Results 1 to 18 of 18
    Aug 2023
    Ukraine
    Hello. There is such a link mpd...
    https://vs12.vcdn.biz/ea7c2a50874e06892616c81fed8764f1_mgg/vod/mpd/b/450_900_1350_1500...0/manifest.mpd
    The program N_m3u8DL-RE normally downloads temporary video mp4 files 142 pieces (each size 10.0 MB), adds the disputed one 143 piece and the last one has a file size of 1.5 GB. Collect together the mp4 files have a size of - 2.11 GB with a duration of 01:15:38, although it should be 1.39 GB with a duration of 00:49:59 (only the video without sound and subtitles)
    Here are the options available on the command line - N_m3u8DL-RE "%mpd%" --check-segments-count:false --save-name "%filename%" %keys%
    yt-dlp - this program load normally video size 1.39 GB
  2. Running:
    N_m3u8DL-RE.exe https://vs12.vcdn.biz/ea7c2a50874e06892616c81fed8764f1_mgg/vod/mpd/b/450_900_1350_1500_2000_5000/u_sid/0/o/176166551/rsid/8a209735-8af0-46f9-afc9-5aae98954316/u_uid/1546846946/u_vod/4/u_device/cms_html5/u_devicekey/_site/u_srvc/2741/te/1760354712/u_did/web_ufUvWAJW4hh3VWBsJtUHNwHAi8JtabBU/wtrmrk/0/manifest.mpd
    I got a 2.79 GiB video file, 49:59 long. Can't say anything else about it since you didn't provide a key.
    Aug 2023
    Ukraine
    you don't need a key, but for the sake of experimenting --key 7d91116c8f0b95b8db4953f1f26e6aa2:5a4491ef67bc263c0 125c5914322dfba
    Aug 2023
    Ukraine
    Originally Posted by white_snake View Post
    Running:
    check the sound on the video is from 49:30 to 49:59 is it present? , and is the image on the video not distorted?
  5. Originally Posted by nadya86 View Post
    I do because otherwise how do I determine if the files I get are corrupted or not if it's all encrypted?
    Anyway, after some testing, it's pretty obvious that N_m3u8DL-RE has a problem with this mpd. I also don't get why it shows 144 segments, when in reality all it needs to download is a single .m4s file. You could just download the single .m4s streams from the .mpd, for example the 1080p video stream:
    https://vs12.vcdn.biz/ea7c2a50874e06892616c81fed8764f1_mgg/vod/mpd/b/450_900_1350_1500_2000_5000/u_sid/0/o/176166551/rsid/8a209735-8af0-46f9-afc9-5aae98954316/u_uid/1546846946/u_vod/4/u_device/cms_html5/u_devicekey/_site/u_srvc/2741/te/1760354712/u_did/web_ufUvWAJW4hh3VWBsJtUHNwHAi8JtabBU/wtrmrk/0/media-i6499081681.m4s
    Decrypt them manually, and then mux them. Or if yt-dlp succeeded in downloading the files, and you want to do all in one go, you could try to use the mp4decrypt extension for it. N_m3u8DL-RE is definitely not the tool to use for this mpd, but anybody is welcome to prove me wrong.
    Aug 2023
    Ukraine
    This is not an isolated case when the program N_m3u8DL-RE cannot (with errors) download video and sound! There is a bug in the program, it needs to be fixed!
  7. Originally Posted by nadya86 View Post
    This is not an isolated case when the program N_m3u8DL-RE cannot (with errors) download video and sound! This is a program N_m3u8DL-RE - defect!
    Which is why you should open an issue in their repository rather than complaining about it here.
    Aug 2023
    Ukraine
    Help, how to do this?
    Aug 2023
    Ukraine
    Thank you. I have already written, but I don't know if anyone will respond?
    https://github.com/nilaoda/N_m3u8DL-RE/issues/376
  10. Don't expect this bug to be fixed quickly. Just wait and watch if you need it.
    Aug 2023
    Ukraine
    Thank you!
  12. Because this is unique, most websites don't do this
    [Attachment 77804 - Click to enlarge]
    You can modify the code
    [Attachment 77810 - Click to enlarge]
    [Attachment 77806 - Click to enlarge]
    [Attachment 77807 - Click to enlarge]
    Please note that this is not suitable for all sites , may cause more bug
  13. Originally Posted by Novia View Post
    Nice, but it would be more helpful, at least for OP, if you shared the compiled binaries.
    Aug 2023
    Ukraine
    If you can, please share the compiled N_m3u8DL-RE file, I will be very grateful!
  15. Originally Posted by nadya86 View Post
    https://github.com/Tontonnow/N_m3u8DL-RE/releases
    Aug 2023
    Ukraine
    Thank you.
