I have a 24fps video:
I put it into VidCoder to downscale it and convert it to x264:Code:Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 3 h 4 min Bit rate : 13.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.067 Stream size : 17.2 GiB (95%) Language : English Default : Yes Forced : No
[Attachment 77779 - Click to enlarge]
And it spits out a file at 23.976fps:
What's going on here?Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 3 h 4 min Bit rate : 9 580 kb/s Width : 1 920 pixels Height : 804 pixels Display aspect ratio : 2.39:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.259 Stream size : 12.3 GiB (91%) Writing library : x264 core 164 r3107 a8b68ebf Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=7 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=62500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
You have to set framerate to 24 and then input the file.
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 09:27 -
Video capture frame rate vs. final output file frame rate
By Theodore in forum Capturing and VCRReplies: 5Last Post: 18th Apr 2021, 18:48 -
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 03:50 -
Does changing video frame rate decrease quality?.
By Felow in forum Newbie / General discussionsReplies: 10Last Post: 15th Mar 2020, 09:10 -
FFmpeg is changing the frame rate to Variable when copying video?
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 1st Dec 2019, 14:14
