Right now I'm using DVDStyler to create DVDs. I noticed that when I stuck one of the DVDs into a DVD recorder and tried to record over it an error came up saying the disc was finalized, and when I went into the menu the Disc Edit option was disabled. How can I stop DVDStyler from finalizing the discs so I can use them again? The discs are DVD+RW by the way.
Finalazing is an essential part of the actual burn process since a player could not play the created disk.
So the alternative is to select 'just generate' from the burn options. Then the programs creates the necc. files so you can test the dvd before you actually burn a disk. (Use imgburn to do the actual burning then) -
From DVD+RW Alliance:
Do DVD+RW discs need to be finalized?
No. Everytime a DVD+RW disc is ejected, either from a DVD+R/+RW drive in a PC or from a DVD+R/+RW video recorder, it automatically contains the needed information for the disc to be read in a normal DVD-Video player or DVD-ROM drive. There's no need to perform a time-consuming "finalisation" process on the disc, as is required for all other rewritable DVD formats, and for CD-RW. Likewise, there is no such thing as "unfinalizing" a DVD+RW disc: you can always make modifications or add new contents to a disc without performing some special procedure in advance.
Perhaps something else is going on.
Help with DVDstyler error
By animalia in forum Authoring (DVD)Replies: 12Last Post: 9th Jan 2023, 14:29 -
Problem with DVDStyler
By Salv1 in forum Authoring (DVD)Replies: 4Last Post: 6th May 2021, 09:23 -
DVDStyler Failed
By reign256 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2021, 20:12 -
2 Blu Ray Discs, 1 srt subtitle file, do I have to rip and merge both discs
By sethhuner in forum Blu-ray RippingReplies: 5Last Post: 27th Jun 2020, 10:24 -
Need Help Finalizing Videos
By Frustrated Teacher in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 30th Apr 2020, 05:11
