In ffmpeg, if I use -vf format=rgb24, will I always get the correct colors for any image format, including jpg and webp? What should I set -qscale:v (-q:v) to so I can get the best quality, 2 or 1? Will adding -qmin 1 and -qmax 1 also improve the quality?
No, as you can see in the documentation of mjpeg and libwebp, which are the default encoders used by ffmpeg for jpg and webp, neither supports the rgb24 pixel format.
ffmpeg -help encoder=mjpeg
Code:Encoder mjpeg [MJPEG (Motion JPEG)]: General capabilities: threads Threading capabilities: frame and slice Supported pixel formats: yuvj420p yuvj422p yuvj444p yuv420p yuv422p yuv444p ...
Code:Encoder libwebp [libwebp WebP image]: General capabilities: dr1 Threading capabilities: none Supported pixel formats: bgra yuv420p yuva420p ...
Code:libwebp encoder AVOptions: -lossless <int> E..V....... Use lossless mode (from 0 to 1) (default 0) -preset <int> E..V....... Configuration preset (from -1 to 5) (default none) none -1 E..V....... do not use a preset default 0 E..V....... default preset picture 1 E..V....... digital picture, like portrait, inner shot photo 2 E..V....... outdoor photograph, with natural lighting drawing 3 E..V....... hand or line drawing, with high-contrast details icon 4 E..V....... small-sized colorful images text 5 E..V....... text-like -cr_threshold <int> E..V....... Conditional replenishment threshold (from 0 to INT_MAX) (default 0) -cr_size <int> E..V....... Conditional replenishment block size (from 0 to 256) (default 16) -quality <float> E..V....... Quality (from 0 to 100) (default 75)
That bgra format for libwebp is perhaps 8bit rgb, like rgb24 is, not planar as rgb24 is, but I guess that does not matter. I read, most likely here (poisondeathray inputs) that it could be done losslessly. It was discussed here, try to google "videohelp forum rgb lossless webp"
Do these topics/posts remind anyone of a recently banned 'Troll' who kept starting topics about 'lossless' pic formats despite already having all the answers presented to him.
Best Visually Lossless File for Highest Quality
By Jay123210599 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2024, 23:02 -
Smallest Visually Lossless Files
By Jay123210599 in forum Newbie / General discussionsReplies: 10Last Post: 19th Jan 2024, 02:10 -
VirtualDub2 Lossless jpgs
By Jay123210599 in forum Newbie / General discussionsReplies: 23Last Post: 15th Jan 2024, 22:03 -
Lossless JPGs
By Jay123210599 in forum ComputerReplies: 2Last Post: 2nd Jan 2024, 10:54 -
Virtually or Visually Lossless Number
By Jay123210599 in forum Newbie / General discussionsReplies: 31Last Post: 27th Dec 2023, 01:45
