssh_value, video_token def get_keys(pssh_value, video_token): if pssh_value is None: return [] pssh = PSSH(pssh_value) device = Device.load(WVD_FILE) cdm = Cdm.from_device(device) cdm_session_id = cdm.open() challenge = cdm.get_license_challenge(cdm_session_id, pssh) licence = requests.post( LICENSE_URL, data=challenge, headers={'x-dt-auth-token': video_token} ) licence.raise_for_status() licence = json.loads(licence.content.decode())["license"] keys = [] cdm.parse_license(cdm_session_id, licence) for key in cdm.get_keys(cdm_session_id): if "CONTENT" in key.type: keys += [f"{key.kid.hex}:{key.key.hex()}"] cdm.close(cdm_session_id) return keys def get_download_command(source_url, format_mpd=False): manifest, pssh_value, video_token = get_video_data(source_url, format_mpd) keys = get_keys(pssh_value, video_token) if len(keys) == 0: return f'N_m3u8DL-RE.exe "{manifest}" -M format=mkv' return f'N_m3u8DL-RE.exe "{manifest}" {" ".join([f"--key {k}" for k in keys])} -M format=mkv' SOURCE_URLS = [ "https://www.rtlplay.be/rtl-info-19h-p_8553/rtl-info-19-heures-19-03-24-c_13060945", "https://www.rtlplay.be/francois-lembrouille-le-best-ouf-p_9043/embrouilles-dinterieures-c_11932445", "https://www.rtlplay.be/linvite-de-7h50-p_8655/georges-louis-bouchez-20-03-c_13060982", "https://www.rtlplay.be/le-good-morning-p_8661/emission-du-19-03-c_13060858", "https://www.rtlplay.be/francois-pirette-p_11851/francois-pirette-les-annees-vhs-du-06-03-c_13058955" ] for s in SOURCE_URLS: print(get_download_command(s, format_mpd=True))
I managed to find the manifest for the highest resolution by using their API but it's kinda useless if you can't decrypt the content. The key you get works for resolutions lower than 720p (in some cases it works even for 720p but rarely). I don't know if I'm doing something wrong with the license call or after a certain date, they added L1 for newer videos at higher resolutions. Maybe someone can shed some light on this issue.Code:N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/5/b/1/5b113d633a6658b8ddf74843405061f47bbf0d01/static/13060945_b836123e75b7e4c7f80e7990b3892f87_web_dash_upTo1080p_720p_vbr_cae_drm_hardware.mpd" --key d480f359451b601d8d6b6e5657b364dc:c6567ab778d6588896d15c4eb4cd5b45 -M format=mkv N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/d/a/f/daf8a3aa75e55ebcb9a30abe06e4f856d197269bd85118b33bc12caa6520ff6a/daf8a3aa75e55ebcb9a30abe06e4f856d197269bd85118b33bc12caa6520ff6a_web_drm_hd_dash_v2.ism/Manifest.mpd" --key 921dc2f5ff4ff9feb16e199cfe35ec4c:52d25bcf90d6be5ffe3691e9b7b37781 -M format=mkv N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/2/6/f/26feb0b27c2a297682feba4a695ec6aeefe31814/static/13060982_15b7a6898a124a1c43a7ccc53b82f56a_web_dash_upTo1080p_720p_vbr_cae_drm_hardware.mpd" --key 98fdd687785249e6e4b2eb6fc933674e:880c0129475246322cb4ea2dfa09cf7e -M format=mkv N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/2/0/c/20c20ec63c57a9bd33d8ed5e7aa2bcb7eca496f8/static/13060858_3a33d1f042d9942bd26ab265f8a587fe_web_dash_upTo1080p_720p_vbr_cae_drm_hardware.mpd" --key 6013c17f099ecec0fd70a92c6f8b6420:2959a43e8be2a249b1db4bc91db07a81 -M format=mkv N_m3u8DL-RE.exe "https://rtlbe.vod.6cloud.fr/rtl.be/output/6/a/b/6ab387bd809d394897b0a54bfca8585249f95096/static/13058955_93d98bf4647aea2475e3f6b3f086b62b_web_dash_upTo1080p_720p_vbr_cae_drm_hardware.mpd" --key 3a3213735e0aaf481b4859af232915d1:85ab638cd08f5aaa87315632983e0a6d -M format=mkv
If it fails for a specific video, try changing "format_mpd=True" to False. I added a way in which the manifest URL can be changed to get rid of its original query parameters that can expire so you could share the download command without being restricted to a timeframe. But if you're using the script just for yourself, you can set it to be always False.
Edit: I noticed that the manifest file has multiple pssh values for different resolutions. However, even if you use the pssh corresponding to the highest resolution, you still get the same key that doesn't work.Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 22nd Mar 2024 at 03:59.
Then stick to the manual way. You can find more info on the sticky threads (all of them).
Here's your 540p requested video. https://www.transfernow.net/dl/20240322fsjmZdwg
Maybe someone else can get 720p for you. I tested the key and it doesn't work.Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 22nd Mar 2024 at 07:53.
Hi,
Thanx for your script 2nHxWW6GkN1l916N3ayz8HQoi. I just tried it and got this error. All the other scripts found here (ITV, C4, boltgeneric) work correctly. Any idea what the problem is?
C:\Users\Me\WKS-KEYS\rtlplay.py", line 6, in <module>
ModuleNotFoundError: No module named 'pywidevine.cdm'
Maybe it's related to the wvd file which is not in the right place? (I saw in your script a line WVD_FILE = "./device_wvd_file.wvd") I never needed it until now, everything worked with the 2 files device client id blob and device private key. I added the wvd file with the 2 mentioned above (here: C:\Users\Me\WKS-KEYS\pywidevine\L3\cdm\devices\android_generic)
If it helps, here's my pywidevine version: pywidevine version 1.8.0
Can someone help me to download a video from plus.rtl.de
By frankio in forum Video Streaming DownloadingReplies: 230Last Post: 19th Jul 2026, 18:20 -
Download from plus.rtl.de
By Data2006 in forum Video Streaming DownloadingReplies: 80Last Post: 8th Oct 2024, 16:00 -
Download movie from "Plus.rtl.de"
By linkinp in forum Video Streaming DownloadingReplies: 36Last Post: 12th Apr 2024, 04:05 -
First try with RTL+/TVNow
By resonator79 in forum Video Streaming DownloadingReplies: 3Last Post: 23rd Feb 2023, 06:41 -
How can I download videos from play.rtl.hr?
By Nintendo Custom in forum Video Streaming DownloadingReplies: 23Last Post: 24th May 2022, 12:51
