Hello everyone! I have a small question. Maybe someone will be able to help me.
So DVDFab, 12 in my case, has an option to split the main title by chapters, so I can burn a 4k movie on 2 bd-r 50 for example.
When I make the first half everything's great, chapters are separated as the should be, example
But when I make the second half from 10th chapter and to the final one, I somehow get thisFILES:
Name Time In Length Size Total Bitrate
00294.M2TS 0:00:00.000 1:31:15.803 44,900,106,240 65,597 kbps
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:07:23.776 52,634 kbps 86,811 kbps 0:02:07.085 64,865 kbps 0:06:17.710 60,752 kbps 0:06:22.090 274,414 bytes 1,920,468 bytes 0:02:06.084
2 0:07:23.776 0:08:24.545 51,953 kbps 90,510 kbps 0:14:34.039 62,214 kbps 0:12:38.090 58,734 kbps 0:14:43.132 270,862 bytes 1,362,007 bytes 0:10:25.458
3 0:15:48.322 0:12:15.234 51,928 kbps 88,648 kbps 0:27:37.697 64,852 kbps 0:21:06.556 60,849 kbps 0:17:47.775 270,731 bytes 1,549,158 bytes 0:27:36.821
4 0:28:03.556 0:04:32.730 55,002 kbps 95,212 kbps 0:32:04.380 69,880 kbps 0:28:41.803 65,768 kbps 0:28:46.808 286,803 bytes 1,466,970 bytes 0:29:52.749
5 0:32:36.287 0:13:00.321 54,216 kbps 94,745 kbps 0:38:45.489 68,974 kbps 0:38:45.489 61,800 kbps 0:38:48.117 282,647 bytes 1,536,486 bytes 0:32:55.598
6 0:45:36.608 0:10:20.661 53,291 kbps 91,147 kbps 0:52:11.753 65,893 kbps 0:47:48.031 61,769 kbps 0:48:28.280 277,855 bytes 1,324,105 bytes 0:49:20.666
7 0:55:57.270 0:12:55.399 55,870 kbps 92,312 kbps 1:07:12.778 76,324 kbps 1:05:48.736 66,969 kbps 1:05:48.527 291,266 bytes 1,756,709 bytes 1:07:11.819
8 1:08:52.670 0:08:50.154 53,592 kbps 86,259 kbps 1:09:49.935 67,289 kbps 1:09:53.355 62,181 kbps 1:09:58.485 279,404 bytes 1,873,175 bytes 1:14:44.521
9 1:17:42.824 0:13:32.978 56,012 kbps 95,680 kbps 1:21:07.195 66,835 kbps 1:22:05.545 62,617 kbps 1:18:13.563 292,038 bytes 1,937,195 bytes 1:27:19.901
Something's not right, no timestamps no kbps, no nothing.FILES:
00294.M2TS 0:00:00.000 1:12:10.784 33,578,029,056 62,026 kbps
CHAPTERS:
1 24:59:17.057 0:00:00.000 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 835,474 bytes 835,474 bytes 24:59:17.057
2 24:59:17.057 0:00:00.000 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 bytes 0 bytes 0:00:00.000
3 24:59:17.057 0:00:00.000 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 bytes 0 bytes 0:00:00.000
4 24:59:17.057 0:00:00.000 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 bytes 0 bytes 0:00:00.000
5 24:59:17.057 0:00:00.000 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 bytes 0 bytes 0:00:00.000
6 24:59:17.057 0:00:00.000 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 bytes 0 bytes 0:00:00.000
7 24:59:17.057 -23:-47:-6.-272 0 kbps 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 kbps 0:00:00.000 0 bytes 0 bytes 0:00:00.000
What might be the problem?
And thanks in advance for any input.
Best regards!
  To DVDFab or not to DVDFabBy Yanta in forum Blu-ray RippingReplies: 32Last Post: 8th Jul 2023, 18:31
  DVDFab Launches Enhanced Product Suite in DVDFab 12By DVDFab Staff in forum Latest Video NewsReplies: 0Last Post: 13th Oct 2020, 23:11
  Splitting Blu-Ray MKV By ChaptersBy mugz8391 in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Aug 2020, 16:11
  Splitting DVD into ChaptersBy RandmTask in forum MacReplies: 3Last Post: 28th Mar 2020, 06:38
  DVDFab for LinuxBy nypaulie in forum LinuxReplies: 3Last Post: 11th Jan 2020, 18:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
