https://fmoviesz.to/tv/hawaii-five-o-92mvq/8-12
I want to download this episode in high quality, but unfortunately I can't because:
1 - Using StreamFab, when you reach almost halfway through the download, the speed drops sharply.
2 - Using IDM, I can even download it, but not in 854x480, which is the original quality of the material...
Anyone who can solve this problem for me, I would appreciate it.
Results 1 to 11 of 11
Have you tried grabbing the list....m3u8 url with The Stream Detector and use yt-dlp or N_m3u8DL-RE to download it?
Tried the first two video sources: Vidplay and MyCloud.
Both returned a maximum of 480p.
Didn't try the third because of "proxy" detected.
which is the original quality of the material... -
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
there is 1080p from other site but not free
[Attachment 77849 - Click to enlarge]
[Attachment 77850 - Click to enlarge] -
There is no license URL, only PSSH and MPD, even when refreshing the page.
384x512, using IDM, but saved in .TS format
I'm only interested in this specific episode because of Kathleen Beller, if you could save it in the best possible quality and upload the episode somewhere else for me to store, I would be grateful. -
Of course there's no license url or PSSH, this is not an encrypted video. It would be funny if a pirate site used WideVine to protect their videos. yt-dlp only works with unprotected content anyway. N_m3u8DL-RE works with either protected and unprotected.
What's the point of your post if you're not sharing a command or a download link? -
Here's a WEB-DL from prime video, which is most likely the best possible quality available:
https://www.transfernow.net/dl/202403214zqgecOl
Code:Video ID/String : 1 Format/String : AVC Format/Info : Advanced Video Codec Format_Profile : High@L4 Format_Settings : CABAC / 4 Ref Frames Format_Settings_CABAC/String : Yes Format_Settings_RefFrames/String : 4 frames CodecID : V_MPEG4/ISO/AVC Duration/String : 50 min 30 s BitRate/String : 13.6 Mb/s Width/String : 1 440 pixels Height/String : 1 080 pixels DisplayAspectRatio/String : 4:3 FrameRate_Mode/String : Constant FrameRate/String : 24.000 FPS ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 8 bits ScanType/String : Progressive Bits-(Pixel*Frame) : 0.363 StreamSize/String : 4.78 GiB (98%) Default/String : Yes Forced/String : No colour_range : Limited colour_primaries : BT.709 transfer_characteristics : BT.709 matrix_coefficients : BT.709 Audio ID/String : 2 Format/String : E-AC-3 Format/Info : Enhanced AC-3 Format_Commercial_IfAny : Dolby Digital Plus CodecID : A_EAC3 Duration/String : 50 min 30 s BitRate_Mode/String : Constant BitRate/String : 224 kb/s Channel(s)/String : 2 channels ChannelLayout : L R SamplingRate/String : 48.0 kHz FrameRate/String : 31.250 FPS (1536 SPF) Compression_Mode/String : Lossy StreamSize/String : 80.9 MiB (2%) Title : English Language/String : English ServiceKind/String : Complete Main Default/String : Yes Forced/String : No Text ID/String : 3 Format/String : UTF-8 CodecID : S_TEXT/UTF8 CodecID/Info : UTF-8 Plain Text Duration/String : 49 min 40 s BitRate/String : 55 b/s FrameRate/String : 0.240 FPS ElementCount : 715 StreamSize/String : 20.3 KiB (0%) Title : English Language/String : English Default/String : No Forced/String : No
