I use Avidemux to transcode a folder of files from one container to another. The problem is that since the folder is quite large with many files, I want the process to work in the background whilst I do other stuff on the PC. The problem is that on most occasions the processing window appears and I have to click away to minimise it, but as soon as the next file is loaded, it reappears. I just want it to work in the background and only appear IF I click the tab on the taskbar. Thanks for any help!
Code:set avidemux="C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe" set videocodec=Copy set audiocodec=Copy for %%f in (*.mkv) do %avidemux% --video-codec %videocodec% --audio-codec %audiocodec% --force-alt-h264 --load "%%f" --save "%%~nf.mp4" --quit echo. Pause
Where do I add this in the batch file? I tried after the exe launches;
and at the start;Code:set avidemux="C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe" start /min avidemux set videocodec=Copy ...
Both give errors about not finding "avidemux"Code:start /min avidemux set avidemux="C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe" set videocodec=Copy ...
should do itCode:
start /min "C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe"
This doesn't work unfortunately. Changing;
to this;Code:set avidemux="C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe"
causes every video file within the directory to have the following appended to the end, in the output log;Code:start /min "C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe"
Code:..... is not recognized as an internal or external command, operable program or batch file.
set avidemux="C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux.exe" set videocodec=Copy set audiocodec=Copy for %%f in (*.mkv) do start /b %avidemux% --video-codec %videocodec% --audio-codec %audiocodec% --force-alt-h264 --load "%%f" --save "%%~nf.mp4" --quit echo. Pause
So I went looking for a solution and I found it by using a combination of things.
1. The AviDemux GUI cannot be kept running in a minimised state. I don't know why and none of the replies above have suggested it can do so either. I feel it should be able to, but nobody has figured it out.
2. Someone suggested that instead of running avidemux.exe in the batch file, to use avidemux_cli.exe instead. This however also ran onscreen. However it was probably easier to keep a CLI minimised than a GUI, since nobody had figured out the latter.
3. Then it was suggested that I add this code to the start of the batch file script;
4. So by combining both parts (with a change to the exe) into the batch script, we get the following;Code:rem --------------------------------------------- rem how to minimize the command prompt when rem running a batch script? rem --------------------------------------------- rem https://stackoverflow.com/questions/2106723/ rem how-to-minimize-the-command-prompt-when- rem running-a-batch-script if not "%minimized%"=="" goto :minimized set minimized=true start /min cmd /C "%~dpnx0" goto :EOF :minimized rem Anything after here will run in a minimized window
5. Now when the script runs, it runs minimised does the complete task and prompts to close - all in the background. Mission accomplished.Code:rem --------------------------------------------- rem how to minimize the command prompt when rem running a batch script? rem --------------------------------------------- rem https://stackoverflow.com/questions/2106723/ rem how-to-minimize-the-command-prompt-when- rem running-a-batch-script if not "%minimized%"=="" goto :minimized set minimized=true start /min cmd /C "%~dpnx0" goto :EOF :minimized rem Anything after here will run in a minimized window set avidemux="C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux_cli.exe" set videocodec=Copy set audiocodec=Copy for %%f in (*.mkv) do %avidemux% --video-codec %videocodec% --audio-codec %audiocodec% --force-alt-h264 --load "%%f" --save "%%~nf.mp4" --quit echo. Pause
I hope at some point someone can figure out the original request of how to keep the GUI minimised and not having to use the CLI. The only reason I say this is because the GUI gives a good popup warning when there is an error to pinpoint it to the exact part in the video. For now however, it seems that the goal has been achieved.
Batch Process Videos with FFmpeg
By Jay123210599 in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2023, 17:53 -
Best way to change .avi frame rate as batch process?
By cluelessScientist in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2023, 10:42 -
batch to process files one by one starting from a .txt list?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2022, 08:06 -
MP4 File Re-Sync Batch Conversion (Avidemux?)
By lplp in forum Video ConversionReplies: 1Last Post: 20th Sep 2019, 23:47 -
has there EVER been a solution to Avidemux's no batch problem?
By KneeRow in forum Video ConversionReplies: 1Last Post: 23rd Aug 2019, 14:28
