I have an Elgato HD60 Pro capture card (1 HDMI input) in my system that I've been using to capture live Zoom meetings. Is there a way that I can add a second camera and plug the HDMI from both cameras into some device that then outputs to the single input on the Elgato? If so, what is that device called, and then how would I be able to set up a picture in picture type scenario for the Zoom meetings? Thank you in advance for any advice.
https://www.videoplusfrance.com/fr/4028978-roland-v-02h-micro-melangeur-video-2-canaux-hdmi.html
that's the kind of equipment you need imo*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Damn.. I was hoping for something less complicated and expensive
There is probably less expensive, this is pro stuff (reliable/endurant). Obs can capture from 2 or more different cards at the same time, not sure if it can mix them live, haven't tried much. But then again : dropped frames, glitches etc are a possible when you go the cheap road.
Ok thank you.. Maybe there's a different capture card that has inputs for two HDMI sources.. It's really not critical though at this point.
I don't think I have ever seen a capture card that could accept video input from 2 different HDMI connections at the same time. If such a thing exists, I doubt that it would be is less expensive than a live stream switcher or a second capture card.
Here is a video about the device I recommended: https://www.youtube.com/watch?v=pAA-WaU3kTELast edited by usually_quiet; 20th Mar 2024 at 18:36.
Cheap HDMI Capture Device, is it worth it?
By therock003 in forum Capturing and VCRReplies: 60Last Post: 17th Jan 2024, 06:07 -
Using a Extron 300A with a HDMI capture device
By 32768 in forum Capturing and VCRReplies: 3Last Post: 14th Dec 2023, 16:49 -
Is there a USB HDMI capture device that handles 50fps?
By AVR2 in forum Capturing and VCRReplies: 3Last Post: 4th Jun 2023, 20:47 -
Cable box > HDMI audio receiver > HDMI splitter > Capture card?
By ArianK in forum AudioReplies: 0Last Post: 6th May 2021, 03:18 -
Need USB capture device for analog sources in ProRes 422.
By digicube in forum Capturing and VCRReplies: 31Last Post: 22nd Jul 2019, 14:14
