Hello,
I used "Audio to text" function in Subtitle Edit and the recognition of the words was perfect, but... I have a big timing problem in the column of "Start Time".
Each Start Time is brought forward.
I'll explain:
for example, if the first 20 seconds of video have no dialogue, the first words spoken are not marked at the 20th second, but at time 0.
Start Time 0:00 and End time 0:23.
So, the End Time is right but the Start Time is wrong.
And so also in the rest of the video.
If the next dialogue starts at 0:40 and ends at 0:43, this time too I have: Start Time 0:24 instead of 0:40 and End Time right again, 0:43.
As you can see it doesn't start in the right moment (0:40) but soon after the previous End Time (that was 0:23).
Can you please tell me which option I need to change within Subtitle Edit to avoid running into this problem?
Thanks very much in advance!
Results 1 to 12 of 12
Thank you,
I tried Faster-Whisper but the recognition gives error: "No text found". -
Try to use smaller models, most likely you don't have enough VRAM.
You can use CPU with "--device=cpu" command.
8GB is enough for large model.
AMD doesn't have support for CUDA. -
The Start Time error was using a big model of 2.88 Gb.
The No Text error was using a little model Tiny of only 74 Mb (the only available in Fast-Whisper) -
With what engine? And what Subtitle Edit version?
Subtitle Edit version 4.02
Model: Large-q5_0 (2.88 Gb) with Engine: CSS
Model: tiny.en (74 MB) with Engine: Purfview's Faster-Whisper -
installing the latest version, the situation even worsened. Now anyway it always tells me: text not found
How it worsened?
Did you see popup to download "cuBLAS and cuDNN"?
Try adding "--device=cpu" command to advanced field.
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
getwvkeys.cc code":400,"error":true,"message":"Failed to get license: 405
By Koldunas in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2023, 02:44 -
{"code": 2048, "message": "Authentication failed"} when getting license
By warmachine in forum Video Streaming DownloadingReplies: 2Last Post: 26th May 2023, 16:34 -
How to change "m3u8" to "json" and "ts" to "js" extension
By wowza in forum Newbie / General discussionsReplies: 6Last Post: 4th Mar 2023, 15:36 -
By wowza in forum User guidesReplies: 6Last Post: 4th Mar 2023, 15:36
